Closed Thread
Old 01-14-2012, 12:57 PM   #4526
jbgroby
jbgroby's Avatar
Re: What did you do to your truck today?
When I was a teenager, those Nova's seemed to be all the rage. Many boys I went to school with had the rearend about 6" higher with "Hi-Jackers", wide rear tires, hood scoops, etc. It has one of those universally appealing body styles.
jbgroby is offline
Old 01-14-2012, 03:22 PM   #4527
mrfixit4818
Nice shape ,good luck w it!
mrfixit4818 is offline
Old 01-14-2012, 07:46 PM   #4528
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
I installed my CPP 2.5" drop spindles my son got me for Xmas
Also installed new front stock springs and cut 1/2 a coil off to gain a little more drop. Rides much better than the stock spindles with 2 coils cut on the stock springs... Only had 2" of travel until it hit the bump stop...
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline
Old 01-14-2012, 07:53 PM   #4529
mrfixit4818
Anyone ever try heating old coils to drop the truck down?
Old 01-14-2012, 07:54 PM   #4530
protrash64
Resistance is Futile
protrash64's Avatar
No.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline
Old 01-14-2012, 08:05 PM   #4531
mud.man.rj
mud.man.rj's Avatar
Ya we heated the old rear coils when we order a drop for front and back(coil) and got the wrong rear coils(sent stock) so we returned them and while waiting for the new ones (the front had 5"drop) we heated one coil only and gently put 2 peoples body weight on rear bumper until it dropped and mid way between the 2 coils and had a 3" drop and it worked good and drove nice but we didn't care because it was back end high so we heated another coil and dropped it the same which worked good too but of corse it road bad but good enough until the new set showed up, so if trying this you will only get a 2-3" drop and will ride a little stiffer, easy to go too far though and collape the coil, did it on a beater for fun but jumped on bumper and collaped the coil.
mud.man.rj is offline
Old 01-14-2012, 08:12 PM   #4532
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
When I bought my truck the front coils were heated for drop and it rode like crap... I converted to a 75 Chevy front and cut the stock coils. It rode better but I made the mistake of cutting 2 coils which is too much...
My rear leaf springs are heated for drop and I think that I will replace them and do an axle flip for the drop.
Tony
66 GMC LWB
AZ66GMC is offline
Old 01-14-2012, 08:27 PM   #4533
mrfixit4818
The guy I bought the truck from told me to heat them but i saw ebay has rear 4in drop coils for my 64 for $89 delivered.Anyone bought ebay springs?
Old 01-14-2012, 08:41 PM   #4534
markeb01
Senior Enthusiast
markeb01's Avatar
When I was a kid my old man picked up a 52 Chevy 2 door sedan to turn around for a quick profit. It had belonged to a teenage girl, until her boyfriend “fixed it up” for her by lowering the front end and rebuilding the transmission.
He torched the front springs in one spot straight up and down until each coil had a U shaped droop in it resting on the droop below. At this point they lost all temper and collapsed completely. After “improving” the front end and repairing the transmission, he sent her home in it without any transmission lube. No idea if the relationship endured, but that was the last time she ever drove the car.
It left me with the lasting impression that torching coils and running a transmission empty wasn’t very productive.
markeb01 is offline
Old 01-14-2012, 11:01 PM   #4535
sigshooter
sigshooter's Avatar
I put my new body over on my frame today
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline
Old 01-14-2012, 11:03 PM   #4536
65Gregg
65Gregg's Avatar
Started cleaning up and removing a bad rocker while the fender is off for repairs from a run in with a golf cart. The inner portion will be fine, it's still solid just needs the scale removed. The end pieces are just fine so I feel pretty lucky.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 01-14-2012, 11:33 PM   #4537
allaboutchevelles
allaboutchevelles's Avatar
Yes>> I bought those same 4 inch drop springs off ebay for 89 dollars and they look great and fit but my bed and cab is off the frame so I just sat them in to see how they looked.
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline
Old 01-15-2012, 12:29 AM   #4538
sahnobi
where can u get a cheap lowering kit for front and back im on a budget
sahnobi is offline
Old 01-15-2012, 09:54 AM   #4539
waspp
waspp's Avatar
Painted my dash and part of the cab interior.
waspp is offline
Old 01-15-2012, 10:01 AM   #4540
mrfixit4818
Nice,Can or sprayer?
Old 01-15-2012, 12:42 PM   #4541
66farmer
66farmer's Avatar
I spent all day streighting removing dents sanding buffing and polishing the stainsless steel windshield trim.
Got a call from the painter of my truck to come look at the first painted part.
(IIII LIKE IT)
66farmer is offline
Old 01-15-2012, 02:08 PM   #4542
waspp
waspp's Avatar
I was going to spray it but I did some research on this board and decided to go the rattle can route. The color is a bit lighter than stock but pretty close for who its for! The Krylon rattle cans have a nice wide spray pattern and I was surprised at how well it came out.
waspp is offline
Old 01-15-2012, 09:47 PM   #4543
gofastnut
gofastnut's Avatar
I looked longingly at "old brownie" while pulling out of the driveway to go to church this morning...sigh....
gofastnut is offline
Old 01-15-2012, 11:22 PM   #4544
Narxoleptic Customs
Got my console covered in an old leather jacket... Working on the shifter cover over the next few days.
Narxoleptic Customs is offline
Old 01-15-2012, 11:28 PM   #4545
sigshooter
sigshooter's Avatar
What is the Krylon paint code number? I am gonna give it a try
1966 Short stepside
1964 long bed
Old 01-16-2012, 12:28 AM   #4546
waspp
waspp's Avatar
Off the shelf at Walmart:
http://www.walmart.com/ip/Krylon-Bru...uveau/17211106
waspp is offline
Old 01-16-2012, 02:23 AM   #4547
markeb01
Senior Enthusiast
markeb01's Avatar
(IIII LIKE IT)
Both turned out very nice!
markeb01 is offline
Old 01-16-2012, 06:04 AM   #4548
Turkey
Turkey's Avatar
Bought my rear coils and shocks on ebay. They are from CPP. I just went to their website for the front ones.
Turkey is offline
Old 01-16-2012, 11:46 AM   #4549
Goldie80
Goldie80's Avatar
Installed the engine! Well, it was installed Saturday not today.
Goldie80 is offline
Old 01-16-2012, 02:12 PM   #4550
gofastnut
gofastnut's Avatar
Goldie80, That looks nice! Really liking the crinkle finish on the valve cover.
Closed Thread
