#26 |
Re: I want to build a Chevy 327 - need tech help
The 327's are internally balanced so the only question on the balancer is its outside dimension.Most were 6.75 and the large journal were 8 inch.
#27 |
![]() Join Date: Jul 2006
If you want a true 327, they seem to pop up on Craigslist pretty regular. Usually tired old original units from impalas, trucks, etc. Perfect rebuild candidates.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#28 |
i'm keeping an eye out for them!
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
#29 |
was gonna say the same thing about Craigslist... there are several on the Houston CL right now... Cheap...
1972 GMC Sierra Grande (current truck) 1980 Chevy Stepside (gone) 1987 Chevy Blazer (gone) 1972 Chevelle SS Convertible (gone) 1973 Chevy Corvette (gone) 1967 Chevy Camaro (STOLEN!) |
#30 |
I'm in North Carolina near Asheville... if anyone knows of one, let me know
#31 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
#32 |
Yes you firefighter... so that's '72 crank accessory pulley, what is that.. a 4 groove pulley?
#33 |
In 72, the crank pulley like that was actually two pulleys bolted on top of each other. If the truck didn't get power steering and AC, it just used one pulley
![]() ![]() ![]() Posted via Mobile Device |
#34 |
firefighter, what a nice motor man, nice details
#35 | |
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#36 | |
Thanks for the insight Insidious!
#37 |
#38 |
http://asheville.craigslist.org/pts/3639977777.html
http://asheville.craigslist.org/pts/3761649804.html http://charlotte.craigslist.org/pts/3723283825.html http://charlotte.craigslist.org/pts/3753043211.html http://charlotte.craigslist.org/pts/3754223993.html http://charlotte.craigslist.org/pts/3748592940.html http://charlotte.craigslist.org/pts/3770478849.html http://winstonsalem.craigslist.org/pts/3738836248.html http://winstonsalem.craigslist.org/pts/3679730545.html http://wilmington.craigslist.org/pts/3744745659.html Here are some North Carolina 327's on Craigslist. |
#39 |
yep, working on these today...
#40 |
If you do the 307 crank in the 350 block it will get you a cheap 327. Just remember that the 307 crank is cast and not forged like GM used in 327, also that the 307 crank was made for the standard pedestrian market....not the high performance market. I would not play with a big cam or high RPM in a cast crank 327. GM did make a very limited number of forged 327 large journal in early 1969 (read rare and very expensive). Like said earlier, check with one of the crank manufactures to find a large journal 3.25 stroke crank and install that in a 350 block. I like the 327 too, but drive a 406 SB and you'll never look back (sorry could not resist). The balancers for the all SBC built between 1969 and 1986 (2 piece rear main) will work for a 327 fine....EXCEPT the one for a SB 400. This is also true for the flexplate/flywheel.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
#41 | |
thanks for the added info...
#42 |
I had a 327 in a 78 Malibu I had over 10 years ago. It was rebuilt, had a Holley 600 and some alum intake. Cam was either stock, or very mild. When I took the car for a test drive, it smoked the sh!t out of the one legged right rear tire. Granted it was a 14" tire, but anyways the motor did run good. I pulled the motor out after it developed a knock, put in a 400. I pulled the heads after I got the motor out, couldn't find anything about the heads, casting numbers didn't come up anywhere. I don't remember what the numbers where, but there was some on the pistons. I told them to builder, he told me they were 350 flat top pistons. After that, I looked at the pistons, and they were 1/4" below the deck!!!! How it ran I don't know, but it did run good. I for one like to be different, but it's really hard to beat a 400. The one I swapped in had well over 100k on it, and I put 60k at least on it before I had the 468 built.
And I forgot bout the small/large journal cranks, my 327 was from a 69 Camaro, IIRC the casting number was the same as a 350, or one digit off....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
#43 | |
#44 |
so a 8 inch balancer will fit on an engine with a fixed timing tab meant for a 62-68 327?
