01-15-2012, 12:08 AM | #1 |
Still Learning
Re: '72 Chevy SWB, Project Driver
Nice machine work Ben. You're gonna have to give me Cliff notes version of how this helps performance? I really don't understand suspension.
01-17-2012, 10:07 AM | #2 | |
Has more rust than truck...
Moving the LCA forward causes the top of the spindle to tilt backwards so when you turn the wheels the tire will tilt. This tilt when in a turn forces the outside edge of the inside tire and the inside edge of the outside tire into the ground for better traction and also compensates for body roll. Thats my understanding at least. Tires are here, props to Tirebuyer.com cheaper than any local place by over $50 a tire and fast free shipping. Now to get them on. |
01-17-2012, 12:29 PM | #3 |
Still Learning
Oh yeah! Love the new tires. Late Christmas present eh? Those are gonna look great on there. Mount them up.
01-17-2012, 04:11 PM | #4 |
Ya didn't want to run a shorter sidewall than 60 series? I like 50 series. Stiffens up the tires without making the ride too stiff, like 40 series.
01-18-2012, 02:24 AM | #5 |
I digg those Indy 500's. I run them on my 'Burb. The 255 seems like a good all around width.
01-18-2012, 06:30 PM | #6 | |
Mike, You could say that, hopefully mounted tonight!
Thanks, Hope I like them. |
01-24-2012, 08:55 AM | #7 |
Little late of an update, but tires are on and its back from the alignment shop. The drivers side worked out great 5.6deg of caster, but on the passengers side they were only able to get 0.4deg. So now I'll be taking the truck to another shop that has a frame rack, hopefully they can figure out what is going on.
01-24-2012, 05:27 PM | #8 | |
Still plays with trucks
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
01-25-2012, 01:16 AM | #9 |
Still Learning
New meats look great Ben. I actually like some side wall on my tires. I think they look tough too. Hope you get the alignment figured out.
01-25-2012, 07:33 AM | #10 |
Very impressed. That Roland sure is a good friend. That other cab was a gonner. Keep pics coming. Going to be a nice driver when done.
Here is mine. http://www.flickr.com/photos/waltspr...7628925019747/
I know I can! I know i can! 72 K20 Restoration |
01-25-2012, 10:34 PM | #11 |
awesome build man!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
01-26-2012, 12:22 AM | #12 |
Your truck is looking great, it's come a long way! Hope you get your alignment issues worked out.
Wade , JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!! , Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570 Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro |
01-26-2012, 11:01 AM | #13 | |||
Thanks! Quote:
I hope so too. I took it to the frame shop yesterday and they said its the frame, but should be no problem to fix. They're having me pull the inner fenders out and then drop it off on Monday. |
02-05-2012, 05:18 PM | #14 |
Eat, Sleep, Drive a Chevy
Did you get the truck back to the frame shop yet?
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
02-06-2012, 10:45 PM | #15 |
Just drove her home, drives awesome........ but still only 3.5 deg of caster. I think my alignment instructions never made it to the alignment tech because there are plenty of shims in all 4 locations. I'm still happy, it drives perfectly straight at 70mph and doesn't fight me in a turn anymore. That and it was only $298 to have the frame straightened and the truck aligned, I think that was a very fair price for this area.
02-07-2012, 12:29 AM | #16 | |
Still Learning
02-08-2012, 06:00 AM | #17 |
Glad they were able to straighten it out for you.
That is a very good price for the job. It was $400 to do the same thing for me on my Chevelle 15 years ago up here.
02-09-2012, 12:14 AM | #18 | ||
Other updates, destroyed my air filter by driving the truck to and from the shop with no inner fenders. I guess I should have thrown a zip-tie on it to keep it from bouncing and rubbing on the tire, oops. Also installed the correct lugnuts on the truck. The rims I have use shank type lugs 1" long with a .74" diameter, the ones I originally used were 1" long with .6x diameter(didn't know they made different diameters). This was enough of a difference to let the wheel get off center and cause slight bouncing and vibration. Much better now, hopefully someone learns from my mistakes |
03-01-2012, 09:45 PM | #19 |
What ratio are you using and what king mileage are you getting. Very nice truck.
2001 GMC 2WD, 1998 Chevy K2500 |
03-02-2012, 02:22 PM | #20 | |
I did a little bit last weekend. Painted the rear brake drums and installed the correct lug nuts on the rear. My son decided to help |
03-02-2012, 03:22 PM | #21 |
He did a good job!!!!
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
03-02-2012, 11:27 PM | #22 |
Those are the kind of pictures he will treasure when he grows up.
I love when my daughter "helps" me out.
03-03-2012, 12:15 AM | #23 |
Still Learning
Cool pictures Ben. Glad to see you have junior out in the shop at a young age.
03-25-2012, 03:10 AM | #24 |
Very impressed with the depth and breadth of all you have done. No fanfare, just one cool functional modification after another.
On a more practical level for me, could you tell me what model / year Freightliner your seats came from? They look like a good solution for me. Thanks. Good luck working forward. |
03-26-2012, 11:03 AM | #25 |
Thanks everyone! Took a bit of a trip yesterday, Odometer hit 1000 miles and got 20.2mpg highway
peterbuilt, Thanks, I have no idea what truck the seats came out of. They are pretty comfy, but they are gone when I find a nice bench. That way the entire family can ride with. |
