Old 01-17-2021, 11:30 PM   #451
Just call me Sean
Just call me Sean's Avatar
Re: What did you do yo your truck today??
Worked on the '99. Spliced the gas gauge wires, have to see how it works but I think it will need the sender. Changed some PCV thing that had broken clip ears and would blow off sometimes with a big smelly puff of smoke. Added the missing headlight/key in ignition buzzer. I have the DRL module that was missing but I'm not sure if I want to put it in.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 01-23-2021, 04:11 PM   #452
Gunner41
Gunner41's Avatar
Same thing I have the past week. Trying to figure out why my Aux fan will not work on my 3500? Ughhhhh
Gunner41 is offline   Reply With Quote
Old 02-02-2021, 02:34 PM   #453
Just call me Sean
This damn thing keeps blowing off. It's new, busted the ears off like the one I replaced.
Old 03-14-2021, 06:23 PM   #454
Just call me Sean
I've been hearing this noise, sounded like the alternator bearing. The noise got pretty loud today, so I removed the alternator belt and started it up. Well... it was the alternator bearing making noise, but the louder noise was something separate. I think the transmission is close to dying. I just put that thing in there, and it looked recently rebuilt.
Old 03-14-2021, 10:51 PM   #455
Just call me Sean
Had a chance to check it out better. Luckily not the transmission, but the noise was pretty close to it.
Old 03-15-2021, 12:07 AM   #456
Just call me Sean
So this dust shield whatever thing broke off, so I had to cut it off. Bearing is fine. That's all I can do tonight, have to pick up the mount and alternator tomorrow.
Old 03-15-2021, 11:34 PM   #457
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
The Boss (Grandson) wanted to Help And I Had To do Front Brakes And Wheel Bearings
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 04-24-2021, 03:38 PM   #458
Just call me Sean
The temperature door motor for the '99 is bad. I managed to get it to open to cool and unplugged it, so I have a/c again.
Old 04-24-2021, 08:48 PM   #459
Just call me Sean
I changed the master cylinder reservoir on the '93. Hopefully that will stop the leaking. I changed the master cylinder twice.
Old 05-14-2021, 07:12 PM   #460
Just call me Sean
Sudden tire failure at 70MPH on the expressway while pulling my trailer. Chewed up the rim a bit.
Old 06-24-2021, 09:56 PM   #461
Just call me Sean
Re: What did you do to your truck today??
Picked up a hitch from the junkyard. I'm going to have to cut the old one off my truck.
Old 06-26-2021, 09:29 PM   #462
Just call me Sean
A few pics of the old hitch.
Old 07-05-2021, 11:42 PM   #463
Gunner41
Gunner41's Avatar
Pulled off my grill to find power steering pump cooler leak and fixed. Now I replaced my gtill and Im pulling my hair out trying to find a 97 3500 Grill emblem that doesn't cost $100+. I cant help it I like the gold look on the grill.
Old 07-06-2021, 05:36 AM   #464
I like the gold bowties, too. Nice gold bowties! Dang, $100.
The announcement I need to make is I greased up the front end on my Suburban Saturday morning. Not your ordinary lube job here. The driver side upper ball joint zerk wouldn't take grease. No problem I figure. I have a bunch in my bins. Oh shoot, metric! No can do. I make a Saturday evening run for metric zerks. Sunday evening I put the new zerk in and greased her up. So it took two days for that lube job
Old 07-06-2021, 07:48 AM   #465
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Installed an upgrade OE radio and a CD player.
Old 07-11-2021, 12:31 PM   #466
Nice. I have one, too, and an upgrade steering wheel to install. I need to replace the multifunction switch in the column, so the wheel goes on then. And the stereo will go in when I replace the heat/AC control panel, once I find one.
Old 07-15-2021, 09:23 PM   #467
Just call me Sean
The '99 started misfiring the other day, and since I know the timing is off I figured it's the distributor cap and rotor. Picked up a brass terminal one and it's running as it was. I think my brother or one of my cousins has the thing I need to set the timing so I don't toast the new cap. I'm not sure if I can use the old bad one to do the cut a hole in it trick but I might try anyways.
Old 07-16-2021, 03:48 PM   #468
Just call me Sean
Still good for a spare?
Old 07-18-2021, 01:28 PM   #469
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Added a dash mat. I’ve used these for years in my cars. Really helps cut glare.
Old 07-18-2021, 03:08 PM   #470
Snarl95
Snarl95's Avatar
Replaced steering damper and alternator.
1995 k3500 cclb srw 6.5 turbo diesel.
The lessons that hurt are the lessons that teach.
There is always a price to pay.
You are free to make any decision you want. You are not free from the consequences.
Snarl95 is offline   Reply With Quote
Old 07-20-2021, 02:16 PM   #471
LT7A
Siping.
Old 07-20-2021, 10:40 PM   #472
Just call me Sean
Originally Posted by LT7A View Post
Siping.
Three more and I'll be set.
Old 07-24-2021, 01:58 PM   #473
Snarl95
Snarl95's Avatar
Replaced radiator.
Old 07-30-2021, 03:56 AM   #474
mikelom
I just rotated the tires and fitted the new air filter.
mikelom is offline   Reply With Quote
Old 07-31-2021, 09:19 PM   #475
Just call me Sean
Installed a power steering pump I got off a Cadillac. Had to change the reservoir.
