01-01-2012, 01:14 AM | #4451 |
Re: What did you do to your truck today?
Yes, nice and dry. I thought it was a real reasonable deal on the wood. I cut all the grooves etc in them today. They turned out very nice, but I didn't go the full 1/4 inch wide for the grooves (about 3/16").
Opportunity usually comes disguised....As hard work!!! |
01-01-2012, 02:13 AM | #4452 | |
01-01-2012, 05:17 PM | #4453 |
01-01-2012, 06:06 PM | #4454 |
Not what I have done but more what needs to be done, replace heater core, it blew out Thursday morning on the way to work, its from radiator exspress, ( 55 plus tax vs 79 plus tax thru LMC ) they are the cold glue type, lasted eight years, not sure I want to go the glued route again. Mann it sured fogged up the interior in a hurry, could`ntt see anything at 4:00 am in the morning when the outside temp was 28 degees, had to open both windows to clear out....it was cold. Does anybody know if LMC`s are soldered or glued.....?
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
01-01-2012, 06:40 PM | #4455 |
Put 3" drop rear coils and shocks and also got my rear light harness put in and my lights put back together.
01-01-2012, 07:53 PM | #4456 |
put the engine in my truck today
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
01-01-2012, 08:03 PM | #4457 |
NOTHING!New years day cleaning and taking apart cribs and moving furniture so my girlfriends sister could move out so much FUN. Could you sense my sarcasm!
Posted via Mobile Device |
01-01-2012, 08:51 PM | #4458 |
I went to bleed my brakes today and ended up with another blown brake line. Right rear portion just before the rubber brake hose. Pretty sure the rubber hose has collapsed so I ordered a new one from Ecklers.
'66 C10 250 3-on-the-tree '68 Galaxie 460/C6 '74 914 2.0 |
01-01-2012, 09:52 PM | #4459 |
put in a different wheel
01-01-2012, 10:17 PM | #4460 |
Got my new speakers mounted!! 6x9s baby!!
01-02-2012, 12:10 AM | #4461 |
Console back to black
Could use new chrome trim but it's good for now.. Posted via Mobile Device |
01-02-2012, 01:54 AM | #4462 |
Senior Enthusiast
01-02-2012, 08:53 AM | #4463 |
thanx man... ive had the engine bay envisioned in my head forever.. im glad i finally got to see what its really gonna look like.. im gonna keep it as minimal as possible.. manual steering, manual brakes, a push electric fan on front of radiator, hide the wireing and brakelines .. eventually gonna replace all the bolts in the engine bay and on the motor with nice stainless ones to
01-02-2012, 12:13 PM | #4464 |
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Pro street truck is at the body shop so between my visits and work there....
I pulled my next project out of storage and put it into the front of the shop...Powder coated frame rolling chassis....washed it all up and looking it over to decide what changes i want to make...
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
01-02-2012, 05:10 PM | #4465 |
Put front chopped crossmember in truck an air bags
01-02-2012, 08:36 PM | #4466 |
Csa, how did you "chop"your crossmember ? Does it move forward to center your front wheels in the wheelwell ?
01-02-2012, 09:34 PM | #4467 |
Desert Dweller
I filled in my dash for A/C controls and vents. Also installed my rubber bed mat...
Before; After; Bed mat; . |
01-02-2012, 09:43 PM | #4468 |
Today replaced the driverside bed panel. I picked up a shortbed about a month ago for $100. Well traded it for a 292 that I paid 100 for. Now need to decide on one piece of high quality plywood or a bed kit. Also got a gilmer drive kit. Need to find a different alt bracket for it to work.
01-02-2012, 10:47 PM | #4469 |
Started to remove the front end, to get ready to sand blast and then take in to the powder coater!! Smashed my hand with a hammer (not the smartest thing Ive done) so I thought I would call it a day
1962 Chevrolet S/B Fleet side Engine: 283 Transmission: 3 speed manual 2 do list !!!!!! Frame off-2 1/2" front , 4" rear Rebuild engine (or find a 327), 700R4 Trans, relocate gas tank, Bed wood |
01-02-2012, 10:52 PM | #4470 |
Redneck Hillbilly
Washed the windows, filled her with gas, and kept on driving. Still loving driving her!
01-02-2012, 11:12 PM | #4471 |
Nothing on the truck but related. I picked up the gas cylinder for my new mig welder and began the learning process. I can't believe it took me 45 years to do this. I had a lot of fun, managed to get a half decent bead by the time I quit, and I didn't burn down the garage or burn or electrocute myself. It was a good day!!
01-02-2012, 11:27 PM | #4472 |
01-02-2012, 11:37 PM | #4473 |
Well not just today for over the last 2 "truck" days... Two coats of POR15 on the frame after cleaning it up with a pressure washer and wire brush and wire wheel. I also worked on the firewall. More pics on my build page...
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice http://67-72chevytrucks.com/vboard/s...d.php?t=492640 |
01-03-2012, 12:27 AM | #4474 |
Falk!! I typed two long posts and fat fingered them into the ether-sphere.
01-04-2012, 08:38 AM | #4475 |
Console not bolted down yet... have to wire the heated function going to mount under console.... Posted via Mobile Device |
