06-25-2012, 08:32 AM | #426 |
Re: 68 aka "Chained in Porterbuilt Prison"
this is a awesome build cant wait to see more of it
06-25-2012, 09:42 AM | #427 |
Master Procrastinator
WOW!!! great work
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
06-25-2012, 12:25 PM | #428 |
CCTek
Looks great Jim. Our doors are original and don't fit near that well. Keep me posted on the one piece glass details. We want to do it, but I keep getting mixed feedback. They all look great up or down, but that is the issue. How hard is it to get them up and down? I'm sure you will make it work and look good. Keep up the excellent work! We should be mounting front sheet metal soon!
Chad 68 swb Project http://67-72chevytrucks.com/vboard/s...d.php?t=262840 72 swb Project SOLD http://67-72chevytrucks.com/vboard/s...=1#post3993641 THANKS TO: Hermance Design (www.hermancedesign.com), Paradise Road Rod & Custom, Harry Opfer Welding, Tri-State Machine, Wegner Automotive Research, Nsane Hotrodz (www.nsanehotrodz.com), Clayton Machine Works, CCTek (http://www.candctek.com) |
06-25-2012, 09:38 PM | #429 | |
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
06-27-2012, 09:14 PM | #430 |
Finished up bear claw in cab jamb......man it was worth getting some jamb pieces from another board member...that metal would have been tough to make that rolled bend..pics of before (of pass side still to go) and now....and replacement panel for pass.side....fairly easy install and door closes NICE.......Slosh Tubz tomorrow....oh boy.....I feel someone grinning....lol....jim
06-27-2012, 09:30 PM | #431 |
67cheby
Clean !
Posted via Mobile Device |
06-27-2012, 09:33 PM | #432 |
CCTek
Nice work! We went opposite for the same reason you mentioned about the windows. The claw is in the cab and the pin is in the door on ours. There's pics in my thread. That's why I love this stuff! 100 ways to skin the cat! Keep those pics coming!
06-27-2012, 09:36 PM | #433 |
And that's why I'm not doin pass door until windows get here this week and I get dr. side installed..claw will stay and I think will clear but we'll see..I want the ring brothers handles so needed release to be in door...I'll be back.......jim
06-27-2012, 09:40 PM | #434 |
Oh by the way...if U haven't tried the push-on weatherstrips...your missin it.....when your fitting a door like I am they are PRICELESS...on and off in a flash...Will never use anything else.......Gmc Paul are U smilin...lol.......jim
06-27-2012, 09:49 PM | #435 |
CCTek
Thanks for the tip! Will be looking at those soon!
06-27-2012, 11:18 PM | #436 |
Hey Jim, nice work on the doors....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
06-28-2012, 10:51 AM | #437 |
67cheby
it's Tomorrow now ! just sayin
06-28-2012, 08:44 PM | #438 |
Wait.....what is this.............
06-28-2012, 08:47 PM | #439 |
Oh ...maybe this .........thanx Mike .....they look great..only got this one in...Date Nite...gotta go......I'll let u guess what the last 2 pics are....been holdin out.....jim
06-28-2012, 09:05 PM | #440 |
PROJECT 7DEUCE
Love dimples..........
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-29-2012, 01:36 AM | #441 | |
The tub looks great! Maybe after the date you can talk her into helping with the other one.
71 Ol' Blue: http://67-72chevytrucks.com/vboard/s...d.php?t=474752 Carving the Jake-olantern: http://67-72chevytrucks.com/vboard/s...d.php?t=679537 |
06-29-2012, 01:42 AM | #442 |
the ones from gmc pauls but others sell them...jim
06-29-2012, 11:51 AM | #443 |
67cheby
Oh ya baby !!
07-08-2012, 08:28 PM | #444 |
Well a little progress...Had to modify p.b. hood hinges since I welded up wire channel.....little tweakin'...and boy do I like um'.....Only thing is hood open height but man they open and close perfect...the mods were on the outer bracket...had to cut the bracket off at bottom so ended up a 2 piece bracket.....but still works well..........jim
07-08-2012, 11:24 PM | #445 |
67cheby
Beautiful.....what hinges??? All I could see was Slosh Tubz !!
07-08-2012, 11:58 PM | #446 |
Sounds like a proud papa. Hinges look good...Jim
07-09-2012, 10:33 AM | #447 |
Since U brought that up...having a rub problem on pass. side where hood "fold" is ...need to pull front of tubz away from fender 1/4"...may have to slot a hole or 2....OUCH there goes your reputation.....lol......but then again it is an aftermarket hood!!!........jim
07-09-2012, 10:41 AM | #448 |
67cheby
dang aftermarket hoods.....LOL, my go to statement in this case is they fit pretty darn good for aftermarket parts...LOL, they fit better than most of the metal aftermarket inners i have installed !!
07-09-2012, 09:19 PM | #449 |
In fact way better than hood in pics...I am going to switch mounting plates to original hood as we speak....thought I would try new hood with out all the cleanup work....but way more work to make this new one fit....1 step forward..2 back...lol...jim
07-16-2012, 10:23 PM | #450 |
Little progress in the paneling process up front..slow..tedious ...but worth it in the end...having to plan for hoses..wiring ..etc...as U go......pita!!.....
1st pic of stock "pooch" of fender on dr. side..moded pass. side before welding...then a 3/16" rod welded to core to form cover or lip for panels..little trick I learned years ago...able to put fender side panel under stock "lip"...this is a mock up waiting for dimple dies to arrive!! I'm going to order the grill top enclosure ..but I've always not liked the top of it having edge exposed...will do the 3/16" rod trick on grill side too in order to clean that up...lots of work... by the way that pass. side fender panel will have another 4 spot bulkhead fitting installed .....to connect from the one under the pass. end of firewall...hoses routed over Slosh Tubz (another head swell for Mike..lol) inside fender...I know..lots of connections but U can install these before Tubz and forget em....later jim
