09-27-2015, 12:44 PM | #26 | |
Re: main differences between 73-79, 81-87
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-28-2015 at 07:00 AM. |
09-27-2015, 12:48 PM | #27 |
What's the difference in C/K vs R/V?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
09-27-2015, 01:09 PM | #28 |
In 1975 catalytic converters were standard on all pickups under 6,001 lbs. GVW
09-27-2015, 08:34 PM | #29 |
They are the same (except for the model year and TBI).
The designation was changed to avoid confusion with the new GMT400 models, which retained the C/K codes. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-28-2015 at 06:55 AM. |
09-27-2015, 08:45 PM | #30 |
02-25-2017, 09:35 PM | #31 |
i was wondering if the grill from a 85 will fit my 81 i can't find it anywhere else and just want to be sure before i buy one
02-26-2017, 12:16 AM | #32 | |
http://67-72chevytrucks.com/vboard/s...+swap+85+to+81
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
02-26-2017, 01:32 AM | #33 |
1975 was first year for cats in C-10. 1979 was first year for cats in C-20/30, K-10/20/30.
1978 was first year for electric oil pressure gauge instead of pressure-tube gauge. 1979 was the first year for gas filler doors.
Rich Weyand 1978 K10 RCSB DD. |
02-26-2017, 01:37 AM | #34 | |
Re: ??
Bear in mind that the fuel filler necks are different. Different angle, different diameter, different length. I replaced the filler necks, the filler neck hoses, and the gas tanks (the filler neck hose nipple is bigger, to address slow-fueling issue) on my dual-tank setup to get it all right. You can find the filler necks on car-part.com, which is the salvage yard search site. Hoses and tanks from LMC, etc.
02-26-2017, 08:09 AM | #35 |
[QUOTE=rich weyand;7869855]1975 was first year for cats in C-10. 1979 was first year for cats in C-20/30, K-10/20/30.QUOTE]
Catalytic converters were required by GVW. For instance, in 1977, the GVW break would have been about 6000 GVW. Our 1977 4x4 Jimmy, owned since 1979, was 6200 GVW, had original exhaust and no cat, no EGR. My 77 C1500 was 5300 GVW and had a cat. Catalytic converters were not installed on one tons until 87 and had to be fuel injected, at least in non-California domestic. Same goes for 3/4 ton. The break at that point was 8500 GVW. Under would have a Cat. over did not, unless fuel injected. In fact, through 1989, you could still opt for a carbureted one ton with stainless steel dual exhaust, leaded gas spec. They still had the large hole filler necks like the diesel. I can confirm this on both my 83 and 85 K30.
83 K30 SRW 350 TH400 NP205 4.10 9' Fisher 85 K30 SRW 350 TH400 NP205 4.10 87 V3500 Dually 454 TBI SM465 NP205 4.10 9' Fisher 83 K2500 350 TH700R4 8600GVW Dual Tank 4.10 1973 Cheyenne Super 30 DRW Std Cab Z83 4.10 1976 Silverado C30 Std Cab 4.10 DRW (4 sale) |
03-01-2020, 09:17 PM | #36 |
I have a 1975 Chevy truck with some cab damage(they don’t make repair panels for this location), I was wondering if I could use a 1986 cab for parts. The damage is behind the door on the passenger side of the cab.
03-02-2020, 11:22 AM | #37 |
Yes in that area everything should be the same so you can use it as a donor.
1982 Sierra Classic K15 RC/LB 6.2L Diesel 700R4 1988 GTA Trans AM 305 TPI 700R4 1993 Formula Firebird LT1 T56 1995 GMC K2500 ECLB 6.5L 4L80E 1996 GMC K3500 CCLB LB7 6L90 |
03-02-2020, 09:42 PM | #38 |
73-80, Different Hood, Radiator Support, Fenders/Inners, Front Bumper that I know of, I know the Glass in the 73-80 Trucks was Thicker than 81-87 and some other little things.
Bed should be the same as Doors, Round hole was until 78? I think The Square came into play in 79. |
07-09-2022, 10:28 PM | #39 |
Except the trailering special- my 77 does not have cats
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
07-09-2022, 11:13 PM | #40 |
Seatbelts were different throughout the years.
73-75 were Lap Belts 76/77 was the 1st Style 3pt shoulder belt. 77-86 was the more common 3pt that you see a lot of. 87 they changed the style leading into the next generation of trucks. And the 87, because it changed to a longer lower profile belt, it has to use this extra mounting tab.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR Last edited by TKCR; 07-09-2022 at 11:32 PM. |
07-09-2022, 11:25 PM | #41 |
There we a lot of different variations of buckles on the seat belts throughout the years also. My favorite, are the lap belts buckles.
Then there are a couple different styles of plastic buckles. And then the metal buckles.
07-13-2022, 09:46 AM | #42 |
Here is what I have learned from putting a 2wd 75 body on an 84 4x4 frame, parting out some of the 73-80 trucks and owning an 84 M1009 CUCV.
1) The very front section of the frames where the bumper mounts are different. 2) I had to drill new holes in the 84 frame to mount the 75 box for the second set of bed bolts from the cab (Never seen this mentioned anywhere!). 3) Dash pads are different. 4) body mounts are different you need to use the ones for the year of your frame. 5) 81+ had thinner glass. 6) Tailgate mounting hardware is different. 7) Gauge cluster wiring dont seem to standardize until 76-77?. 73-75 have an amp meter instead of voltage meter and trying to use different year gauges without redoing the wiring can result in burning wires. 8) Power steering boxes, hoses, and hydroboost units - 73-80 have SAE fittings and 81+ have metric fittings. 9) Windshield washer pumps on the early trucks are built into the wiper motor. 10) Windshield washer buttons are on the dash instead of on the column. 11) High beam switch on the floor until? 12) Steering columns between 73-80 and 81+ use a different spline or D shape (I forget the exact difference but the popular xj shaft mod isnt as bolt on on the earlier trucks as the later ones. 13) Ebrake setups are completely different including the backing plates on the FF 14bolt (not sure about other axles). 14) 73-? use glass fuses instead of the blade type in the fuse boxes. 15) The np205 mount rod between the trans and transfercase stopped being used at some point? I have friends with 81+ trucks and everytime I think "I have one of those!" the 73-80 stuff I have doesnt fit the 81+. Basically assume the 73-80 parts wont fit the 81-87 and visa versa, they are as different as a similar truck can be. Compatibility does seem to increase with every year but the 73-75 (maybe 76?) trucks are headaches as far as compatibility with the older years. |
07-13-2022, 08:54 PM | #43 |
07-13-2022, 09:55 PM | #44 |
Front ends.
07-14-2022, 09:37 AM | #45 |
07-14-2022, 06:35 PM | #46 |
Oh good! I thought maybe I was crazy.
