Old 11-21-2013, 01:38 PM   #401
Rusbuilt
Rusbuilt's Avatar
Re: 1967 Mustang Coupe Build (Electra)
You did a great job Jeff!
Rusbuilt is offline   Reply With Quote
Old 11-21-2013, 02:25 PM   #402
JRANGER
JRANGER's Avatar
meh, the trunk and top dont look great but i figured out why. My gun was partially clogged...How i managed to get it this decent is beyond me....
I need to align the hood too..It is all off whack...Too close on the passnger side and too far away on the drivers side...It look like it needs the front driver side to just be pulled over a bit....
JRANGER is offline   Reply With Quote
Old 11-21-2013, 02:39 PM   #403
67ChevyRedneck
67ChevyRedneck's Avatar
By the time you get all the trim and stuff back on, it will look so cool you won't notice the little stuff.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-21-2013, 02:47 PM   #404
JRANGER
JRANGER's Avatar
Hahaha!! Yeah, that is true but this weekend im putting the stripes on!! Just adjusted the hood..That was easy...Loosen the screw on the passenger side and pull it up a 1/4" in... Nice and straight gaps now...All though the hood does quiet close flush on the passenger side
Old 11-21-2013, 07:08 PM   #405
JRANGER
JRANGER's Avatar
Got the driver fender attached to the pillar since the bolt was MIA....Got the hood adjusted finally after figuring out the last guy had put a patch there, regular bolts, and no lock washer...Wow, what a pain re-alligning but its much better now. Managed to put a small ding in the hood while aligning but should but able to push it back out. Couple small scratches on the door from god knows what...but is still pretty. I should learn to leave things be lol
Old 11-22-2013, 09:29 PM   #406
JRANGER
JRANGER's Avatar
paint the headlight door rings, turn signal bezels. and installed cowl to hood seal. Rainy day fun lol
Old 11-22-2013, 09:30 PM   #407
Rusbuilt
Rusbuilt's Avatar
Stuff looks good pimp
Old 11-22-2013, 09:31 PM   #408
JRANGER
JRANGER's Avatar
LOL!!!! Thanks Rus
Old 11-23-2013, 04:23 PM   #409
cubber
Impressive!
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 11-23-2013, 04:24 PM   #410
JRANGER
JRANGER's Avatar
Decided to put together a list of things I still want/Need for the project...So I dont forget
Headlight Relay Kit
Projector Headlights
New Driver side Remote Mirror
New thin trim mounting screws
New Popup Gas Cap
New Tailight Bezel Seals
New Lock Set (all)
New Reverse Light Set
Dash Pad
Seat Upholstry
Seat Foam
Package Tray
Carpet (Mass Back)
Sound Deadening
Brushed Aluminim Gauge Bezel
LED Dash Bulbs
3 Point Seat Belts
All Door Weatherstrips
Wheel Bearings (Atleast the passenger front)
Front Disc Conversion Kit
Rearend seal?? I think
Valve Cover Gaskets (Maybe new valve covers)
FUll Exhuast
New Stereo as the water finally killed the exisiting one
Door Sills
Shift Knob
TMI or MTF Center Console
Speaker Pod Kick Panels
Brushed Heater Insert
New Ignition Switch and Headlight switch Bezels
Wheel Well Trim (Maybe)
New Bushings for all the front end stuff
Bump Steer kit (Maybe not sure I need it)
New Emblems (All are tarnished and some broke)
New Window Trim...some are painted and dented atleast on the rear
New Hoses for the engine
Heater Box Rebuild kit (Works but is noisy)
Floor Mats
New Fuel Lines
Stuff to fix the parking brake
Fog Light Kit
Racing R Front Apron
GT Rear Valance
Old 11-23-2013, 04:27 PM   #411
cubber
I got some sound deadener at ABC supply. It's roofing stuff, but rubber-y and stick-y. Rus knows what it's called. I can't remember.
=MATTHEW
Old 11-23-2013, 05:02 PM   #412
JRANGER
JRANGER's Avatar
o yeah, Ill have to keep that in mind when i get to that point lol
Old 11-27-2013, 12:04 PM   #413
JRANGER
JRANGER's Avatar
cjponyparts got me today...Blackfriday sale came out and well the mass back carpet was on sale for $90 off....couldnt hold back Carpet on the way
Old 11-27-2013, 05:06 PM   #414
cubber
Good deal!
=MATTHEW
Old 11-28-2013, 01:50 PM   #415
Denee007
Denee007's Avatar
I was looking on your wish list or things to do list, and you want a 3 point seat harnesses. You want to do that before carpet installation and head liner. Obviously before the headliner. You'll have to weld a nut, or nut bar for the upper mount. I welded my lower bracket in as well as bolted it. I suppose carpet would be the last thing you want to install.
This is how I did the rear seat belts. Jury is still out on whether on not I like the hydraulic hood opener. You can just see my weld burns on either side of the bolt which holds the retractor in place. The plate which the retractor is bolted to is inside the wheel well.
The upper part installed, I worked on the headliner wrinkles using a steamer to shrink the headliner taking out most of those lines. The carpet hadn't been installed yet nor sound deadener.
This package tray is ok, the plastic is thick, I have sound deadner to reduce the vibration noise from the plastic. The built in speaker pods are very close to the glass, about 3/16" I'd say. If I wanted tint, it may be a bit difficult, but I could remove the package tray if I ever should want to do that. However, to remove the package tray is a pretty big deal. You can just make out the seat belt coming through the package tray.
This was on my photobucket~ I love the trilogy of Back to the Future!
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 11-28-2013, 05:22 PM   #416
JRANGER
JRANGER's Avatar
Thanks for the info! I bought the carpet but i wont be putting it in anytime soon. Just couldnt pass up the deal. I hope to get my seatbelts soon so i can install them...Thanks for all the pics and info!!! It will definitely be useful
Old 11-29-2013, 06:25 PM   #417
JRANGER
JRANGER's Avatar
Ripped out the headliner, wire wheel the roof, sprayed it with rust encapsulation, wire wheel the driver side floors and more and rust encapulation all over them.
Install the trim clips for the windshield even though i had two extra as the drivers side lower corner and passenger side top corner clip location is missing...hmmm
Cleaned the urethane off the windshield and put the new gasket on it and ran some 12 gauge wire to prep it for install..I may give that a go tomorrow. I have watched Mustangs To Fear video a million times and have all the sealant. I figured if i can get it in tomorrow i will then let it sit a day or so for the urethane install into the gasket
Old 11-29-2013, 07:22 PM   #418
Rusbuilt
Rusbuilt's Avatar
Looking good bro!
Old 11-29-2013, 07:26 PM   #419
Denee007
Denee007's Avatar
aren't you supposed to install your headliner before the front and rear glass? Mustangs to fear~ one piece headliner?
Old 11-29-2013, 07:27 PM   #420
JRANGER
JRANGER's Avatar
Yes if it was a stock like headliner but I will be using a one piece headliner that doesnt wrap around the pinch weld
Old 11-29-2013, 07:29 PM   #421
Denee007
Denee007's Avatar
I wish I had had that available when I did my mustang I saw one at a car show~ really nice!
Old 11-29-2013, 07:30 PM   #422
JRANGER
JRANGER's Avatar
Yeah, after removing the stock like headliner i was shocked...Also found out i had a dome light under the headliner...lol Wonder if it works
Old 11-30-2013, 06:37 PM   #423
JRANGER
JRANGER's Avatar
Windshield is in..... Was a royal pain in the ass.. I got beading compound everywhere including my hair. Some parts of the gasket tore and it took me all day.. However it is in, and it is sealed. I still have to put urethane on it against the glass but on the rear I may just put it in dry and them inject the beading compound after today. I had to use gas to wipe it off the glass and the car and now im worried that it may of messed up the paint but i cant tell as of right now...blah
Old 11-30-2013, 07:26 PM   #424
Denee007
Denee007's Avatar
You now have a new experience to share Next time you may want to place blue tape where you don't want adhesive/sealer/ or whatever the stuff is called, but it looks really good!
dne'
Old 11-30-2013, 09:05 PM   #425
Rusbuilt
Rusbuilt's Avatar
Good job Jeff!
