Closed Thread
Old 12-13-2011, 10:19 AM   #4376
hopped up
hopped up's Avatar
Re: What did you do to your truck today?
I drove my truckto work in the rain! Been driving it since fri, first time I've been able to do that since I got it. Feels really good ,just gotta get my brake lights working and I'll drive it everyday
hopped up is offline
Old 12-13-2011, 03:05 PM   #4377
Woogeroo
I ordered some parts... and checked the tracking number on some others.
yeah, hard morning for sure.
-W
Woogeroo is offline
Old 12-13-2011, 05:53 PM   #4378
Money Pit C-10's
I sat in mine and made big-block noises.
Money Pit C-10's is offline
Old 12-13-2011, 06:01 PM   #4379
markeb01
Senior Enthusiast
markeb01's Avatar
A popular past time for sure. Welcome to the forum!
markeb01 is offline
Old 12-13-2011, 07:44 PM   #4380
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Okay thats just funny......
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline
Old 12-13-2011, 07:47 PM   #4381
E911manager
Uhm with your mouth or something else??
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline
Old 12-13-2011, 10:13 PM   #4382
"El Jalapeno 66"
today i finish with all the engine work, engine start and runs great
"El Jalapeno 66" is offline
Old 12-14-2011, 09:48 AM   #4383
jbgroby
jbgroby's Avatar
Martha Stewart would NOT be happy, the Green does not co-ordinate with the udder color.
jbgroby is offline
Old 12-15-2011, 01:44 AM   #4384
"El Jalapeno 66"
Jajajaja i know, something different, thats why i named "el jalapeno"
Old 12-15-2011, 09:27 AM   #4385
jbgroby
jbgroby's Avatar
Spicy
jbgroby is offline
Old 12-15-2011, 07:11 PM   #4386
Money Pit C-10's
Smile Re: What did you do to your truck today?
Thanks Mark! And E911, you've taken something pure and made it...nasty! Anyway, for the last two days I've been clearing out the garage so I can work. I've got the 66 up on jackstands and the wheels are off. Guess I'll start by finishing the brakes. I converted it to 5-lug by swapping in a 12-bolt and front spindles and brakes from an 85 Suburban (for the thicker rotors). I have a brand new CPP brake booster/master cylinder/proportioning valve setup all installed. the factory Suburban drums are all rebulit and the brake lines are run from the rear up to the firewall. Also, the front calipers/pads/rotors are new and installed. I just need to drill the frame to run the rubber lines through (like the later C-10's) and finish up the hard lines. Then fill with fluid and bleed and we should have brakes, cause you know brakes are soooo important when your truck doesn't even run. So to recap, I've done absolutely nothing to my truck today.
Old 12-16-2011, 12:22 AM   #4387
E911manager
Snuck out and put the front end back on. Cut down the salvaged front frame clip to manageable pieces so I can mock up the front bumper mounts. Heading to get more metal tomorrow for a weekend of welding. Sorry if I offended anyone on my reply to Money Pit's post.
Old 12-16-2011, 12:46 AM   #4388
Money Pit C-10's
It's all good E911. I was just messin' with ya. But to be clear, I made the noises with my mouth. lol
Old 12-18-2011, 12:39 AM   #4389
E911manager
Tacked the front bumper mounts in place. My shop floor is a little uneven so I hope it is straight!!! LOL!!
Old 12-18-2011, 02:31 AM   #4390
Bardahl
Put a starter in my 68 Anni. edition
Bardahl is offline
Old 12-18-2011, 10:47 AM   #4391
Rayo
looked at it and got the hell out of the garage!
Rayo is offline
Old 12-18-2011, 06:04 PM   #4392
70inline6
Finally got the emergency brake cable (that had to be made) installed and my rear brakes back together. The rear end had been up on jack stands for over two months! lol. Now I can at least push it around the yard. I may even get it running next weekend.
70inline6 is offline
Old 12-18-2011, 06:38 PM   #4393
T2vigil
T2vigil's Avatar
I finally got started on the motor assembly. Ported the head, gasket match and reassembled. Crank in and torqued and got the pistons in and the rods torqued. Head on and torqued. Thats where it stopped. The crankshaft thrust plate was broke and I had to order another one but at least I got the majority done. This will be the last work for a while, I get my shoulder operated on wednesday. Nothing serious but it will put me out for about a month.
T2vigil is offline
Old 12-18-2011, 08:06 PM   #4394
markeb01
Senior Enthusiast
markeb01's Avatar
Good luck with the surgery.
markeb01 is offline
Old 12-18-2011, 08:13 PM   #4395
C4 Metal Werks
C4 Metal Werks's Avatar
I had an amplifier, dual dash speakers and kick panel speakers installed with a jack to plug my smart phone into so I can stream music while driving. Sounds great and the cables hide in the ashtray.
C4 Metal Werks is offline
Old 12-18-2011, 09:47 PM   #4396
T2vigil
T2vigil's Avatar
Thanks Mark. Just a few bone spurs a labrum tear and grinding out some arthritus. It has been hurting for a while and I have met my deductable and since all of my Santa apointments are done now is the time. Terry
T2vigil is offline
Old 12-18-2011, 10:10 PM   #4397
Martin64
Martin64's Avatar
After moving the mounts and changing the radiator from the stock original(almost 50 year old) 6 cyl radiator to the V-8 radiator last week, I changed radiators again because the one I bought last week leaked!
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline
Old 12-18-2011, 11:16 PM   #4398
E911manager
Front bumper mounts were completed along with the bed mounts and getting the Caprice tank placed..
Old 12-19-2011, 02:32 AM   #4399
66ChevyMax
66ChevyMax's Avatar
Got the front of the engine installed.
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline
Old 12-19-2011, 06:16 AM   #4400
glos55
glos55's Avatar
It's put away for the winter.
glos55 is offline
Closed Thread
