Old 12-07-2014, 06:16 PM   #451
WiggyHD
Re: 1967 C10 Urban Retro
If you want some help with the wiring, let me know! I can get some pictures of the routing on mine to go by...
Mark
Retired Air Force/Disabled Vet
1969 Chevy C-10, On the way to greatness!
WiggyHD is offline   Reply With Quote
Old 12-07-2014, 06:40 PM   #452
Orangetonicclicc
Orangetonicclicc's Avatar
Got pictures from my powdercoater! Looks terrific!
Orangetonicclicc is offline   Reply With Quote
Old 12-07-2014, 06:44 PM   #453
Orangetonicclicc
I bought my hinges from Matt out of PA! He does such a good job! I send all my parts to him his chrome powder coating is the best flawless!
Old 12-07-2014, 06:46 PM   #454
Orangetonicclicc
Parts are on the way! I will be able to bleed my brakes and install my steering column!
Old 12-07-2014, 07:01 PM   #455
Orangetonicclicc
Mark
Old 12-08-2014, 08:25 PM   #456
Orangetonicclicc
I completed running my external wire. Had a few questions about connecting them. I have the original wire connection harness but don't know if I should just cut that connection and solder them or use a butt connection. Once I'm happy with it and confident I will put wire jackets over everything and make it clean and neat.
Old 12-08-2014, 08:30 PM   #457
Orangetonicclicc
Front external location is routed and ready to be covered, cut, and connected. Verifying my connections and confirming the wires that won't be needed. I don't intend to cut them completely. I will cut put covers on the ends and leave them in case I decide to do something different and may need them. Like an electric fuel pump...
Old 12-08-2014, 09:28 PM   #458
Orangetonicclicc
[/ATTACH]Name:  image.jpg
I've learned in my career that you don't be hasty cutting wires til you confirm your connection. Because of the Dakota Digital dash, it makes this factory connection on the Painless Wiring harness that would have went to the factory dash bezel obsolete and some of these wires will be connected to the Dakota module. But I wanted to be sure and ask one of the forum members before I make these cuts.
Old 12-09-2014, 03:33 AM   #459
Bowtie468
Bowtie468's Avatar
PM sent with answers to your questions .
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 12-13-2014, 07:22 PM   #460
Orangetonicclicc
Built some ground straps for my truck. Grind down the frame for good connection. This one goes to the frame to the bed.
Old 12-13-2014, 07:27 PM   #461
Orangetonicclicc
Made a ground strap from the back of the passenger heads on the engine to the frame. I still need to add one to the frame to the cab. I may also make some smaller ones going to the valve covers as well and one to the core support to give my headlights a good ground. I researched this and you can never have enough grounds!
Old 12-15-2014, 10:19 PM   #462
Orangetonicclicc
Got my powdercoat parts back today! I can finally see if these headers are going to match to these pre-bent brake lines...
Old 12-15-2014, 10:34 PM   #463
Orangetonicclicc
Fits like a glove!
Old 12-15-2014, 10:45 PM   #464
Orangetonicclicc
Now back to wiring
Waiting on my Go Keyless RIFD Pushbutton start/alarm. Installed my floor dim switch. Pretty simple but I had to make a hole in the carpet. I used my solder tool. Painless kit comes with a dim switch, head light switch, windshield wiper and the ignition and a few more like the dome light switch connects. Makes things easier. I've decided to purchase Dakota Digital's Electric fan controller! Easier wiring and it gives me the ability to set my fans anyway I want! (I have no reason why this thing is side ways!)
Old 12-16-2014, 06:18 PM   #465
slowcpe
slowcpe's Avatar
Just spent the better part of my work afternoon reading you thread. Awesome build and can't wait to see it on the road. Love the color.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 12-16-2014, 06:22 PM   #466
Orangetonicclicc
Originally Posted by slowcpe View Post
Just spent the better part of my work afternoon reading you thread. :lol Awesome build and can't wait to see it on the road. Love the color.
Thanks Ryan! And you can be sure, I'm following Laymond! Love the name!
Old 12-16-2014, 09:47 PM   #467
Orangetonicclicc
Decided to make disconnects for my relocated fuel tank. Did some grounding and continuity checks too,all through out the truck. The inner cab is grounded next the core support.
Old 12-16-2014, 09:49 PM   #468
Orangetonicclicc
My ManCave! Once I'm not spending money on this truck maybe a pool table and big screen TV???
Old 12-16-2014, 10:16 PM   #469
slowcpe
slowcpe's Avatar
A big screen is a must! Couldn't live without mine.
Ryan
Old 12-18-2014, 07:29 AM   #470
Orangetonicclicc
Took these pictures to show age a member how far my engine set behind my radiators. I'm glad the headers forced me to set the engine back more you can see my serp set better!
Old 12-18-2014, 07:42 AM   #471
Orangetonicclicc
Hey guys I'm putting electric remote locks in my doors. What can I do to make the wires look neat and custom from the door to the cab? I gotta drill 2 holes one in my door and in my cab in the door jam area on fresh paint which suxs! But I'm sure that make a grommet and loom to clean it up neat?
Old 12-19-2014, 07:02 PM   #472
Orangetonicclicc
Thanks to Chris (BOWTIE468), I made me a 4 connect Weatherpack Connect for my tailight harness! I used my extra length of wire and made a female and male end. Now I can cut the old one and slide braided loom over the wires, splice it with solder cover it with heat shink and button it up neatly!
Old 12-21-2014, 01:38 AM   #473
Orangetonicclicc
Still collecting electrical components and hardware for this wire installation Dakota Digital Electric Fan controller and Stainless braided door jam wire loom for my electric locks for my alarm.
Old 12-24-2014, 10:03 PM   #474
Orangetonicclicc
Final wire installation is underway! Still waiting on my push button start! Trying to figure out my back up light connection as well! And where to install my relays for my electric fans! High Temp wire loom is ran. Now final connections for the headlights can be done!
Old 12-25-2014, 08:48 PM   #475
Orangetonicclicc
Preparing for column install. Need to get a limit switch. Finally starting to click. Waiting on parts! I love the fact that you can get a great deal in my parts from vendors, but I hate the wait.
1967 c10, chevy truck, classic truck, short bed
