Old 06-01-2016, 05:06 PM   #426
MTCK
MTCK's Avatar
Re: 1991 V3500 Project Heavy Hauler
Sure thing. Head unit is pretty basic Alpine with 3 pair of pre amp outputs (4volt) and Bluetooth calling / audio. Amp is a 5 channel JL xd series, 75x4 and 300x1. Coaxial speakers are 6.5 and 6x9 JL TR series (bottom of the line) and sub is called a microsub 8.2 I think. It has two 8w3's and the box is ported. I had the smaller microsub with a single driver in my 77 K10 and it sounded great. That was a four channel amp with the back two bridged to the sub and pair of MB quart front components. Simple and clean.
I haven't played with this system too much yet but it sounds very clean. Also it's NOT loud outside the car even at high volumes inside. Probably need to give the fatmat some credit there. When I was 16 I wanted everybody to hear my stereo, now just I want to hear it...
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Plow Truck
MTCK is offline   Reply With Quote
Old 06-04-2016, 06:01 PM   #427
COS399
COS399's Avatar
Looking great. Looks like you've been busy. What caused your block heater issue?
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 06-04-2016, 06:25 PM   #428
MTCK
MTCK's Avatar
Thanks. Yes been busy for sure. Good question on the cause of the block heater popping out. When I fixed it, the bolt that holds it in was very loose. I'm not sure how it got so loose, as I torqued it down when I installed it. Hopefully there is no other underlying problem. Only other time I have seen this happen it was a blown head gasket, but I don't have any other symptoms.
My damn radiator is still leaking though. I'm going to have to pull it out and get it to the shop to pressure test and repair.
-Marcus
Project Plow Truck
Old 06-05-2016, 04:56 AM   #429
MTCK
MTCK's Avatar
Installed some steel roller rockers. Summit and Comp couldn't tell me if they fit under the factory rocker covers. Short answer: no. The locking nuts were too tall. I shortened them about 1/4" and they fit after that.
-Marcus
Project Plow Truck
Old 06-11-2016, 03:43 AM   #430
MTCK
MTCK's Avatar
Well the block heater issue didn't go away either. I took it apart and the bolt was stripped. Flipped the nut around which put it on a different part of the thread. Was hoping it would hold so I could go claim the topper I found on Craigslist but it wasn't to be.
Hope this isn't a ride the truck needs again...
-Marcus
Project Plow Truck
Old 06-12-2016, 08:37 PM   #431
deejaaa1
put in a freeze plug until you can figure it out.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 06-12-2016, 11:29 PM   #432
COS399
COS399's Avatar
Bummer on the break down. I just put 4,600 miles on my truck in the last two weeks and luckily it didn't leave me stranded. I was towing a trailer most of the the time and it has 220,000 miles on the odometer. Good luck getting it figured out. Look at the bright side, it wasn't below freezing.
Old 06-12-2016, 11:38 PM   #433
MTCK
MTCK's Avatar
At least it wasn't 40 below! Block heater was junk like so many parts you buy these days. I'm putting the freeze plug in and installing a circulating heater instead of the block heater. Also using this down time to take the radiator in and get that leak fixed.
Topper claimed with the help of a buddy. All good glass, struts, and even has a key for the lock.
-Marcus
Project Plow Truck
Old 06-13-2016, 12:15 AM   #434
Greenlee
Greenlee's Avatar
Nice find! Looks like it's even the right color.
Once you get the kinks worked out this thing will be as reliable as a new truck.
Greenlee is offline   Reply With Quote
Old 06-13-2016, 09:53 AM   #435
y5mgisi
Second Chance Program
y5mgisi's Avatar
Can't wait to see the topper on the truck!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 06-13-2016, 07:47 PM   #436
Matt Man
Matt Man's Avatar
I loved my camper shell on my old truck, I would like to find one for my k10 when I paint it.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 06-14-2016, 01:06 AM   #437
MTCK
MTCK's Avatar
I sure hope so!!! Got the radiator back from the shop today. Had a leak by the drain petcock... Go China.
Thanks guys I'm pumped about the topper too. Will post pics as soon as its mounted. Need to straighten the wow in the front of my bed.
-Marcus
Project Plow Truck
Old 06-21-2016, 04:17 AM   #438
MTCK
MTCK's Avatar
Topper is on. Big test tomorrow we are driving down to Denali with some out of town guests. 180 miles each way and planning to sleep in the back with the mutts. The weather is wet down there so I hope it doesn't leak.
-Marcus
Project Plow Truck
Old 06-21-2016, 04:22 AM   #439
MTCK
MTCK's Avatar
Built a sleeping platform. Queen mattress fits on no problem. Full height space in the back for gear. Spare tire, tools, recovery gear, water, camp chairs and stove fit under it.
-Marcus
Project Plow Truck
Old 06-21-2016, 04:25 AM   #440
MTCK
MTCK's Avatar
Plenty of space for all the gear.
-Marcus
Project Plow Truck
Old 06-21-2016, 07:59 AM   #441
Greenlee
Greenlee's Avatar
Nice! That is the perfect rig for that type of trip. Makes me miss having a long bed.
Old 06-21-2016, 10:06 AM   #442
whitels1
whitels1's Avatar
This truck is awesome! Nice camper, I like the pedestal you made for the mattress and storage.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 06-21-2016, 12:51 PM   #443
daddyjeep
daddyjeep's Avatar
I'm liking the raised bed frame as well. The only thing I would add would be a slide out tray for underneath. Stuff will slide under there and I know I am not skinny enough to fit under there, maybe you are.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 06-21-2016, 02:21 PM   #444
68Timber
I know the pieces fit
68Timber's Avatar
I'm digging it to but surprised nobody mentioned privacy. I'd have to add window tint or maybe some dowel rods to hang sheets on.LOL I wouldn't sleep too well knowing someone walking by could stop and stare. Yeah I've misplaced my tinfoil hat...
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 06-21-2016, 02:43 PM   #445
watahyahknow
watahyahknow's Avatar
seen a few of those on youtube , most build long drawers under the bed with a kick out leg . usually holds the stove and a cuttingboard too so you can somewat cook behind the truck on top of the fully pulled out drawer
prolly be able to fit a jerrycan with water and a tap in there too if it isnt too fat and laying on its side
they usually make some trapdoors in front of the wheelwells under the matras (against the cab) to store camping gear like backpacks and tents and stuff
prolly be a good idea to make foam sides that sit on top of the matrass so you dont roll against the cold metal / sharp sides , that would wake you up in a hurry
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 06-21-2016, 11:12 PM   #446
COS399
COS399's Avatar
Nice set up. I like to see that your using your truck and the topper is a fine addition. I hope you don't have to call the rollback again. Take some pictures for us. I would like to make a trip up there in the next year or two.
Old 06-22-2016, 03:00 PM   #447
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice score on the topper! Nice work on the mattress stand/storage compartment. Good luck on the trip! That really sucks good parts are hard to get these days!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-23-2016, 03:22 AM   #448
MTCK
MTCK's Avatar
Thanks guys appreciate all the compliments and ideas. I'm not sure how much more work I'm going to put into this specific side project. We are hoping to upgrade to one of these next winter, so the sleeping platform isn't made to last forever.
http://www.fourwh.com/product/grandb...er-8-foot-bed/
I'm not a skinny guy, but I can reach everything that could need to come out. The spare tire is most difficult, but possible with patience. I've seen some of those slides, and they are slick! Curtains would be good, but we try to stay where it isn't too crowded, and I've never had trouble with folks up here peeking in windows. Might get a .44mag peeking back...
Truck did great. Over 350 miles, quite comfortable, hauled my wife, two dogs and a passenger without issue. I was kind of wishing for cruise control, but no biggie. AC worked great, topper kept us dry and power ports kept everybody's junk charged up. It really likes 65 mph at about 2250 rpm. I almost wish it was geared a little taller as the motor pulls like a freight train at 1500. Haven't filled up yet to calc mileage but should be north of 12.
-Marcus
Project Plow Truck
Old 06-23-2016, 08:39 PM   #449
COS399
COS399's Avatar
That will be a nice camper. I like the low profile for when your going down the road. Glad you made it up and back without any issues.
Old 06-30-2016, 04:53 AM   #450
MTCK
MTCK's Avatar
Pulled a little maintenance on the truck. Front diff oil was milky, rear was super black and looked like the original pan gasket. I had to use the die grinder with a scotch brite wheel to clean both surfaces.
-Marcus
Project Plow Truck
