11-24-2013, 11:43 AM | #451 |
Re: Our "What are we going to do?" 66 Suburban Build
the new place is looking great, I've have to stop by again after the new yr! we're moving to Tulsa with are income tax! nice jeep didn't see it the last time I seen you guys! I still love those rear tires, i'm working on getting mine done! I hope by summer i'll have everything worked out
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
11-24-2013, 11:54 AM | #452 |
Hey Chad, good to hear from ya. I didn't have room at the old place for the jeep...kept it at a buddies house. I've taken it all over Cavanaugh...good times! Tulsa will be nice, we lived there for 4 yrs. The engine in yours looks great, really like the color combo/details!!
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
11-24-2013, 10:03 PM | #453 | |
Rollin' Old Skool
Cool Jeep for sure!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
11-25-2013, 12:40 AM | #454 |
I hear ya on never enough space, but it's amazing what can be accomplished in little to no space. That jeep was initially built primarily in a normal garage with not much more than a torch, welder, and grinder...lots of grinding discs . To get it in and out of the garage, I put tiny tires on the front, pulled the rear tires off, and drove it in and out on a floor jack under the rear.
Like most of us here, you do what you can with what you have...it's definitely easier with more space and better tools though!
11-25-2013, 01:49 AM | #455 | |
Rollin' Old Skool
11-25-2013, 02:26 AM | #456 |
60-66 Nut
Wow nice
Ram Jet 502? My son got his buggy going earlier this year and has been working on getting the bugs out.
11-26-2013, 01:05 AM | #457 |
Thanks Cap!
Very clean buggy, that looks great! Y'all need to bring that down to our neck of the woods! Started with a HO502 (iron rectangular port heads), worked the heads, custom cam/computer/tune, port matched the Ram Jet intake to the heads, worked the throttle body a bit, and swapped in some higher flow injectors...had Mena Street and Performance do all the intake/TB/Comp/tune work...it runs extremely well
11-26-2013, 02:25 AM | #458 |
60-66 Nut
Thanks for the compliment
I'm pretty proud of him having done most of the build himself. He learned a lot and gained an appreciation of what it takes to build a rig from scratch. The drivetrain in the buggy is a turbo'd 4.3 V6, Holley TBI, full manual TH350, Dana 300 with the Lowmax gear kit, Dana 60 front and rear, ARB front welded rear.
12-10-2013, 03:14 AM | #459 |
it may be a shot in the dark, but do you still have that oem fan shroud?
12-12-2013, 12:39 AM | #460 |
No, sorry. That's long gone...
12-17-2013, 05:31 PM | #461 |
Just noticed the nice rocking chairs and your stand up heater in the shop. What type of ventilation do you have in the roof of the shop? That heater could cause you guys some trouble if not well vented. The board lost a fellow in San Diego County last year to carbon monoxide poisoning, stay safe guys! You contribute way to much to the board to have anything bad happen to you.
01-11-2014, 08:56 PM | #462 |
Wow, just awesome work all around. I have been on this board for a couple years and never looked at this build, my loss. Just read all of it. Great work, great ideas, great family build. Loved it!
01-12-2014, 04:35 PM | #463 | |
Thanks earl84! It means alot to us to hear that others enjoy what we're doing!!
01-18-2014, 05:03 AM | #464 |
Been gathering parts for a few weeks...my boy and I started swapping parts earlier this evening...gonna see how far we can get over the weekend!
01-18-2014, 02:43 PM | #465 |
that loks like a busy weekend with a great return
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 |
01-19-2014, 04:18 AM | #466 |
More like a busy weekend with a poor return...
We swapped out the Pro Comp HEI dist (get what you pay for) in favor of a MSD dist/coil/box set-up chasing a dead #2 cylinder...it wasn't the ignition! Dug a little deeper and found the problem...we think that it's been this way for a little while. Ran pretty good with no noise that we could recognize for longer than we care to admit!!! There may have or have not been a time (or two) that we over revved it goofing around We're thinking that the 2" or so piece of broke off push rod found its way to the pan with out causing to much damage...nothing obvious visually, by ear, or gauges?? Gonna drop a couple new push rods and a rocker on tomorrow and see what happens
01-19-2014, 12:02 PM | #467 |
Junk Yartist
X2 on the Pro Comp distributors. Garbage.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
01-19-2014, 03:50 PM | #468 |
Good old stock rocker arms, never use them, can't be trusted for abuse and I abuse everytime I drive. Looks like good pushrods, well were.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
01-19-2014, 04:08 PM | #469 |
ouch that sucks ..could thing you found it now without blowing a hole in the block
01-19-2014, 07:17 PM | #470 | |
Yea, I've always been suspicious of them...this one, I guess, is alright. What we've got now is much better...good upgrade.
Yea, got lucky (so far) with this little deal.
01-19-2014, 07:27 PM | #471 |
Let us know how the big block works out, hope all is well, sounds like it will be.
01-20-2014, 12:25 PM | #472 |
60-66 Nut
Good idea. I always upgrade to 3/8 pushrods on a performance big block.
01-20-2014, 01:24 PM | #473 |
All big blocks are 3/8's pushrods, just crappy ones, you upgrade to 7/16's rods. but takes some work.
01-20-2014, 02:29 PM | #474 |
Older BBC, yes...newer BBC will/may have 5/16 push rods. Our set-up is 049 heads on a Gen VI block, but ended up with 5/16 push rods.
Irregardless, we gonna make it better!! My son should be rounding up parts now...will post up later.
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread Last edited by RockTonka; 01-21-2014 at 01:53 AM. |
01-20-2014, 06:04 PM | #475 |
Oh I am used to an older big block, wow that is sad isn't it to use a 5/16, well at least a good quality 3/8's will be better. hope it works out alright for you. Love my big block, makes my day everytime I fire it.
