#451 |
![]() Join Date: Jul 2010
Re: Started my first frame off - 72 SWB LS1, 6-spd manual
Radiator pic
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
#452 |
Pic 2 of radiator with 16" SPAL fans
#453 |
I ran the engine harness through the firewall today. It was a little nerve racking hole sawing through the firewall. I still need to install a grommet. Getting closer to finally hearing it run. I can't wait.
#454 |
![]() Join Date: Dec 2006
Harness looks good Mark and so does that radiator/fan assembly. It fits in the stock 4 core mounts?
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#455 |
Thanks Keith. I hope so. I called Griffin's tech support to make sure before I ordered the mounts. I should receive them by Friday. The radiator measures exactly 3" in width top/bottom. If your running the same mounts (4 core) can you verify the width for me?
#456 |
Still Learning
Nice looking radiator Mark, love the clean engine bay. I'm ready to see a video of this puppy running.
#457 | |
#458 | |
#459 |
Not a big deal if you can't get to it. Tracking number shows I should get them Friday. Thanks Keith
#460 |
Still Learning
Thanks Mark. I hear you about the four years it's amazing how long it takes to go through one of these old trucks. Your truck is gonna be so nice, all that time and effort will pay off in the end.
#461 |
Mark I just went out and measured my 4 core mounts. The rubber inserts measure right at 3" from bend to bend on the inside where they bend around the top of the radiator. Should work out perfect for you. Does that radiator have Trans cooler lines in it?
#462 |
Great news. One less headache lol. No trans cooler since I am running the manual transmission. The nice thing with the radiator is the inlet/outlet are both on the passenger side so they match the ports on the LS. There is also a steam port fitting in the radiator for the LS. Thanks for taking the time to grab me the measurements Keith!
#463 |
Today I finished installing the engine harness. So far I am really satisfied with the workmanship from S&S Performance. They labeled every plug and sent a legend for each connection along with a trouble shooting guide.
#464 |
Pic 2
#465 | |
#466 |
![]() Join Date: Nov 2001
Very nice build.
Can't wait to see the finished product.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
#467 |
![]() Join Date: May 2013
I have the same radiator on my truck with 4 core mounts. It sat a little high so the upper mounts didn't want to sit on top of the core support without some persuasion. You could probably trim the rubber portion of the mounts down a little or run some small spacers between the upper mounts and the core support. I'd like to get the upper mount that Keith is running one of these days but I'm not sure how well it would fit with this radiator
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435 |
#468 | |
#469 |
#470 |
I forgot what accessories you're using with your engine and how the water pump is positioned but i used a 07 tbss upper radiator hose with mine that has the truck accessories. Glad I could help with the link. Can't wait to see your truck finished
Edit: Just looked and your water pump snout is definately different from mine
#471 |
Today I was able to get the radiator in and wire the fans. Im really happy how well it fit.
#472 |
Pic 2
#473 |
Looking good!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#474 |
Thanks Duane
![]() I have been working on all of the small details. Mounting the ECM/fuse box/relays, power steering hoses, radiator hoses and fuel lines.
#475 |
For some reason I can still only upload 1 pic at a time on IPad.
