Old 01-22-2013, 06:07 PM   #401
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by Low Elco View Post
How'd I miss this? You're cookin'! And the work looks great!
Thanks for the up lift there man I do try. Good luck and keep working my fiend.
gdavis is offline   Reply With Quote
Old 01-22-2013, 06:13 PM   #402
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by 69swb View Post
You sir are doing a great job and WOW you've done a lot of work. I'd been meaning to check out your thread for awhile. Glad I finally did. I'm inspired!
Thank you so much I do try. I somtimes do it twice before I get it right. But in the end it is going to be fine. Good luck and I do enjoy comments from you guys on my build. Keep working my friend.
Old 01-22-2013, 06:20 PM   #403
emilio impala
emilio impala's Avatar
Re: 1968
Muy buen trabajo! Saludos!
emilio impala is offline   Reply With Quote
Old 01-24-2013, 06:24 PM   #404
gdavis
gdavis's Avatar
Re: 1968
thanks
Old 01-24-2013, 06:28 PM   #405
gdavis
gdavis's Avatar
Re: 1968
Caught the fue bug. Have not been outside untill today. I noticed a build on TV and I started me to think. How important is it to have the upper A arms in the center. I have mine about 1/4 inch off center. If it does matter I need to take it apart again and fix the problem.
Old 01-24-2013, 06:31 PM   #406
gdavis
gdavis's Avatar
Re: 1968
here are the pictures of the A frame arms off center. Don't look at the bolts I am replacing them with grade eight bolts. Just not got around to it.
Old 01-24-2013, 06:34 PM   #407
gdavis
gdavis's Avatar
Re: 1968
Everything is geting dusty up the caopy. I need to add my side I guess.
Old 01-24-2013, 06:47 PM   #408
sduckworth13
sduckworth13's Avatar
Re: 1968
Originally Posted by gdavis View Post
Today I was looking at the truck and I found one of my welds that I was so pround of on the roof, gave way. Now I have to reweld it and this time do it right. Someone put a hole in te middle of the roof. I guess it was for a radio or a CB.
I also have a hole in my roof that needs patched that a previous owner put there too. Must have been a trend.
Posted via Mobile Devicee
Scott
sduckworth13 is offline   Reply With Quote
Old 01-25-2013, 07:10 PM   #409
gdavis
gdavis's Avatar
Re: 1968
Today, I decided to take the upper control arms off and center them. They were 1/4 inch off center. I asked if anyone ever came across with this, but decided too it anyway. So now they are on right. Also welded up the hole in the cab roof. and put a little bondo and tomorrow I will sand it down and it is complete. Taking short cuts sometimes does not pay off. If any body ask there is a difference between the left and right upper control arms. There is a little hump and it goes to the front of the truck. If you don't do this the hump will be in the way to turn the spendle to turn.
Old 01-26-2013, 03:53 AM   #410
jayman68
Fun Stuff
jayman68's Avatar
Re: 1968
What part of the A arm is off center, and how did it get that way? I don't notice anything in the pics. I probably should check mine. Looks like you are making good progress, good job.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Old 01-26-2013, 07:09 PM   #411
gdavis
gdavis's Avatar
Re: 1968
[QUOTE=jayman68;5844110]What part of the A arm is off center, and how did it get that way? I don't notice anything in the pics. I probably should check mine. Looks like you are making good progress, good job.[/QUOTE
If you look at the picture you can see a gap on the right and nothing on the left. Where the upper control bolts to the cross member. I just jacked up the lower control arm to compress the coil springs a little and I took the upper ball joint cotter pin and nut off. Then I took the two nuts that hold the upper control to the cross member and truned it in the direction it needed to go. It took me about 30 to 45 minutes. But I am slow. and 62 years old so I took a break in my chair every few minutes. Just getting over the flu. Good luck my friend. and happy building.
Old 01-26-2013, 07:15 PM   #412
gdavis
gdavis's Avatar
Re: 1968
Today I went over to a friends house and he gave me two shocks bolts where they bolt thru the frame. Mine were broke both of them. And a new door panel and a window crank asy. He has a few 67 thru 72 trucks. I also got two new door handles for the outside of the door from LMC trucks.
Old 01-26-2013, 07:16 PM   #413
gdavis
gdavis's Avatar
Re: 1968
Parts from LMC trucks
Old 01-26-2013, 07:24 PM   #414
gdavis
gdavis's Avatar
Re: 1968
So after I came home I steel wool the two chrome pieces for the outer grille. Thn I painted them black. they were in bad shape that is why I painted them black And they will stand out against the orange I am going to paint the truck.
Old 01-26-2013, 07:36 PM   #415
gdavis
gdavis's Avatar
Re: 1968
Here is list of things I orded.
Radiator core support, inter fender, inter rocker panel, floor pan section, lower rear pilar, dash pad (black), left and right door, door pin repair kit for two doors, left and right vent window, cab mounts and core support mounts with bolts and rubber bumpers kits for the entire truck. Benzle dash and circuit plate and lens.
I know when they come in I will be ordering some more things I forgot. But this will keep me busy for a while.
Old 01-27-2013, 02:13 AM   #416
Bomp
Bomp's Avatar
Re: 1968
Nice grill pieces.
Door handles are sweet too.
When they bring you those parts there will be two truck for that delivery???
Bomp is offline   Reply With Quote
Old 01-27-2013, 07:32 PM   #417
gdavis
gdavis's Avatar
Re: 1968
Yea, I think so. I am not going to let them deliver them. I am taking my neighbor 16 ft trailor down when he calls me that he has al my parts.
Here is another list of parts I am ordering from Classic parts.
wiring diagram.
grille moulding clips.
wheel studs.
spindle dusk caps.
brake hose front left and right.
brake hose rear.
gasket for the rear end cover.
Also I was on criags list last night and I going to buy a tilt colum for 60.00 and a gas tank for my truck. 98 model I know I will have to deal with figuring out the install but what a deal.
A friend has a 283 engine that has been rebuilt with less that 5000 miles on it. I am trying to talk him into selling it to me. But no luck at this point.
I will be needing it in the future on another build. I am going to make a 67 from the 72 frams. I have all the parts for the rolling chassis but a transmission and motor. anyway this is where I am at now.
Old 01-27-2013, 08:06 PM   #418
Xeen
Xeen's Avatar
Re: 1968
The Chevrolet Gen III Vortec 5300 series 5.3L engine, variants include LM7/L59/LM4/L33, produced from 1999-2007, combined with a 4L60E transmission would be a great choice for your truck, I'm putting one in mine.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 01-28-2013, 07:56 AM   #419
emilio impala
Re: 1968
Que lindas!! Yo las tengo que pedir desde acá. Tardan un poco en llegar a Argentina, son muy lindas!
Old 01-28-2013, 08:27 PM   #420
gdavis
gdavis's Avatar
Re: 1968
Yea, it wood be sweet with that engine. But my purse has a hole in it after the parts I ordered.
Old 01-28-2013, 08:29 PM   #421
gdavis
gdavis's Avatar
Re: 1968
say what? No obplay only english. My friend.
Old 01-28-2013, 08:34 PM   #422
gdavis
gdavis's Avatar
Re: 1968
Went on Craig List last night and found a 1967 chev short wheel base truck for 400.00 so I called and someone took a saw to the frame and took the front end off the truck. So all is left is the cab. So I offered 200.00 for the cac and door and fenders and he said ok. So Thursday I will go and pick it up. Also there was a short step bed on crags list for 300.00 he has two of them. But this month I have spend enough so Next month I will call and see.
Old 01-28-2013, 08:36 PM   #423
gdavis
gdavis's Avatar
Re: 1968
I also bought a distribtor, starter, water pump long shaft, fuel pump, 2 heads for a 350 all for 40.00. what a deal.couldn't pass that up. They look like new.
Old 01-28-2013, 09:04 PM   #424
Xeen
Xeen's Avatar
Re: 1968
I wonder what condition those short step beds are in, if one of them is in atleast good condition its worth way the heck more than he is asking.
Old 01-28-2013, 09:46 PM   #425
sduckworth13
Re: 1968
Handy spanish translator I found here on the internet.
That beautiful I have to order from here. They take a while to get to Argentina, they are very nice!
Scott
