Old 01-11-2012, 11:55 AM   #451
mcbassin
Still Learning
mcbassin's Avatar
Re: '72 Chevy SWB, Project Driver
Originally Posted by usmcchevy View Post
Thanks! I'm thinking a bit of caster
mcbassin is offline   Reply With Quote
Old 01-11-2012, 12:03 PM   #452
Nick_502
Nick_502's Avatar
Your truck is looking pretty sweet. I seen you were going to install that hidden antenna? How does that work?
1970 Chevelle
1969 C-10 shorty
Nick_502 is offline   Reply With Quote
Old 01-11-2012, 12:07 PM   #453
mcbassin
Still Learning
mcbassin's Avatar
Powered Antenna
Guess its a good thing I replaced the rear end cover.....I never noticed this until now Just about wore through.
I'm interested in the power antenna. Have you used one of these before? How did it work?
What was rubbing on the cover?
Old 01-11-2012, 12:12 PM   #454
thor
thor's Avatar
How's the R&P?
Interested to see if the hidden antenna works well. Keep us posted.
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 01-11-2012, 12:55 PM   #455
Crash_OK
Crash_OK's Avatar
Looks like he has a dent in the pan and the ring gear is rubbing....
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 01-11-2012, 08:40 PM   #456
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
I'm shifting the lower A arms forward 3/4" which will give me more caster in hopes of making this thing handle better.
Check here: http://67-72chevytrucks.com/vboard/s...d.php?t=487363
Or if you have a day or two here: http://67-72chevytrucks.com/vboard/s...d.php?t=419251
Thanks! It works, haven't had it out of the garage to see how good though.
Nope this is my first, A few guys on here have had good luck, so I hope it works good.
Originally Posted by thor View Post
How's the R&P?
Will do.
Yep, there was a dent in the cover so it was rubbing. Ring and pinion are in great shape. Thanks everyone!
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-11-2012, 09:10 PM   #457
Jarwood
Jarwood's Avatar
I installed a hidden electric antenna and was not happy with it. Stations that were strong worked ok, but would lose a strong signal alot. Hope yours works better.
Jarwood is offline   Reply With Quote
Old 01-11-2012, 09:17 PM   #458
mcbassin
Still Learning
mcbassin's Avatar
My bad, I kept thinking caster??? wth? That's something I'm going to have to deal with eventually. When I built my front end I just bolted eveything together. I know it's way off. Not sure it would be driveable to the alignment shop. I'll have to refer to the manual alignment thread when that time comes.
Old 01-11-2012, 11:08 PM   #459
usmcchevy
usmcchevy's Avatar
Thanks, I hope it works good. At least my favorite station came in before I even hooked the power up.
No prob, I thought i might throw someone for a loop with that answer
Just ordered some new front tires 255/60R15, Current ones are 225/75R15-too tall and narrow.
Build thread
LSx Swap FAQ index
Old 01-11-2012, 11:47 PM   #460
2FnCool
shorter wider tires will look better and help the handeling
2FnCool is offline   Reply With Quote
Old 01-12-2012, 08:07 PM   #461
mcbassin
Still Learning
mcbassin's Avatar
Sounds like a plan. You get to drive this bad boy everyday? I can't wait till I'm just able to drive mine.
Old 01-13-2012, 12:56 AM   #462
usmcchevy
usmcchevy's Avatar
Yep....and the new ones should hold air longer than a month
Every day to work and back, but I haven't worked for just about a month now. My wife has had and still recovering from two knee surgery's in the last few weeks. She's fine now, but can't chase our 14 month old son just yet.
Build thread
LSx Swap FAQ index
Old 01-14-2012, 06:37 PM   #463
usmcchevy
usmcchevy's Avatar
Done shifting the A arms forward.
Old.
New
Needed some clearance.
You can see the old locating hole here.
Tires will be here Monday, go on Wednesday and hopefully it will get an alignment Wednesday-Friday.
Build thread
LSx Swap FAQ index
Old 01-15-2012, 12:08 AM   #464
mcbassin
Still Learning
mcbassin's Avatar
Nice machine work Ben. You're gonna have to give me Cliff notes version of how this helps performance? I really don't understand suspension.
Old 01-17-2012, 10:07 AM   #465
usmcchevy
usmcchevy's Avatar
Thanks......Not sure I would consider something done with a cordless drill and a 5/8" bit "machine" work, but I'll take it
Moving the LCA forward causes the top of the spindle to tilt backwards so when you turn the wheels the tire will tilt. This tilt when in a turn forces the outside edge of the inside tire and the inside edge of the outside tire into the ground for better traction and also compensates for body roll. Thats my understanding at least.
Tires are here, props to Tirebuyer.com cheaper than any local place by over $50 a tire and fast free shipping. Now to get them on.
Build thread
LSx Swap FAQ index
Old 01-17-2012, 12:29 PM   #466
mcbassin
Still Learning
mcbassin's Avatar
Oh yeah! Love the new tires. Late Christmas present eh? Those are gonna look great on there. Mount them up.
Old 01-17-2012, 04:11 PM   #467
thor
thor's Avatar
Ya didn't want to run a shorter sidewall than 60 series? I like 50 series. Stiffens up the tires without making the ride too stiff, like 40 series.
Old 01-18-2012, 02:24 AM   #468
Average Joe
Average Joe's Avatar
I digg those Indy 500's. I run them on my 'Burb. The 255 seems like a good all around width.
Average Joe is offline   Reply With Quote
Old 01-18-2012, 06:30 PM   #469
usmcchevy
usmcchevy's Avatar
Mike, You could say that, hopefully mounted tonight!
I think these are the lowest profile tire I ever owned so no real experience. I didn't want them too short as they will already be about 1.25 shorter than the back. The 255/60R15 front and 275/60/R15 seems to be pretty popular , so I hope I like it. Some day the truck will get 20's and this set of wheels will be turned into my racing set with some drag radials on the back, but thats a lot of money, paint and a turbo from now
Thanks, Hope I like them.
Build thread
LSx Swap FAQ index
Old 01-24-2012, 08:55 AM   #470
usmcchevy
usmcchevy's Avatar
Little late of an update, but tires are on and its back from the alignment shop. The drivers side worked out great 5.6deg of caster, but on the passengers side they were only able to get 0.4deg. So now I'll be taking the truck to another shop that has a frame rack, hopefully they can figure out what is going on.
Build thread
LSx Swap FAQ index
Old 01-24-2012, 05:27 PM   #471
68 TT
Still plays with trucks
68 TT's Avatar
I had a bent upper control arm do that to me. It looked OK but was twisted just a bit from a neighbor backing into my car. The corner of their bumper hit the top of the rim and the weak link was the upper A-arm.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 01-24-2012, 10:55 PM   #472
usmcchevy
usmcchevy's Avatar
I hope its an A arm........but I think its the frame.
Updated pic.
Build thread
LSx Swap FAQ index
Old 01-25-2012, 01:16 AM   #473
mcbassin
Still Learning
mcbassin's Avatar
New meats look great Ben. I actually like some side wall on my tires. I think they look tough too. Hope you get the alignment figured out.
Old 01-25-2012, 07:33 AM   #474
wrwelton
wrwelton's Avatar
Very impressed. That Roland sure is a good friend. That other cab was a gonner. Keep pics coming. Going to be a nice driver when done.
Here is mine. http://www.flickr.com/photos/waltspr...7628925019747/
I know I can! I know i can! 72 K20 Restoration
wrwelton is offline   Reply With Quote
Old 01-25-2012, 10:34 PM   #475
mooseknuckles
mooseknuckles's Avatar
awesome build man!
mooseknuckles is offline   Reply With Quote
