Old 02-08-2010, 02:29 PM   #401
nuke1
nuke1's Avatar
Re: 1967 C10 Custom Big Window
I can taste it, how close it is getting to DONE!!!!! keep it up, dig the ol'school rims!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-08-2010, 03:34 PM   #402
Slick67
Sofa King Crazy!!
Slick67's Avatar
Originally Posted by my67chevytruck View Post
It's kind of been on hold, then invisible cowl is painted, so you can see it now... needs a bit of touching up, hopefully it wont be much longer before we get it out of the shop. We may lower a couple of inches front and rear, i may have him drive it a few months like it is, and go from there.
Keep up the great work David!
It would look a little more "street rod" if it was lowered a little but it looks really good as is!
Oh yeah! The motor is still being promised, and nothing is happening, makes me mad. Always wanted those rallys, can't wait to put some new shoes on em!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 02-10-2010, 08:34 AM   #403
nuke1
nuke1's Avatar
Hey, so what is really going on with this engine of yours, if it was me I would have gone elsewhere. Have you thought about this? Because you have to be getting frustrated by now. Sorry if it is causing trouble for you.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 02-10-2010, 12:17 PM   #404
Slick67
Sofa King Crazy!!
Slick67's Avatar
I really have not needed the motor until now, so it didn't matter. Now I am getting to the point where it would help me to have it for wiring and clearance issues. I still have not installed my steering column so it isn't a necessity. I gave him my 283 on March 4th and we could not find the correct pistons for it, so he gave me a 327, so I really can't complain. He will have it for me soon and that's fine, but it is still frustrating to have waited almost a year. But he gaurantees his work and will come to the shop and help get it tuned all for around $1600.....so that isn't bad.
Old 02-11-2010, 02:28 PM   #405
67-C10
67-C10's Avatar
your truck is sweet man coming along real nice. what do you have to the bottom of your gas tank? i got mine cheap and got 8" to the bottom of the tank at the back but im just afraid of hitting it coming down a sloped drive.
67 C10 2wd Stepside (to be fleetside), Factory AC truck, Big Back Window, just got a 6.0/6l90e to jam in it now.....
Needed: paint and lots of it. and i'm sure lots more misc. parts.
Project 67 short step Build Thread
01 Sierra Crew 6.0
2015 Ford F150 Work gave me truck i really wouldn't buy a ford.
67-C10 is offline   Reply With Quote
Old 02-11-2010, 03:45 PM   #406
suville
suville's Avatar
I'm by no means a suspension expert but if you consider your plans to shim the UCA out on the rear stud you do in fact push the wheel forward in the fender but you also create an issue in that now the top ball joint is ahead of the lower and that I believe could cause steering issues. Not only is there caster,camber, and toe in there is another factor called ackerman I cannot explain that but I have had it explained to me and Im thinking by creating two different axis on the UCA and LCR pivot points you may have issues. In looking at mods to center the wheel in the opening I cant help but think moving the complete suspension forward is the best way to accomplish this. I have seen cut and modified CA's but aint no way I'd do it. So Im considering the crossmember relocation as the best way to accomplish the goal. I know that Nate,(Porterbilt) is a busy guy but I would value his input to this situation anyone that can design and build the dropmember with the expertise he has I would think he definitely understands steering geometry. Anyway not to throw cold water on your plans I would sure do some diligent research into this, you have built one of the cleanest rigs on this forum and it would be a shame to create a situation that could possibly prove disastrous you can always build another truck if it gets damaged but you cant restore or replace your body!
suville is offline   Reply With Quote
Old 02-11-2010, 04:17 PM   #407
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks for the compliment, feels good to hear that! Being that my truck is bagged I will set the ride height to accomodate for daily driving issues like this, but then again it is just a weekend cruiser so I am cutting my percentage of chances dramatically of damaging the sump at the rear. Airred out I still have over 5 inches of clearance when it's up I will have 8 to 10 like yourself! Another thing that will keep me in check is that my tires are 10 inches wide and I don't want them to rub by driving while airred out.
Hey Suville, I read alot of your comments on other threads and value your thoughts and opinions and of course open to everyones. After reading several forums and looking through this site it seems to be a "quick fix" but also seems to work and be safe. I shimmed the uca forward about .5 of an inch and in trying to keep the geometry correct I moved the lca forward about .5 of an inch, so the goemetry changed, but ever so slightly from the ackerman stand point. It was explained to me like looking at a wheel on a shopping cart, or, the reverse of a motorcycles front fork rake. You can bet I will take it easy before any road time really happens just to monitor the action/reaction of the uca's and lca's and all attached especially since my truck is bagged. I hope at a later date I will be contacting Porterbuilt to order a front end and not just for asking advise! (when my money is right) He is very knowledgable, and you as well! Keep up the great questions and answers, it makes us all think!!! Question......if I move the cab back toward the bed, maybe .25 of an inch, will that effect anything like the core support alignment or fender alignment or will they move back a little too? If this is a non-issue then that will get my front wheel closer to the center of the wheel opening also.
Old 02-11-2010, 05:39 PM   #408
kev2809
low n' slo
kev2809's Avatar
if you move the cab back, wouldnt you have to move all the mounts? including the front core support mounts, which holds the grille which bolts to the fenders?
i didnt get a chance to run outside and check my truck to make sure because its ugly ass hell outside and wont stop raining (been off all week and no progress lol)..but i think if you move the cab back, everything has to move. maybe someone can verify that..
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 02-11-2010, 06:04 PM   #409
Slick67
Sofa King Crazy!!
Slick67's Avatar
It is true, but if you only move it back .25 of an inch then it should not effect anything. The cab mounts have enough play in them and the core support to move everthing back that much without doing anything else (like steering column adjustment). I have had to move my cab forward and backwards while installing and removing my bed at least 7 times in the past couple of months and really do not see any problem with it. Then again, it is only a quarter of an inch or so.
Old 02-11-2010, 07:51 PM   #410
70stroker
70stroker's Avatar
Looking good man. but you slackin on the pics..
70stroker is offline   Reply With Quote
Old 02-12-2010, 12:20 AM   #411
Slick67
Sofa King Crazy!!
Slick67's Avatar
I'm on it! Should have some for all you picture wh*res tomorrow or Saturday! Of what I dunno, but something!!!
Old 02-16-2010, 03:55 PM   #412
Slick67
Sofa King Crazy!!
Slick67's Avatar
Update: I took my engine cradle to the machine shop today, you know that means it is almost time to get the elusive engine back. It has only been 11 months and 12 days, should have it back Saturday!!! Now for the pics, this will have to suffice until I post this weekend.
Old 02-16-2010, 05:11 PM   #413
my67chevytruck
Under Construction
my67chevytruck's Avatar
What a tease
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-17-2010, 03:33 AM   #414
texanidiot25
Eat My Rust
texanidiot25's Avatar
texanidiot25 is offline   Reply With Quote
Old 02-18-2010, 04:06 PM   #415
Slick67
Sofa King Crazy!!
Slick67's Avatar
I traded out the Blazer seats for a set of 88 to 91 buckets, they actually are in great shape just a little dirty. The Blazer seats had a little more rust on them than I wanted to contend with. Also have the bodyman coming this weekend to finish up my rockers and breather cover and a couple of odds and ends. I am getting more excited about the engine too!
Old 02-21-2010, 08:36 PM   #416
Slick67
Sofa King Crazy!!
Slick67's Avatar
A little bit accomplished this weekend, wish it was more, here goes.
Test fitted the seats....they are perfect for these trucks!
Got my gas filler neck in and got it ready to install when the bed goes on for the last time.
Some of you guys will know what these are. Sorry the pic is a little blurry. Camelhump heads.....and they are going on the 327.
They look rough now but they won't for long. Couple more hottanks and a sandblasting and they'll look like new.
What's this??? My 327! It is not quite finished but getting those heads was worth the wait. He has paint on it so that was a good indication that it will be done soon. My bodyman talked me into painting it the color of the truck.
Old 02-21-2010, 08:45 PM   #417
VA72C10
VA72C10
VA72C10's Avatar
Looking good. I'm painting mine to match the truck too.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-21-2010, 08:45 PM   #418
Slick67
Sofa King Crazy!!
Slick67's Avatar
Had a couple more pics to share. We started fixing the paint on both rockers and cab corner (no comment). Almost ready for paint.
Got the valve covers and the breather cover prepped and primed so hope to have a little color on those before the end of next week.
Old 02-21-2010, 08:49 PM   #419
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks bro! Last minute decisions.......they can make you or break you. I think I made the right choice!
Old 02-21-2010, 09:18 PM   #420
VA72C10
VA72C10
VA72C10's Avatar
It's really coming together....engine cover is going to look great and it's going to really flow well with the engine and valve covers all painted the same!
Old 02-21-2010, 09:51 PM   #421
kev2809
low n' slo
kev2809's Avatar
good idea on the color matched engine. thats gonna look good.
hey whats seats did you drop in there?
-_--_--_ _________
Old 02-21-2010, 10:06 PM   #422
suville
suville's Avatar
"My bodyman talked me into painting it the color of the truck."
Bet he didnt have to talk to hard.... Good choice! Carries out your whole theme.
Old 02-21-2010, 10:17 PM   #423
Slick67
Sofa King Crazy!!
Slick67's Avatar
Hope it comes out as good as some of your ideas!
Thanks Kevin! They are 88 to 91 chevy truck buckets.
Not too hard
Old 02-21-2010, 10:34 PM   #424
my67chevytruck
Under Construction
Looking. Good David!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 02-22-2010, 09:42 AM   #425
0331grunt
Now what??
0331grunt's Avatar
Good choice with the color matched engine! Whole thing is looking good
69 Long Fleet - Project
06 Ram 1ton Cummins 4x4-DD
01 Tahoe- wifes
"The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi
"A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell
my, um, build
USMC OIF Veteran SEMPER FI!
0331grunt is offline   Reply With Quote
1967, custom, lwb
