Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 09-09-2020, 04:53 PM   #451
aotte1
Re: Power Brake Booster Adapter Bracket
Ordering a bracket today. Would like powder coated one please.
Pm payment info. please.
Les
aotte1 is offline   Reply With Quote
Old 09-09-2020, 09:48 PM   #452
Captainfab
60-66 Nut
I replied to your PM Les.
Old 09-19-2020, 11:47 PM   #453
aotte1
Received the power brake booster bracket, thanks John, just what I needed.
Les
Old 09-20-2020, 10:57 PM   #454
Captainfab
60-66 Nut
I appreciate the purchase. Did you get my email about the payment?
Les
Old 09-23-2020, 12:12 AM   #455
aotte1
John,
Email sent tonight.
Les
Old 11-04-2020, 02:11 PM   #456
Dodge68charger
Do You Take Visa?
Dodge68charger is offline   Reply With Quote
Old 11-04-2020, 10:40 PM   #457
Captainfab
60-66 Nut
Yes but only thru PayPal.
Originally Posted by Dodge68charger View Post
Do You Take Visa?
Old 11-14-2020, 10:09 PM   #458
KVB
I would like a power brake booster adapter for my 65 GMC. could you guide me what years of booster would fit? Master cylinder also please. I am running drum/drum.
Ken
KVB is offline   Reply With Quote
Old 11-14-2020, 10:28 PM   #459
Captainfab
60-66 Nut
For a drum/drum braking system you will want a booster and master for a '67-'70 C10. Or if your truck is a 3/4 ton you will want those for a C20.
Old 11-14-2020, 10:35 PM   #460
KVB
Thanks for the reply. How much for the bracket and payment instructions please. I am in Canada, postal code J5R1G4.
Old 11-14-2020, 10:49 PM   #461
Captainfab
60-66 Nut
I'll send you a PM.
Old 11-15-2020, 01:41 AM   #462
Dodge68charger
Does Anyone Have A Part Number For a Black Dual Diaphragm Power Booster and Master Setup That Will Work With This Bracket For My 69 C10?
It Looks Like a Great Piece and Wanna Use It
Old 11-15-2020, 08:52 PM   #463
Captainfab
60-66 Nut
Do you realize that every one of my booster brackets comes with a list of compatible boosters including some part numbers. That does include some of the universal aftermarket boosters in black. Most of the aftermarket universal boosters are compatible with all of my booster brackets. Also this thread is for the '63-'66 booster bracket. You will need the one that I fabricate for the '67-'72's.
Old 12-26-2020, 11:09 PM   #464
BAGGERSOCAL
Active Member
Nice bracket that would look good on my 168 C10
BAGGERSOCAL is offline   Reply With Quote
Old 12-26-2020, 11:09 PM   #465
BAGGERSOCAL
Active Member
Nice bracket that would look good on my 1968 C10
Old 12-26-2020, 11:25 PM   #466
Captainfab
60-66 Nut
This for sale thread is for the '63-'66 standard booster bracket. This will not work on a '67-'72. You will need this booster bracket if you are looking for a standard booster bracket as opposed to the booster bracket with the hydraulic clutch conversion.
http://www.67-72chevytrucks.com/vboa...d.php?t=347484
Old 03-22-2021, 11:30 AM   #467
Merican68C10
Merican68C10's Avatar
CaptainFab,
I recently purchased a 1965 Suburban with standard master cylinder (front disc/rear drum) and I was looking to upgrade the brake system to a power booster setup. I was curious if you knew if I'm able to use the OEM style booster setup (front disc/rear drum) off of my 1968 C-10 in conjunction with your bracket setup on my new 65?
Merican68C10 is offline   Reply With Quote
Old 03-22-2021, 09:25 PM   #468
Captainfab
60-66 Nut
I replied to your PM.
Old 04-08-2021, 09:53 AM   #469
dweikum
Guest
Posts: n/a
Just what I needed! PM incoming.
Old 04-08-2021, 09:57 PM   #470
Captainfab
60-66 Nut
PM replied to
Old 05-05-2021, 01:03 PM   #471
Merican68C10
Captainfab,
Received bracket, got it mocked up, painted and installed. Worked out perfect! Only thing I had to do was leave bracket to firewall little bit loose until booster was installed to front of bracket and then fully tighten firewall bolts. This way it didn't cause the outer metal to booster to spring outwards pulling bolt holes farther apart. Fits my 67-72 booster/master cylinder setup perfectly!
Thanks again for a premium made piece!
Old 05-05-2021, 09:49 PM   #472
Captainfab
60-66 Nut
Thank you for the feedback and the compliment
Old 06-05-2021, 09:35 PM   #473
rcodea
seeking some input on the right booster to use with this bracket. its a 71 C10 LWB with a blown LS3....kinda need good brakes.
I have a 93 s10 reman booster now which seems to be either bottoming out at ~1/4 pedal throw, or is not strong enough to be of any assistance past that point. The pedal feels like its assisted to that point, then feels like manual brakes where you have to truly stand on it to get additional stopping force.
booster is currently a 93 s10 4.3 V6, Cardone 54-71152....10.8" single booster
Master is a Wilwood 1 1/8" w/adjustable prop valve...currently back all the way off....still getting strong force to the rear since the rear rotors are so large
front c5 calipers w/14" rotors
rear mustang calipers w/14" rotors
electronic vacuum pump, known working well and pulls about 28"Hg
stainless lines
fresh fluid and both standard bled and reverse bled(previously thought i had air)
The calipers come on their respective cars with a 15/16" master...so i understand that the pedal will be harder than 'stock' because of the increased master size....was trying to limit the long pedal i was getting with the 15/16" master.
Any input would be helpful. will not go with hydroboost....want to stay vacuum. Is there a chance mine is bad? go do larger or dual 9" booster? ANythign ic an do to futher troubleshoot?
rcodea is offline   Reply With Quote
Old 06-05-2021, 10:30 PM   #474
Captainfab
60-66 Nut
How did you lengthen the booster pushrod? Could the pushrod be binding or rubbing on something?
Old 06-06-2021, 10:01 AM   #475
rcodea
I cut the round portion off the booster, then threaded it and use a 2" threaded coupling along with the manual pushrod...makes for a slip joint but still keeps it aligned which allows me to adjust the length without much trouble.
There was a sheet of paper which came with the bracket....had the applicable options for the boosters....would any one of them be better suited than the single 10.8"
