Closed Thread
Old 03-23-2014, 10:32 PM   #426
67stepper
67stepper's Avatar
Re: What did you do to your truck today? Chapter II
Size:  52.1 KBPut the rear suspension together, 5 in. lowering coils, 1 in. lowering blocks, adjustable trac bar, rear shock relocating brackets. on some old roller tire and wheels.
Hope i did it right.
67 longbed fleetside switching to a 67 shortbed stepside with a 71 front clip, front disks, 2.5" lowering spindles w/1" lowering spring in the front, 5" lowering spings w/1" lowering block rear, 255/6015 front and 275/60/15 rear on 15x8.5 slotted mags, 355/350, 12 bolt 4.11 posi.
67stepper is offline
Old 03-23-2014, 10:42 PM   #427
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
It's spring.
So, it's THIS (first pic), because of THIS (second and third pics).
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 03-23-2014, 10:54 PM   #428
colgad
colgad's Avatar
Originally Posted by magwakeenercew2jh View Post
Nice set up all the way. Really like the script on the gate.
It's from SpeedCult, I got them at the Turkey Rod Run.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 03-24-2014, 09:31 AM   #429
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
[QUOTE=
So, it's THIS (first pic), because of THIS (second and third pics). [/QUOTE]
Deer problems Bill?
Tom Vogel is offline
Old 03-24-2014, 11:07 AM   #430
magwakeenercew2jh
Originally Posted by Tom Vogel View Post
Deer problems Bill?
Yeah, Tom.
And squirrels, moles, gophers, and voles.
Aieeee!!!!
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 03-24-2014, 04:23 PM   #431
jmorri34
jmorri34's Avatar
Put a new fuel pump on the ole 69er and then proceded to get 2nd degree burns on the old wrist from the header tube checking for leaks!!!
1969 cst prostreet
http://67-72chevytrucks.com/vboard/s...d.php?t=568661
jmorri34 is offline
Old 03-24-2014, 04:58 PM   #432
knomadd
knomadd's Avatar
Saturday I started my Vintage Air Frontrunner swap. Proceeded to break a tap inside the block Had to spend a good portion of my Sunday afternoon grinding away with very little progress. Spent the rest of the afternoon doing research and buying tools to get the bugger out. Now I'm waiting until they show up so I can move on...
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline
Old 03-24-2014, 11:59 PM   #433
bddcustoms
bddcustoms's Avatar
Hope to finish up the cab work this season -- not a lot of time, but it's just about done. Last few days (the first of the season), I picked up were I left off last fall with the trimmed drip rail.
Next will be settling on a trick design that looks somewhat period-correct for the interior. Got a set of '65 corvair buckets to replace the bench. I'll design around that to start at least... one I figure out how I'll actually mount them.
Should be a fun spring summer with the truck!
broke d!@k dog Garage
1969 C20 - Project: "Big Sexy" [http://67-72chevytrucks.com/vboard/s...d.php?t=454894]
2003 'Burban - [Big Pop's daily driver]
1969 350/350 Stingray - [as soon as the economy turns...]
1939 Chevy Roadster Pick Up - Project: "Pre-School" (searching now)
bddcustoms is offline
Old 03-25-2014, 01:00 AM   #434
BlacklandCamper
Exhaust, now welded and installed. Sounds great.
Put trans fluid in it, and it actually moved under its own power! Found out I do need to fiddle a bit more, it moves, but likes to bog down and stall out in gear.
[IMG]youtu.be/2HcvqIXSk0g[/IMG]
http://youtu.be/fzD0r9hE740
Thats my buddy acting goofy. I was having a beer break since it was his turn to weld.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline
Old 03-25-2014, 03:59 PM   #435
big_rig
Kept going on finishing up the engine install after a total overhaul. Replaced all the rad and heater hoses, new carb, new lokar throttle cable and pedal, new fuel lines, triple checked everything. Have to rewire the engine harness for HEI and hopefully fire it up soon.
big_rig is offline
Old 03-25-2014, 04:54 PM   #436
Elliot949
Elliot949's Avatar
Dude... That is a Sweet Six...
Dan
Elliot949 is offline
Old 03-25-2014, 05:14 PM   #437
ole dollor
ole dollor's Avatar
man that's a cool set up....I want one to....Nice
ole dollor is offline
Old 03-25-2014, 06:42 PM   #438
Lou Boffa
Lou Boffa's Avatar
Damn, that 6 is fine.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline
Old 03-25-2014, 07:30 PM   #439
74baggedbug
Had to admit defeat and run a temp sensor on the intake.. Waiting for a fellow forum member to lmk about machining one down to a 3/8
74baggedbug is offline
Old 03-25-2014, 07:56 PM   #440
Lees68GMC
Lees68GMC's Avatar
Vortec's done, going for exhaust tomorrow.
Still gotta sand and paint the hole where the gas fill used to be when the tank was in the cab. Carpet, door panels, you guys know the drill.
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline
Old 03-25-2014, 08:09 PM   #441
Motoxrrar
If you have access to a lathe it's quite easy.
If you need some help I would be happy to provide details and part numbers you may use.
What motor are you running? And what gauges do you want to use?
Motoxrrar is offline
Old 03-25-2014, 09:07 PM   #442
74baggedbug
Running a crate motor with center mount heads.. I want to use the factory gauges .. Thanks
Old 03-25-2014, 09:33 PM   #443
Motoxrrar
There are two different Sensors you can use.
BWD makes two different sensor that will work.
WT359 (220 degrees)
WT357 (253 degrees)
That can be turned down.
Is your original temp sensor port 12mm ?
Old 03-26-2014, 04:49 PM   #444
PowerdbyChevy79
PowerdbyChevy79's Avatar
Finally got my frame painted....used por15..used john deere blitz black as a topcoat.was pretty happy with the results...learned a few lessons..got some ares to fix ..but all in all I was pleased..
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1976 C35 Sierra Grande "Mr. Harvey"
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
1982 C10 Silverado "Lucy"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline
Old 03-26-2014, 04:56 PM   #445
Elliot949
Elliot949's Avatar
looks good to me... I can't wait until my frame is painted...
Old 03-26-2014, 06:30 PM   #446
magwakeenercew2jh
Flip(s):
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 03-26-2014, 11:19 PM   #447
ole dollor
ole dollor's Avatar
Flip(s):
magwakeenercew2jh.....your the man....looks better.
Old 03-28-2014, 03:33 AM   #448
Mike_The_Grad
Mike_The_Grad's Avatar
I made a commitment...now I'm in it til the end,or else I won't be driving a truck! Lol. Pulled all wire today and started the new classic update rewire from american auto wire. Honestly, doesn't appear to be to ardious,at least so far.. actually had enough time to get fuse block mounted! Day two tommorow.
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is offline
Old 03-28-2014, 03:46 AM   #449
Aussie Ol' Blue
Aussie Ol' Blue's Avatar
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
Talking Re: What did you do to your truck today? Chapter II
I picked up my re-built big block from the engine builders today! Everything bar the crank, block and heads is brand spanking new and we've added roller rockers. I am sooo excited!
Took it down to the mechanics and it will be fitted next week.
Also finished the upgrade to the gauge bezel. All I need now is a clock to fill the last blank. 69 Chevelle or similar? Any suggestions?
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY!
IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE!
Aussie Ol' Blue is offline
Old 03-30-2014, 08:03 PM   #450
Econman
Econman's Avatar
Just a little cleaning, prep, primer and paint on the crank pulleys, alternator brackets, fan blades, etc. while I wait on my rotating assembly to be completed from balancing...
As for the fan clutch, what's the best way to get it looking nice again (without replacing it)?
Econman is offline
Closed Thread
