Old 11-05-2015, 12:32 AM   #426
66ChevyMax
66ChevyMax's Avatar
Re: Mesquite 1966 C10 - LS3 W/Air Ride
Got the bed back on today:
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 11-05-2015, 12:33 AM   #427
66ChevyMax
66ChevyMax's Avatar
On the Bump Stops:
Ride Height:
Craig
Old 11-05-2015, 12:35 AM   #428
66ChevyMax
66ChevyMax's Avatar
Thanks Dwight, it's time to finish this puppy, I can smell the finish line!
Originally Posted by tune_1 View Post
Looking good, glad to see the work that you have done.
Dwight
Craig
Old 11-05-2015, 11:03 AM   #429
66ChevyMax
66ChevyMax's Avatar
OK have a engine question for you LS Tuners:
Went for another test drive everything was great and the only thing that was different is I hooked the alternator up to the battery, volts showed to be close to 15 which I thought was high but the truck ran fine. Drove it about 4 miles, parked it in the driveway to show to my neighbor. Started it about 15 min. later it ran for about 10 sec then sputtered and died. When I tried to restart it had a knocking sound so I pushed it back into the shop.
I was not in the mood so I let it sit a day and turned the motor over without power to the ECM, had oil pressure, turned over just fine, no noises. Hooked everything back up, she turns over great no noises but will not start, does not even attempt to fire.
I have a pressure gauge on the fuel line so I have fuel.
Any ideas would be greatly appreciated.
Craig
Old 11-05-2015, 11:42 AM   #430
Hart_Rod
Hart_Rod's Avatar
What fuel pressure are you getting at the rail?
Hart_Rod is offline   Reply With Quote
Old 11-05-2015, 11:52 AM   #431
66ChevyMax
66ChevyMax's Avatar
60-65lbs
Craig
Old 11-05-2015, 11:58 AM   #432
Hart_Rod
Hart_Rod's Avatar
Originally Posted by 66ChevyMax View Post
60-65lbs
Have you scanned it? Are you throwing any codes?
Old 11-05-2015, 12:00 PM   #433
66ChevyMax
66ChevyMax's Avatar
I have not scanned, I would like a recommendation on a scanner as I will obviously need one in the future and NOW!
Thanks,
Craig
Old 11-05-2015, 12:28 PM   #434
Hart_Rod
Hart_Rod's Avatar
Thanks,
I would recommend buying HPTuners Pro (or EFIlive). It costs more money, but it gives you the tools to work on your tune.
Old 11-05-2015, 10:41 PM   #435
66ChevyMax
66ChevyMax's Avatar
Ok found the problem, I strapped the fuse box to the inner fender for the first time since I had the hood on. I didn't put the cover on the fuse box so the strap went across the ignition relay and all the vibration wiggled it loose. Removed strap pushed ignition relay back in and she fired right up.
Craig
Old 11-05-2015, 10:45 PM   #436
66ChevyMax
66ChevyMax's Avatar
One more Pic:
Craig
Old 11-06-2015, 12:05 AM   #437
rondog4416
rondog4416's Avatar
your doing a awesome job !!I just read your whole build and man you have some mad skills !! looking forward to seeing it in paint soon !!
rondog4416 is offline   Reply With Quote
Old 11-06-2015, 06:32 PM   #438
66ChevyMax
66ChevyMax's Avatar
Thank you sir, don't know what I would have done without help from those here.
Craig
Old 11-07-2015, 10:27 PM   #439
Bugeyev8
Bugeyev8's Avatar
awesome truck !
Bugeyev8 is offline   Reply With Quote
Old 11-08-2015, 01:42 AM   #440
66ChevyMax
66ChevyMax's Avatar
Thank you sir!
Originally Posted by Bugeyev8 View Post
awesome truck !
Craig
Old 11-08-2015, 01:45 AM   #441
66ChevyMax
66ChevyMax's Avatar
Switching over to Hydroboost, other set up was just too soft!
Craig
Old 11-09-2015, 12:29 AM   #442
66ChevyMax
66ChevyMax's Avatar
Took a long test drive today, man this thing needs a windshield
Brakes work much better with hydroboost.
Craig
Old 11-09-2015, 03:18 PM   #443
66ChevyMax
66ChevyMax's Avatar
I've got a paint question for you, I will be sending the truck parts out for blasting soon. Should I also send the new panels and have the coating removed?
I have read how great this stuff is and, how it sucks! My feeling are get it all back to metal so the paint is on the same base for the entire truck.
Thanks,
Craig
Old 11-09-2015, 07:03 PM   #444
dwcardfan
dwcardfan's Avatar
Well I am not a professional painter but I have a friend that is and he helped me with what paint and primers to use and so on. He told me to scuff it and primer it. If you don't primer it the black will change the color a bit. That is if you are using a gray primer or light colored primer. And your build is looking good.
dwcardfan is offline   Reply With Quote
Old 11-10-2015, 10:17 AM   #445
66ChevyMax
66ChevyMax's Avatar
Thanks for the advise.
Craig
Old 11-11-2015, 11:39 AM   #446
66ChevyMax
66ChevyMax's Avatar
Want to give a shout out and say thanks to all the veterans here and to my Father in law, Vietnam USMC
Craig
Old 11-14-2015, 08:38 PM   #447
66ChevyMax
66ChevyMax's Avatar
Going to try to use this canister for radiator overflow.
Craig
Old 11-14-2015, 08:40 PM   #448
66ChevyMax
66ChevyMax's Avatar
Painted some samples today, will use the 2nd from left Sunburst Orange:
Craig
Old 11-14-2015, 09:03 PM   #449
likaroc13
Rollin' Old Skool
I like that color. Kinda reminds me of the one Ronnie "198plus" had on his old truck.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 11-14-2015, 09:49 PM   #450
dwcardfan
dwcardfan's Avatar
Looks good. That orange is gonna pop!
