Old 08-21-2016, 10:28 AM   #4501
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
alright already lets get to the rebuild process
so here I am using my Polish Press to gently slide the new brass? sleeve bushing thingie in the hole (hammer did not contact the bushing that's what the small wood pieces was for)
the hardest part of this precission process is keeping your thumb out of the way
Gregski is offline   Reply With Quote
Old 08-21-2016, 10:29 AM   #4502
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
How is the ball screw itself? That's where a major portion of the wear seems to take place.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 08-21-2016, 10:33 AM   #4503
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
ladies I would be lying to you if I told you I counted and knew exactly how many of these bee bees came out of that ball screw
I may have counted 50 and I may have read somewhere that 54 is required, please chime in if you know
Old 08-21-2016, 10:35 AM   #4504
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
with balls in it ZERO lateral play, I think that = good
Old 08-21-2016, 10:37 AM   #4505
harley87ta
Re: Restoring Rusty
Originally Posted by Gregski View Post
"Eh Good Enuff'
IT'S A TRUCK!!!
When I read this it made me think of the door alignment on your truck. I looked at doors on my 73 and they have the same sagging look to them. Our doors may have been hung by the same person. They said Eh Good Enuff It's a Truck
harley87ta is offline   Reply With Quote
Old 08-21-2016, 10:40 AM   #4506
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
harley check the bottoms of your doors, when I was a camping my truck was a bit on a hill and I was sitting in a camping chair down low enjoying a luke cold beverage if you know what I mean, and I was like are my eyes lying to me or how stiff is this drink cause my door alignment under the truck is horrible, I mean bad, looks like someone side swiped ie T boned my cab, but they didn't the bottom of the doors just hang way out over the rockers, see if yours is the same
Old 08-21-2016, 10:44 AM   #4507
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so she's coming along handsomely, though the supplied new washer for this adjustment bolt (foreground pointed right at you with the flat screw driver tip) did not fit so we went back with the old one as there needs to be a bit of wiggle room play in there I suppose
and we just packed the darn thing with some 30 year old Castrol bearing multipurpose grease we have been trying to get rid of since I was a teenager
Old 08-21-2016, 10:55 AM   #4508
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
a couple mandatory before and after shots of this Woolly Mammoth
Old 08-21-2016, 10:59 AM   #4509
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
well if nothing else you sure do clean these parts pretty well bro
top pic: Razor Back
bottom: Smooooooooth
Old 08-21-2016, 11:02 AM   #4510
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I just love these before and after shots [oh sorry, millenials translation] pics, I meant pics
Old 08-21-2016, 11:06 AM   #4511
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
can we PALEAZE get this box on the truck already
alright alright...
out with the old first
Old 08-21-2016, 11:10 AM   #4512
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
by my estimation, assuming the power steering fluid was topped off, lets see carry the one, don't forget the belt, ... the old system weighed slightly under 712 lbs, hee hee
and yes the pitman arm is keyed wrong on the manual steering box in this pic (apparantly there are four positions it can be in - who knew, I just keyed it on the first key I saw thinking it was the only one there)
don't worry that arm came off half a dozen times before I got it aligned proper
Old 08-21-2016, 11:15 AM   #4513
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
ok so that took me the entire afternoon from 1330 (1:30 PM people) until 1815... no not eight o'clock... 6:15 PM oh why do I even bother impressing you with my military time know how, jk
ok, good job, looks good bro, how does it drive?
oh what's with all these questions? let's not split hairs here
Test Drive Time - TDT
Old 08-21-2016, 11:19 AM   #4514
Wide Open
Re: Restoring Rusty
Nice work on the box.
Why'd you switch to manual?
1972 K10
1986 K30 crew cab dually
2002 Z06
2007 Escalade
Wide Open is offline   Reply With Quote
Old 08-21-2016, 11:21 AM   #4515
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
LESSONS LEARNED so far
the broom stick ie the steering column do slide up and down so the manual box bolted right up though its not the exact same length as the power box
I did re use the old rag joint but I plan on buying a new one or getting a universal joint setup, if someone has one to recommend I would really appreciate that (I think someone already did way earlier in the thread but I am too lazy to look inside my own thread)
Power Steering box was about 3.5 turns end to end
Manual Steering box is about 4.0 turns end to end
Pitman arms be different, not so much in length or design but in hole for the splines, I think the manual is a bit smaller hole
Old 08-21-2016, 11:23 AM   #4516
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I'm a minimalist, less is more, cleaner engine bay, one less thing to leak (power steering fluid is nasty and finding an air tight pump is impossible) tired of squeeky belt during tight end to end U turns, maybe 2 more horse power, WANTED BIGGER BICEPTS!!! seriously just wanted to try it, see how it works, I may go back to power steering and just not tell you all, ha ha, I'm a Hot Rodder = mess with things constantly especially specialize in fixing things that are not broken
Old 08-21-2016, 12:29 PM   #4517
Wide Open
Re: Restoring Rusty
Gotcha
1972 K10
2002 Z06
2007 Escalade
Old 08-21-2016, 06:51 PM   #4518
rusty76
rusty76's Avatar
Re: Restoring Rusty
So how's the darn thing handle/steer now. I'm dying to know. You've answered several questions about swapping to manual now I just need to know your final results youngin.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 08-21-2016, 07:12 PM   #4519
Chrispbrown36
Re: Restoring Rusty
Hey Gregski, remember me talking about that old lady that lives up the road that has the squarebody sitting in her garage? Well I got some details on it from another neighbor....he says that it is a 74 or 75, 3/4 ton, with only about 10,000 miles on it. He said his grandpa and the old ladies dad bought similar trucks at the same time and the old ladies dad pretty much parked his....now I might have to say it with flowers!
Chrispbrown36 is offline   Reply With Quote
Old 08-21-2016, 08:51 PM   #4520
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
LOL, First of all let me just say it took sum ballz to pull this off, sorry could't resist, hee hee
OK, after the test drive... Houston... We have a problem.
Apparently 2 is not the middle of 4 according to GM, you see [ahem] "pops" jk the passenger side hits the steer stop and the driver side stops short of it by maybe just under an inch
I think its time to blame the P.O.
Looks like the previous owner replaced the outer tie rod on the driver side only but not on the passenger side
So first this Power Nap aint going to take itself no how, so lemme git that out of the way and then git after it
Report at 11
Old 08-21-2016, 09:53 PM   #4521
Hewfil1
Hewfil1's Avatar
Re: Restoring Rusty
Report at 11
Luck be with you Gregski!
Hewfil1 is offline   Reply With Quote
Old 08-22-2016, 12:15 AM   #4522
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
thank you, Fix This I Must
so Rule #7 clearly states if you don't know what you is a doin' than Stare 'N Compare bro
and so we is going to compare twisty turney thing on the driver side to the twisty turney thing on the passenger side
first after wire wheelin' them a bit we can actually see they are a slotted, cool we can see how much threads are in them and how far apart
Old 08-22-2016, 12:22 AM   #4523
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
well after a couple hours and some fine "adjustments" and I use that term loosely, ha ha I thought I had the problem resolved both wheels were slightly toed in and each side went to the side an equal distance stopping just before the steer stop on either side - NICE
well but a test drive proved otherwise, the truck drove ok, but it felt like I could make tighter turns to the right than to the left
so... the Greg found me a nice empty parking lot, 57 feet wide with concrete edges on either side so you could not go out of bounce and cheat sort of speak
then I proceeded to make a right hand turn with the wheel turned as tight to the right as possible and I just barely made a couple perfect circles to the right within the confines of that parking lot
ok, awesome now lets try the other way, so I turned the wheel 4 turns to the left, ie all the way and gave it a shot, low and behold I could not fit inside that parking lot
in other words I am unable to make a U turn within 57 feet
help!
Old 08-22-2016, 01:19 AM   #4524
harley87ta
Re: Restoring Rusty
Could your pitman arm not be clocked in the right position? I think they could be installed in different postions. Not sure if that could cause your issue though
Old 08-22-2016, 02:06 AM   #4525
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
this one looks like it can be clocked in 4 different positions but the one that it is in is the only one that reaches the linkage and the steering box
thanks for trying to help, I wish I baselined this with my old power steering box still on, but things seemed fine so I had no idea what problems I would have with the manual box
I bought the manual box with the pitman arm to avoid these types of headaches but I still ran into issues
I think its a tie rod linkage issues, but I am not sure
