Closed Thread
Old 12-23-2011, 07:57 PM   #4426
Woogeroo
Re: What did you do to your truck today?
markeb01 - I took my truck around for a little shakedown run after all of this wiring and what not going on. It's a good thing too, as I noticed my blinkers weren't working. I had knocked the flasher loose in all of my rooting around.
-W
Woogeroo is offline
Old 12-23-2011, 08:02 PM   #4427
Bardahl
Talking Re: What did you do to your truck today?
Bought a 700r4 and dual exhaust for the 68 Chev
Bardahl is offline
Old 12-23-2011, 08:02 PM   #4428
markeb01
Senior Enthusiast
markeb01's Avatar
It's nice discovering those little bugs before being stuck in traffic or heading out on that 1,000 mile road trip!
-W
markeb01 is offline
Old 12-28-2011, 11:10 AM   #4429
E911manager
Finished up the gas tank mounts, grinding down some welds on the bed mounts, made new under the dash mounts for the caprice steering column, made a wire template for the steering and am now checking on options with Flaming River, Borgeson, and IDIDIT. Looks like Borgeson has the best solution for my set up.. Oh and tried a little dent removal on the bed and found out that body work is one thing that doesnt get better with age... I still suck..
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline
Old 12-28-2011, 02:58 PM   #4430
Stefan.
Stefan.'s Avatar
Today I overhaul the brakes
Stefan. is offline
Old 12-28-2011, 11:09 PM   #4431
towersddg9
towersddg9's Avatar
Had to pull the motor and tranny as I had an oil leak, it just got worse the more the motor ran, I was thinking rear main. Well the oil gallery plugs were all loose one fell out and the others just hand tight, I should have checked it, but thing is I supplied the macine shop with a complete new set, and had the works done on the block, its all done, and I will re stab tomorrow, I went ahead and changed out the center bolt covers for an early version
towersddg9 is offline
Old 12-29-2011, 02:05 AM   #4432
69burban
Garage Built Rides
69burban's Avatar
I was pretty exited about getting the heater working (there was no thermostat in it) but the blower motor for the fan was making the craziest noise. Replaced the fan motor today (22.00 from NAPA) that thing moves so much air now! it's awesome!
Albuquerque, New Mexico
65 long bed,
shaved drip rails, tail lights, tailgate, and molding. 350/700r4, dropped springs
69burban is offline
Old 12-30-2011, 06:07 PM   #4433
purzell
purzell's Avatar
Made my 66 long stepper run and drive! New/used Holley 4412 is on, new/used Holley air cleaner, set timing and drove it up the street for the first time. Needs brake job and some asshat stole the car cover off of it last night. But it runs and drives! Happy new year!
purzell is offline
Old 12-30-2011, 06:30 PM   #4434
65Gregg
65Gregg's Avatar
Towesddg9 what did you use to change your centerbolt covers to perimeter style? Adaptors that bolt to the center bolt holes?
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 12-30-2011, 08:56 PM   #4435
chainsaw
chainsaw's Avatar
Still block sanding. This should be my last time, now have to wait for warmer weather to see if I can get some color on it.
chainsaw is offline
Old 12-30-2011, 09:38 PM   #4436
MisterC
MisterC's Avatar
I installed my repaired radiator with all of the accessories. Additionally, I installed my new parklamp/turn signal wiring harness under the hood.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline
Old 12-30-2011, 10:35 PM   #4437
XtechX
XtechX's Avatar
I went to a local saw mill and picked up 10 3/4" white oak boards for my bed floor for $120 bucks. They were all planed and trued up and ready to cut to size. I cut them to spec according gmcpauls write up, or as close as I could. Now I have to cut the grooves etc in them. I made some practice cuts on some scrap, using just a regular combination blade, anyone else just use a regular blade to cut the grooves? Did you go the full 1/4" wide?
Opportunity usually comes disguised....As hard work!!!
XtechX is offline
Old 12-31-2011, 04:41 AM   #4438
C4 Metal Werks
C4 Metal Werks's Avatar
I little bling today.
Low & Slow
C4 Metal Werks is offline
Old 12-31-2011, 02:23 PM   #4439
Vernski
The 1/4" allows for expansion an contraction...Vernski
Vernski is offline
Old 12-31-2011, 08:41 PM   #4440
Bardahl
Bought another 68 GMC long fleet , I`m sick or have another hole in my head, I don`t feel sick??, I must just have another hole in my head !!
Bardahl is offline
Old 12-31-2011, 09:48 PM   #4441
sigshooter
sigshooter's Avatar
Today I pulled it out of the weeds, aired up the tires, and noticed some @$$hole got in my truck and cut off the pigtail and plug off my dimmer switch!
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline
Old 12-31-2011, 10:31 PM   #4442
iceship
got my wires ready.. so my seats will have power and heat...
iceship is offline
Old 12-31-2011, 10:38 PM   #4443
iceship
From this
To this
Had to get the bcm for heated seat to work...
iceship is offline
Old 12-31-2011, 11:31 PM   #4444
markeb01
Senior Enthusiast
markeb01's Avatar
Sorry you were victimized. Another reason why I generally like dogs more than people.
markeb01 is offline
Old 12-31-2011, 11:37 PM   #4445
csa daddy
csa daddy's Avatar
Pulled my 64 in the garage today an started ripping frontend apart for 5 lug conversion an new bushings an ball joints an airbags
csa daddy is offline
Old 01-01-2012, 12:23 AM   #4446
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Got my seats installed.
Alan's Classic is offline
Old 01-01-2012, 12:41 AM   #4447
padresag
they look real good in there , Alan
ron
padresag is offline
Old 01-01-2012, 12:42 AM   #4448
padresag
I hope that they are dry
ron
padresag is offline
Old 01-01-2012, 12:47 AM   #4449
juanz1947
rusty 66
juanz1947's Avatar
fulled up the gas tank with 50 bucks at 3.49 a gallon lol and it only last me 3 day gone to work and back like 74 miles round trip so it like 222 miles for a full tank is that normal for a stright 6 250 motor
1947 chevy fleetmaster
http://www.cbforum.net/forum/
1966 chevy c10 long bed
http://67-72chevytrucks.com/vboard/s...d.php?t=439219
1970 chevy impala custom
http://www.layitlow.com/forums/index...pic=349867&hl=
juanz1947 is offline
Old 01-01-2012, 12:50 AM   #4450
sigshooter
sigshooter's Avatar
I like that way of thinking.... you would think with a nickname like Sig Shooter people would think twice before stealing from a red blooded, gun packing, redneck from the south!
1966 Short stepside
1964 long bed
Closed Thread
