11-25-2010, 06:05 PM | #26 |
RAT1968 '68 Cab/'71 Parts
Re: front end not right!
Too bad it's easier to do this with Photoshop than in real life.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 11-25-2010 at 06:05 PM. Reason: I don't know |
11-25-2010, 08:24 PM | #27 |
laying low
Ah, wish it was that simple Magwa.
It's been a while since I took my front end apart but I don't remember there being a lot of up and down adjustment where the fender bolts to the rad support. If you manage to lower the rad support the fender and grille will go down with it.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
05-27-2012, 10:30 PM | #28 |
I too am having the same issues exactly, for the exact same reason, except mine has a new driver fender only and new (used) out grille. Everything lined up perfectly before they disassembled it. Will post pics, but they look exactly like yours. my bumper is also the same.
05-27-2012, 10:40 PM | #29 |
? is the headlight bezel installed right ? you may need to flip it 180 degrees
05-27-2012, 10:48 PM | #30 |
Yes, I made sure the screw indents are at 9 and 12 o'clock.
05-27-2012, 10:52 PM | #31 |
I did also notice that they tightened the passenger side core support bolt tighter than the drivers side. I back it off to match the amount of threads on the core support mount bolts on the drivers side, but it didn't seem to do much.
05-28-2012, 08:34 AM | #32 |
Must be alighnment somewhere in the support area mine is the same only on pass. side .I only put on a aftermarket bumper all else is original I have had my headlight out a 1000 x my gap is not as bad as yours but still off a little
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
05-28-2012, 08:40 AM | #33 |
laying low
Rather than loosening the bolts to compensate for the lean why not use some thick washers or the correct body bolt shims to even it out?
