Old 12-07-2015, 07:41 PM   #426
RodsGreen10
RodsGreen10's Avatar
Re: 1976 Square "Simple Green"
Well ran into a issue with the an fittings going on the FiTech EFI. I want to run my fuel line and return line like it would be on a carb. Meaning enter and exit on the passenger side. So with a 45 or a 90 an fitting it was hitting my drop base on my air cleaner. I have a 1.25 drop base. So the only way this would work would be put the inlet fuel on the front or rear drivers side of the FiTech and angle the fitting towards the middle you would have to do the same to the return on the passenger side as well. Well I did not want to run the fuel line across the front of the FiTech or run the return line and put a bend in the line to run it back to the passenger side or run the return all the way around to the drivers side then around the front so it would make it back to my tank on the passenger side. So I just order another base and a 3" filter. So this is something you all might need to know. If using a drop base and give a crap about a clean install. I will not put a 90 degree fitting unless I absolutely must. 45 is better for fuel flow. So what I have left is the tank and waiting on the base. Got the 2 fan wires hooked up the ac wire hooked up and the o2 sensor installed.
RodsGreen10 is offline   Reply With Quote
Old 12-07-2015, 08:09 PM   #427
RodsGreen10
If this is confusing let me know I will gets pics so you have a visual.
Or I could put a .5 spacer on the carb flange under the base but I can't do that cause the air clear kid will be hitting the hood. So for me I had to order a new base and filter. The pleasure of running a tall single plane intake and a 1" carb spacer. The new base and a shorter filter should make it work out just how I want it. If not well I will be angleing my an fitting towards the middle.
Old 12-07-2015, 08:41 PM   #428
RodsGreen10
But I may be over reacting cause I am tired and my back is killing me from being humped over in the engine bay for 2 days lmao. Gotta love getting older.
Old 12-08-2015, 06:41 AM   #429
RodsGreen10
It will work with a drop base if you angle the fitting towards the middles of the FiTech. That's not what I wanted to do so I will see if this new base and filter will fit under the hood if so I will do as planned if not I will angle fittings towards middle. Besides that the FiTech is straight forward install nice setup. Nice harnesses covered in nice braided loom nice connectors.
Old 12-08-2015, 01:23 PM   #430
RodsGreen10
Found another place that has the GM weather pack clips. I don't know which one will work but I will find out. I think this should be included with the FiTech for mounting the harnesses. Better than zip ties.
http://www.hipoparts.com/products/Mo...onnectors.html
Old 12-08-2015, 01:26 PM   #431
tjsblazer
tjsblazer's Avatar
Are you going to use the unit to control timing or run it in fuel only mode.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 12-08-2015, 01:41 PM   #432
RodsGreen10
As of now no I am not going to let the FiTech control it. But I am goin to try both ways and see which way I like the best. But it is a kick ass feature. That I will try. No other efi system offers this. Which is a great feature.
Old 12-08-2015, 01:45 PM   #433
RodsGreen10
You know what I am just going to wire it so the FiTech controls it all hell nothing to change a wire around.
Old 12-08-2015, 01:49 PM   #434
tjsblazer
tjsblazer's Avatar
Just seems like a great feature. Easy as hell to make timing changes instead of removing the cap and switching some springs and weights although once it is dialed in you wouldn't likely touch it again.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 12-08-2015, 01:52 PM   #435
RodsGreen10
I agree.
Old 12-08-2015, 02:38 PM   #436
68Timber
I know the pieces fit
68Timber's Avatar
What all do you need to let it control timing? I'm very interested in their kit.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-08-2015, 02:52 PM   #437
RodsGreen10
Ok just got home and looked. I do not have the violet and green wire that you have to connect to the dizzy for timing control. Hmmm. Calling FiTech now. If not no big deal my **** is dialed in.
Old 12-08-2015, 02:52 PM   #438
RodsGreen10
The FiTech EFI and a dizzy lol. That's about it and make your connections.
Old 12-08-2015, 02:58 PM   #439
tjsblazer
tjsblazer's Avatar
Any 2 wire distribuer, separate box or not. It won't work with HEI or ready to run style.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 12-08-2015, 03:02 PM   #440
RodsGreen10
Brain fart lol. It is on the back already wired with a 2 pin connector setup.
Old 12-08-2015, 03:07 PM   #441
68Timber
68Timber's Avatar
Thanks. I guess it's got a knock sensor built in?
John
74 Honda Z50 build
Old 12-08-2015, 03:12 PM   #442
RodsGreen10
It will work with HEI.
Old 12-08-2015, 03:13 PM   #443
RodsGreen10
No uses o2 pulse
Old 12-08-2015, 03:33 PM   #444
RodsGreen10
Also with timing control you must have the tach wire connected. And you can not splice or tap the tach wire for the FiTech. It must have its own tach signal. This is what I was told. But if you look at the wiring diagram it does not show this.
Old 12-08-2015, 03:45 PM   #445
RodsGreen10
And it also does work with ready to run dizzy.
Old 12-08-2015, 03:58 PM   #446
tjsblazer
tjsblazer's Avatar
Interesting. Where do you connect your tach then? Maybe this is a dumb question. I just woke up from night shift
I didn't realize it worked with a ready to run style. Ive just been looking over FITech wiring diagrams.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 12-08-2015, 04:30 PM   #447
tjsblazer
tjsblazer's Avatar
I know the FItech will work with any distributer style in Fuel only mode but you can't control timing with an HEI or ready to run style can you? Maybe I'm ready the wiring diagrams wrong. I haven't checked with their tech support.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 12-08-2015, 04:37 PM   #448
RodsGreen10
Samething I thought.
Here is the link to the instructions. Anyone want to look at them and feel free to post here about it. I want others opinions and views.
http://fitechefi.com/virtualoffice_f...structions.pdf
Old 12-08-2015, 04:53 PM   #449
RodsGreen10
Ok spoke with the mechanic at FiTech. He said it will not work with a big cap HEI. And you can tap the tach wire.
Old 12-08-2015, 05:10 PM   #450
RodsGreen10
Also the mechanic told me I need a relay for my fuel pump. I told him I am happy he told me that cause the directions did not say anything about that. So another hold up. I am ordering a fuel pump relay kit.
