Closed Thread
Old 12-31-2012, 03:47 PM   #4651
North60
Re: How about some pics of 73-91 crew cabs
Originally Posted by jlsanborn View Post
All in good fun here! That sure is a sweet looking truck. What engine in there?
454 nat asp. Starts just like the tbi 87 I had. It seems to idle high, but I think the cold thermostat is the cause the temp gauge won't run past 1/4 notch. Heat in cab is good. The truck originally came from Nevada, had all the work done in California. m thinking the stat is a 165. I'll get it sorted out.
North60 is offline
Old 12-31-2012, 04:30 PM   #4652
jlsanborn
jlsanborn's Avatar
Q-jet I presume? With an electric choke I wouldn't think a low engine temp would keep it on fast idle. Do the secondaries open once its warm?
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline
Old 12-31-2012, 04:38 PM   #4653
North60
Good question, I will check when I get a chance. It does kick down but not as much as I would expect.
North60 is offline
Old 12-31-2012, 04:40 PM   #4654
North60
I assume qjet, buy all I have done is synthetic oil change and block heaters, I haven't even had the air cleaner off. It had been in the -35 c range for weeks. -1 today. Feels tropical.
North60 is offline
Old 12-31-2012, 04:41 PM   #4655
jlsanborn
jlsanborn's Avatar
If it is a q-jet and you're into tinkering with that, pm me an email address. I have a great tech paper that's worth the read!
Old 12-31-2012, 04:52 PM   #4656
North60
Check out this squarebody, I just took the pic. It's outside my office.
North60 is offline
Old 12-31-2012, 04:53 PM   #4657
North60
It's used for pushing light aircraft around
North60 is offline
Old 12-31-2012, 05:58 PM   #4658
jlsanborn
jlsanborn's Avatar
That is pretty cool!
Old 01-01-2013, 07:17 AM   #4659
Big-Sexy907
Jittery / Comegetsome, what are you guys using for wheels? Trucks look great btw!
Big-Sexy907 is offline
Old 01-01-2013, 08:05 AM   #4660
jitteryguy
GoatLube Experss
jitteryguy's Avatar
thank's, 22.5" Alcoa's mill'd down to 22".
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline
Old 01-01-2013, 08:55 AM   #4661
comegetsome2003
comegetsome2003's Avatar
Yea im also running 22.5s milled down to 22s.....my front suspension is narrowed 1 inch and im running a SRW rear end to get them tucked under the fenders
comegetsome2003 is offline
Old 01-01-2013, 08:58 AM   #4662
Big-Sexy907
Are you running a standard rear wheel or is this like TW&T's Tow Nasty wheel?
Do you have a build thread on how to switch over to the SRW axle? I'd love to lower/bag my C30 but I'm not too sure about finding a wheel that fits.
Old 01-01-2013, 09:05 AM   #4663
comegetsome2003
If you go back up and look at the pics i posted my truck actually started life as a SRW 1 ton....i have a build thread over on dually scene
1991 Square CCLB Dually...laid out on 22s with an old noisy 12 valve
Old 01-01-2013, 02:26 PM   #4664
Big-Sexy907
Happen to have a link to the thread? I searched for it on Duallyscene and couldn't find it.
Old 01-01-2013, 03:43 PM   #4665
jitteryguy
GoatLube Experss
jitteryguy's Avatar
ya, mine are the TowNasty wheel's.
'85 1/2 ton CCSB
'92 S10 350/350
Old 01-01-2013, 09:20 PM   #4666
comegetsome2003
Yea man here is the link....it covers my first dually that was bodied with an LS swap...after a couple years of frustration from a blown up motor and frame issue i started fresh with my current dually
http://www.duallyscene.com/forums/su...ene-t4916.html
Old 01-02-2013, 12:58 AM   #4667
twotonecrew
Nice truck! I am usually not a big fan of the dual wheel look but yours is pretty sharp.
twotonecrew is offline
Old 01-02-2013, 04:28 PM   #4668
North60
I am having a rough time finding some running boards for my 86 crew cab dually. Anyone have some suggestions?
North60 is offline
Old 01-02-2013, 05:23 PM   #4669
meatwagon83
meatwagon83's Avatar
im having a hell of a time finding a pushbar, looks like i will be building one!
meatwagon83 is offline
Old 01-02-2013, 05:25 PM   #4670
North60
You would think there are enough trucks still on the road to keep them from being obsolete.
North60 is offline
Old 01-02-2013, 05:26 PM   #4671
meatwagon83
you would think wouldnt you?
Old 01-07-2013, 05:38 PM   #4672
Chevyrules
Chevyrules's Avatar
ha ha that should be in 73/87 projects and builds
Chevyrules is offline
Old 01-09-2013, 01:00 AM   #4673
Black 'n' Blue
Black 'n' Blue's Avatar
Took the sides off, much better. Gonna figure out a system for easy removal so I can take them off in 5 minutes.
-Justin.
The past cannot be edited, or erased. Only accepted.
Loud, proud and country by the grace of god!
Bradley Anderson 1997-2011
Black 'n' Blue is offline
Old 01-09-2013, 08:05 PM   #4674
meatwagon83
is that the explosive truck?
Old 01-09-2013, 10:25 PM   #4675
Black 'n' Blue
Yea it is.
-Justin.
Closed Thread
crew, crew cab, square body, squarebody, squarebody.net
