02-10-2012, 02:11 PM | #4626 |
Re: What did you do to your truck today?
Oil / oil filter change and lubed the front end.
Then I proceeded to run out of grease in the grease tube without a spare tube. whoops. -W |
02-11-2012, 11:45 PM | #4627 |
Finally got a set of headers that fit good, did not have to trim the frame. This was set 3 as the first set of Hedman's wouldnt work with the motor moved to the forward hole, I also tried some patriot shorties, those were close but hit the CPP mounts
02-12-2012, 12:31 AM | #4628 |
Mounthed the front clip.
http://s1299.photobucket.com/user/jb...23904108567829 |
02-12-2012, 01:30 AM | #4629 |
cleaned up some areas and reinstalled my speakers 'cause I found my VH Diver Down cassette. Classic tunes for "parts" running this afternoon.
02-12-2012, 01:49 AM | #4630 |
put the inline back in
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
02-12-2012, 11:39 PM | #4631 |
Not a da^^ thing.. It was to freakin cold...
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice http://67-72chevytrucks.com/vboard/s...d.php?t=492640 |
02-13-2012, 12:50 AM | #4632 |
Froze my butt off in the shop but managed to finish mounting my alternator,new flexplate installed,and got the throttle linkage done and tight.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
02-13-2012, 12:51 AM | #4633 |
Did I mention freeze...
02-17-2012, 11:12 AM | #4634 |
Installed a new retro radio and kick panels with speakers.
02-17-2012, 11:20 AM | #4635 |
I did full rear brake job on my 64 C20 Crew Cab using 1980 K20 front rotors, calipers and lines. Did the swap in 06 and 1 caliper locked up last weekend so i swapped all out yesterday. The mounting brackets are for a 14bolt disc conversion and work on the Eaton H052 / H072. From Great Lakes Offroad...
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 |
02-17-2012, 01:08 PM | #4636 |
Tell some details on those kick panels w/speakers! They look great - how do they sound?
As for me, I picked up a new bed and tailgate from Craigslist and pulled out my radiator and heater core. Taking them to the radiator shop....got most of the front end disassembled. |
02-17-2012, 02:39 PM | #4637 |
They sound ok. Just running deck power now so cant really say for sure until I get an amp. Also the speakers are pretty low, so its a good idea to also run a speaker or pair of speakers in the factory dash to balance the sound.
02-17-2012, 11:33 PM | #4638 |
tried to get an alignment and ran into low truck prejudice.
"wont work on that its lowered" actually its channeled so its really only 2 inches or so lower than stock. "nope" so tomorrow I get to find a new alignment shop.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
02-18-2012, 12:08 AM | #4639 |
just ordered my dom 2600's for the front. got my sectioned cross member paid for. Ordered a running 350 to replace my old 6 from a local wrecking yard they will deliver it thurs. also ordered my new wiring harness from speed way. so a pretty productive day!
1966 C-10 long wide- currently with 2 3/4 sectioned crossmember, 3 inch cupped a arms with 2700 bags, 67 master cylinder, in the middle of a v8 swap, soon custom rear wishbone set up and bags 1942 chevy/divco ambulance 1937 chevy truck |
02-18-2012, 04:22 AM | #4640 |
I pulled my windsheild and started to "discover" where I need to do some body work.
Posted via Mobile Device |
02-18-2012, 09:31 AM | #4641 |
put in rosewood armrest/doorpulls, three point seat belts,spring loaded the glove box door
Don't stop, its harder to hit a moving target. |
02-18-2012, 10:44 AM | #4642 |
GMC's n H.D.'s too!
Do you have pictures of the armrest/door pulls and the spring loaded glove box?
02-18-2012, 10:54 AM | #4643 |
The 60-66 GMC/Pontiac guy....
What I did yesterday was mock up a front end on my 71 frame that I am converting to take a 63-66 cab and front end.
Today, I am taking the front clip and cab back off, hopefully get the nose of the 63-66 frame horns grafted to to the 71 frame, pulling the suspension, again, and cleaning everything up to be ready for paint.
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
02-18-2012, 06:09 PM | #4644 |
Put on my new headlights w 5600k bulbs and wired up 2 relays!nice!!!!!!!
02-18-2012, 07:01 PM | #4645 |
Who Me?
Repaired the leaky float on the gas tank sending unit. I kept wondering why it would only hit a half tank when full.... now I know.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
02-18-2012, 08:16 PM | #4646 |
l
m |
02-18-2012, 08:29 PM | #4647 |
Pulled my Side Mount gas tank, It was in really bad shape, I kept getting rust in my Holley 750 double pumper, So time for a new Gas tank and Sending unit! Cheap on Ebaymotors.
77' 3/4 Shortbed Stepside Silverado |
02-18-2012, 08:30 PM | #4648 |
Same problem with mine!
02-18-2012, 08:51 PM | #4649 |
Installed a new in dash speaker, seatbelts and replaced my fuel pump.
X24 1964 chevy c10 step side 230ci straight six Auto power glide |
02-18-2012, 09:48 PM | #4650 |
cleaned up the mess in the shop and guess what theres truck parts on the shelves now . I can find stuff again!
