Old 07-19-2009, 04:17 PM   #426
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: project INCREDIBLE HULK 6.2L with 6L80E
nice work Don!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 07-19-2009, 09:07 PM   #427
71Hulk
Don, no hurry and whenever possible would you mind taking a picture from directly behind the bed with the tail gate down. I just wanna an idea (view) of how fat the tubs are. thanks! Gr8 work!!!
71Hulk is offline   Reply With Quote
Old 07-20-2009, 09:20 AM   #428
72 SHORTBED 7.0
72 SHORTBED 7.0's Avatar
You must Eat Sleep Dream about how to do some of these trucks good work .D
72 SHORTBED 7.0 is offline   Reply With Quote
Old 07-20-2009, 11:08 AM   #429
Tagg33
Tagg33's Avatar
Nice work on the wheel tubs, welding up the seam and rounding the corners really finished it off nice.
Ryan
84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s
My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328
Tagg33 is offline   Reply With Quote
Old 07-24-2009, 03:47 PM   #430
68 Quad C10
68 Quad C10's Avatar
great build so far love what you have done, ???? for you are you going to remove the factory climb of the roof on the cab?
http://www.tandscustomcars.com/
My Quad Cab build:http://67-72chevytrucks.com/vboard/s...d.php?t=352342
IT"S GOT A ROOF NOW WHOO HOO!!!!
65 GTO Build (If you wanna check it out) http://67-72chevytrucks.com/vboard/s...40#post4503040
68 Quad C10 is offline   Reply With Quote
Old 07-29-2009, 01:05 PM   #431
ChevyChad
Looks even better in person! the pics just dont do it justice!
ChevyChad is offline   Reply With Quote
Old 07-29-2009, 03:02 PM   #432
my67chevytruck
Under Construction
Any updates Don?
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 09-22-2009, 10:07 PM   #433
68 short step
ok im back with some updates... my camara broke awhile back and i just now got another camara...so here is what im working on now....
we got some bear claw style latches for the door, and i smoothed the door and door pillar....installed the latches and the striker bolt... it looks and functions 100 times better then stock form.....also got some power windows....
68 short step is offline   Reply With Quote
Old 09-22-2009, 10:09 PM   #434
atp
I'm Jealous!
atp is offline   Reply With Quote
Old 09-22-2009, 10:11 PM   #435
Painter D
Painter D's Avatar
Lookin good.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 09-22-2009, 10:35 PM   #436
VA72C10
VA72C10
VA72C10's Avatar
Looks good...any pictures of the inside of the door so I can see what you did with that round hump that runs around the outside of the door? Thanks. Are those powered bear claws? And have you tested them with glass in the door (additional weight)? Are you running an additional manual popper anywhere (I was told I needed to)?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-23-2009, 08:12 AM   #437
my67chevytruck
Under Construction
Looking good Don!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 09-23-2009, 07:14 PM   #438
68 short step
i can get pics of the inside for ya....yes they are power latches....yes, i did install the glass, for fitment/position of the latches and solinoid... i dont plan on useing any popers, i think the door seals will do that job fine...
Old 09-23-2009, 09:05 PM   #439
VA72C10
VA72C10
VA72C10's Avatar
Thanks for the info...looking forward to the pictures. I am going to use the newer press in style weatherstrip so I'm not sure if that will be looser or tighter than normal weatherstrip so I have a set of poppers just in case they don't open enough.
If you end up needing a set of poppers I got two accidentally so let me know and I'll sell them to you for what I paid. THey're nice aluminum adjustable ones (non-power)
Old 09-23-2009, 09:27 PM   #440
mcbassin
Still Learning
mcbassin's Avatar
CRAZY SKILLS! I finally got through the whole thread. Its just amazing how far you have came from start to now. I know you have a ton of hours on this ride......any clue how much $$$ are tied up in it? That power plant alone must have cost some bucks! Keep it up fellow Okie.
mcbassin is offline   Reply With Quote
Old 10-04-2009, 09:20 AM   #441
68 short step
time for a little update, the rear suspension had to be removed, because we're going with a diffrent set-up, one that matches the front...so the new ECE trailing arms, and xmember were removed and sold..also here are the pics of the inside door latch as requested (hope this helps).....
Old 10-04-2009, 10:05 AM   #442
nuke1
nuke1's Avatar
Don, the truck is starting to come along good, really like the bear claw latches, that is something that i am gonnna do to mine yet, are you shaving the handles and locks also, what kind of solenoids are you using to release the latches? THANKS James
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 10-04-2009, 11:00 AM   #443
72 SHORTBED 7.0
Skills you do have, nice work...
Old 10-04-2009, 01:59 PM   #444
kev2809
low n' slo
kev2809's Avatar
damn, how the hell did i miss this build. great project man, truck looks good!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 10-04-2009, 06:29 PM   #445
jasonhall
jasonhall's Avatar
Where at in tulsa are you picking up these fine motors?
jasonhall is offline   Reply With Quote
Old 10-17-2009, 03:38 PM   #446
68 short step
while the rear suspension is all apart, i took the opertunity to weld on a drain and fill port on the rear end....this has to be one (of many) dumb things ford did, make the 9" so that you must remove the wheels, brakes, axles, and thirdmember, just to change the rear end fluid...that is just dumb planning IMO...
Old 10-17-2009, 04:16 PM   #447
msgross
msgross's Avatar
don't hit anything with that drain while driving, that would leave a mess... are you gonna put a guard on it?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-17-2009, 05:16 PM   #448
68 short step
i dont think that'll be a problem.... ill have to see what its gonna look like with the new suspension, but im sure it'll be fine. if not ill make it flush
Old 10-17-2009, 11:48 PM   #449
tdave00
Restoring a 68 SWB
tdave00's Avatar
Are you going with a 4 link on the rear now?
tdave00 is offline   Reply With Quote
Old 10-18-2009, 12:18 AM   #450
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
from the brackets he has on it im assuming hes using trailing arms
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
