Closed Thread
Old 06-28-2010, 01:15 PM   #401
Lippyp
English Chevy Owner
Lippyp's Avatar
Re: What did you do to your truck today!
Stripped the old intake off and got the edelbrock performer EPS installed and then ran into a snag with the HEI not fitting.
This
to this
to this
to this
Just got to sort out if I can fit a stock HEI or whether I need to convert the twin point mallory to electronic with an external coil and then finish cleaning up and painting all the odd little brackets etc and refit them. I've even got a cool little direct mount moon temp guage to go in one hole on the manifold. The Mickey T valve covers are getting soda blasted as we speak and then I can either polish or paint them.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline
Old 06-29-2010, 12:12 PM   #402
DorianB
DorianB's Avatar
temporarily mounted a new radio in the spot for the heater controls (it will be stealth mounted later) replaced the door speakers with marine speakers (so that water won't kill them) and continued working on painting the door panels.
I am thinking about putting a pinstripe design on the bottom of the door once I get it looking ok. Maybe something in yellow (Navy blue paint right now)
DorianB is offline
Old 06-29-2010, 12:17 PM   #403
07SSSC
07SSSC's Avatar
My dad found my Bowtie wingnut yesterday so that was my big install last night. Between a headache, sore jaw from a visit to the dentist and the 98* temp, I stayed inside. Hopefully I can get my carpet all prepped for install and get all of my stereo components installed for good tonight.
'69 Chevy C/10-under reconstruction -- '68 C20 Camper 50th Anniversary-runs, but sorely needs a resto --
'07 Cobalt SS/SC-very fun DD -- '93 Chevy K2500-LQ4/4L80E swap --
'84 Trans Am-awaiting (LS) drivetrain -- '00 Trans Am-road tripper -- '06 Z06-577 WHP beast
07SSSC is offline
Old 06-29-2010, 12:23 PM   #404
71tahoe
71tahoe's Avatar
This
to this
to this
to this
Looks good. Even with the v8 in the rear position (with good motor mounts), the HEI will fit. You should take the cap off to install anyway and it will give you more clearance. If it's intake manifold interference you're worried about I won't be any help with the EPS. Performer works fine.
71tahoe is offline
Old 06-30-2010, 11:00 AM   #405
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Cleaned her up and enjoyed my new 406...
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline
Old 06-30-2010, 11:45 AM   #406
Lippyp
English Chevy Owner
Lippyp's Avatar
Even with the cap off its hitting the firewall enough to push the top forward and stop me dropping it in I think its engine mount bodgery. I've decided to go with a Pertronix conversion kit for the Mallory as its nearly new and a flamethrower coil, should be here tomorrow. Coil is a black one so it should dissaper on the firewall a little and it'll be relocated a bit more out of sight and rewired anyway.
Phil
'67 C10 long fleet.
Lippyp is offline
Old 06-30-2010, 11:55 AM   #407
1quik70
I walked out this morning, turned the key, and drove to work!! After my 8hrs, I'm gonna dump the grass clippings out of the back and drive home! Man, is it nice not to be building this one at the moment!
1quik70 is offline
Old 06-30-2010, 12:12 PM   #408
Marc33
Marc33's Avatar
completed my big block install, worked out a few monor bugs and drove her!!!
(broke the motor in last friday)
Yeehaw!!!!
Current stable:
1970 K5 Blazer 4x4
1972 K5 Blazer 4x4
SOLD:
1971 GMC Sierra Grande 2500 2wd
1972 Chevrolet K5 Blazer
1966 Chevrolet C20
1972 Chevy Suburban 4x4 1500
1956 Chevy 150 2 door post
1956 Chevy 2 door post bel air
1968 Chevrolet C20
1958 Ford Thunderbird
1968 4x4 Suburban 1/2 ton
Marc33 is offline
Old 06-30-2010, 01:18 PM   #409
67Slider
67Slider's Avatar
Originally Posted by SweetandLong68 View Post
I gave my upper radiator hose a little long life expectancy by making a rub guard for it! It was rubbing on my altenator bracket.
Hey Chris, I have the same rub on my upper and lower. Got any pics of how you did it. I have been trying to think of a low vis way to make a rub gaurd.
Anyone else have any cool ideas?
Matt
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 06-30-2010, 02:33 PM   #410
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
Matt
Here ya go.. I just went outside and took some pics! Now it is raining! THANKS! hahahha All I did was use some 3/4" Heater hose. Slit it down one side. Rolled it over and ziptied it to the upper hose at the bracket. Works good so far.
lata
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline
Old 06-30-2010, 02:39 PM   #411
davebloomer
davebloomer's Avatar
Bought an iPhone 4 so I can take many pics and hd video of her. Hopefully tomorrow I'll start my cam and heads swap
davebloomer is offline
Old 07-03-2010, 07:13 PM   #412
DaddyO
DaddyO's Avatar
Renewed my insurance policy.....
DaddyO is offline
Old 07-03-2010, 07:52 PM   #413
bglad420
bglad420's Avatar
Hung my fenders on the wall...
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50.
bglad420 is offline
Old 07-03-2010, 08:04 PM   #414
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
dRILLED OUT THE RIVITS AND KNOCKED OUT THE 3/4 TON FRAME SUPPORTS ..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 07-03-2010, 11:53 PM   #415
pat 70/71
pat 70/71's Avatar
I had a problem with fuel @ the pump chased it down to crap in the feed line (in the tank that is brand new) blew it out runs great. not going to say where this tank was purchased but you know who you are. might want to up the quality control just a tad! cheers, Pat
pat 70/71 is offline
Old 07-04-2010, 01:06 AM   #416
vectorit
What?
vectorit's Avatar
Managed to get all four new panels cut, and installed on the head liner of the burb. Tomorrow I plan to remove one and cut out a new one, since the gaps are to big for the bow strips and just barely hanging on.
The whole thing looks good, but I predict that I will re do another panel in the future.
Trying hard to get her looking good for the Brothers show, and not having any head liner was bugging me to much.
Hopefully she will look her best amongst so many hot looking trucks at the show.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 07-04-2010, 06:33 AM   #417
OhioDan
OhioDan's Avatar
Cool Re: What did you do to your truck today!
Worked on the sound sys. Jeez there's a lot of wires? Thank god for by-focals.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline
Old 07-04-2010, 10:59 AM   #418
1968ratrod
1968ratrod's Avatar
1969 stepper- bolted carb down, put in the radiator, water, added gas and busted it off for the first time. Went to local parts store and bought wheel cylinders, brake hardware kits and new front and rear shoes. Going to make it road worthy.
1965 Chevy Suburban
2003 Chevrolet S10
2011 Harley Streetglide
1968ratrod is offline
Old 07-04-2010, 08:19 PM   #419
white71chevy
white71chevy's Avatar
I tried to hook my fan switch up but failed badly lol I have no idea what's wrong with it.
71 c10 with a 305. new dd wohoo
1956 chevy bel air hard top with a 327.
1998 honda passport V6 old dd.
white71chevy is offline
Old 07-04-2010, 08:54 PM   #420
vectorit
What?
vectorit's Avatar
Finished the headliner.
Vacuumed up all the mess.
Took her out for a cruise around town.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 07-04-2010, 09:04 PM   #421
weircc
weircc's Avatar
added new trim before then after
weircc is offline
Old 07-04-2010, 10:27 PM   #422
07SSSC
07SSSC's Avatar
Looks good weircc.
I got my carpet installed yesterday, put the seat in today. Then put new door weather stripping in and capped it off with new door sill plates. So glad I'm done with this go around, tomorrow I clean in preperatoin for next weekends huge car chow. Very excited about that, can't wait!
07SSSC is offline
Old 07-04-2010, 10:53 PM   #423
tys toy
tys toy's Avatar
Swapped the rear and front suspension for a 5 lug disc. Going to slide the frame out tomorrow for blasting
tys toy is offline
Old 07-04-2010, 11:17 PM   #424
heymoe
heymoe's Avatar
This was a few days ago but I finished part of the exhaust and mounted the cab. Today I rebuilt the bed and started to figure out how I want to mount my air tank. Let me know what you all think.
heymoe is offline
Old 07-04-2010, 11:19 PM   #425
heymoe
heymoe's Avatar
one more
heymoe is offline
Closed Thread
