Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Old 09-16-2004, 09:17 PM   #26
1972C10
1972C10's Avatar
Parts Still For Sale You need it name it This truck is going to be tottaly stripped down to nothing all chassis parts disc brakes rearend spring you name it .
1972C10 is offline   Reply With Quote
Old 09-18-2004, 07:01 PM   #27
1972C10
1972C10's Avatar
More Parts/ Details Added
Trans if for sale again Last guy Local Not a board member Was a deatbeat so its for sale BTW It has an electric speedo.
Windsheild Washer Resivoir & pump Works Tested. 30 Shipped , This would be a good piece to adapt into an older truck Since the pump is in the tank.
Overflow tank Missing Cap Dirty .. 10 Plus Shipping
Charcoal Can ? 5$
Headlight Harness The Wire Loom Is Cracking But Otherwise In Good Shape 40$
Grille Good Shape 45$
Headlight Buckets 30 And Thats The Pair
Wiper Motor 30$
Fuel Tank No Leaks W/ Fuel Pump 75$ Local Pickup ONLY.
DriveShaft Truck Had Th375 55$ Length " Coming Soon"
More Parts/Prices/Descriptions/ Coming Soon At the moment i cannot upload pics but as soon as the new cord for my camera arrives from ebay i will be happy to
Please Pm With Any Questions On Mentioned Parts Or Something You May Need Not Mentioned.
Once again My Local Zip Is 75474
Old 09-20-2004, 07:07 AM   #28
1972C10
1972C10's Avatar
Windshield waser pump SOLD>..
Pair Of Hood Hinges With Bolts that attach to the truck 35$ Thats 4 the pair + Shipping.
Cowling Plastic With Screws and end pieces They have white overspray on them but it would prolly remove with thinner.
40$ + Shipping
ABS Controller? Black box With Valve 45$ + Shipping
Power brake booster With Master Cylinder 65$ + Shipping
Instrument Cluster Shows 275K Miles Its Warning Lights Speedo & Gas Gauge 40$ + Shipping Has PRND21 Indicator But needs repair ? the little cable isnt attached.
Horn 15$ , Windshield wiper Under Cowl Setup With Both Shafts and all still attached .. 35$
Automatic Shifter Linkage From Colum To Trans Including Trans Bracket and adjustment bracket for the colum 40$
More to come as items are removed/Inspected Pics coming soon.
Old 09-24-2004, 02:51 AM   #29
1972C10
1972C10's Avatar
Driveshaft Length Is 68 1/2 inches from u joint trunion to u joint trunion .
Blue Seat Belts Could be Used to convert 67-72 to shoulder 50$ thats the full set Im not sure about the middle belt it may be under the seat i havent pulled them yet.
Blue Glovebox Door 25$ Blue Instrument Cluster Surround Pad 25$ Blue Non Casset Player Center Dash Piece 25$ Blue AshTray Assembly all intact 30$
Automatic Transmission Crossmember 45$
Rear Speaker Grilles 25$ Blue..
BTW the windshield wiper motor is only two speed No delay.
Inner Fenders 25$ Each
Core Support 65$
Cab Has hole where vhf antenna was for highway department otherwise in good shape 200$ I can weld hole up upon request.
Old 09-27-2004, 11:17 PM   #30
1972C10
1972C10's Avatar
Emergency Brake Pedal Setup 35$
Brake Pedal 25$ For Auto..
Gas Pedal Assembly W Cable 45$ Cable Seperatly 20$ Gas Pedal Assembly Minus Cable 30$
A/C Controls W Black Buttons Works 25$
Old 09-28-2004, 10:25 PM   #31
1972C10
1972C10's Avatar
Here are some More pics Of the parts
Old 09-28-2004, 10:29 PM   #32
1972C10
1972C10's Avatar
Few more O yeah Cheap Mirrors Came off 89 but are autozone specials
25$Shipped
Old 09-30-2004, 06:13 PM   #33
FirstGen
Just Don't Stop!
FirstGen's Avatar
what about the front discs, spindles, hubs, calipers, all that stuff??? Would also need the tie rods. How much? I can come get the stuff if it's in DFW.
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 09-30-2004, 06:44 PM   #34
1972C10
1972C10's Avatar
The tierods may have wear on them it had some slack Id give you the entire front end cut off the frame for 125 You pick it up .. Im located in Quinlan 75474 Do a mapsco and see if you would want to pick it up Its around 68 miles east of dallas.
Old 09-30-2004, 07:49 PM   #35
FirstGen
Just Don't Stop!
FirstGen's Avatar
They are 6 lug correct?
TT LSA/6L90e/9"
Old 09-30-2004, 08:41 PM   #36
1972C10
1972C10's Avatar
Nope its 5 on 5 Its not a light duty 2500 Its a half ton.
Old 09-30-2004, 08:46 PM   #37
FirstGen
Just Don't Stop!
FirstGen's Avatar
****, I'll think about that
TT LSA/6L90e/9"
Old 10-05-2004, 12:13 AM   #38
1972C10
1972C10's Avatar
Few more pics added Will Take 40$ For the evap coils and all hardware that atttachs it It looks ruff but system had freon in it still so no leaks.
Old 10-06-2004, 05:44 PM   #39
hilbilly
I do everything twice, so what
hilbilly's Avatar
Location: To the Right. One may go as far to say WAY to the Right
Man, I could use a d/s fender and door
hilbilly is offline   Reply With Quote
Old 10-06-2004, 07:20 PM   #40
1972C10
1972C10's Avatar
D/S Fender and D/s Door pics Coming Up. Is there a greyhound Bus Depot Around You? Thats the only way i know of to ship large items such as doors. The fender isnt al that heavy it should go ups no prob but the door is another story.
Old 10-06-2004, 08:25 PM   #41
1972C10
1972C10's Avatar
The door is a little whomperjawed in the two pics of close up . and the inerts dont go with it
Old 10-06-2004, 08:51 PM   #42
1972C10
1972C10's Avatar
Few Mo
Old 10-07-2004, 09:20 AM   #43
hilbilly
hilbilly's Avatar
How much for the d/s door (striped, I could really only use the skin) and fender. Do you inbound/outbound freight at work. I can send an LTL carrier if you can put the stuff on a skid.
Old 10-07-2004, 09:51 AM   #44
1972C10
1972C10's Avatar
I had been asking 65$ for the fender and 70 for the door but if you want both 150$
By Skid Do you mean pallet? Im not certain as to where i could take it A Place i used to work at has yellow friend pick stuff up daily but i doubt they would let me send anything out their dock.
Old 10-07-2004, 11:07 AM   #45
hilbilly
hilbilly's Avatar
Thanks for trying
Old 10-07-2004, 05:02 PM   #46
1972C10
1972C10's Avatar
Greyhound ships large items. Is there a bus depot near you?
Old 10-08-2004, 09:33 AM   #47
hilbilly
hilbilly's Avatar
Yes, but it will cost twice as much to ship. I'll just keep searching the scrap yards.
Old 10-08-2004, 06:17 PM   #48
1972C10
1972C10's Avatar
I heard there is a place in greenville called Tex Pack Im going to try to get ahold of them and see details What Carrier would you be using.?
Let me know some details .. and whether or not you want me to check into it I just heard about this place today.
Old 10-08-2004, 08:47 PM   #49
Blue_71
Bloo
Blue_71's Avatar
does it still have the tailgate? if it does, i need the handle, the handle surround, the rods to the catches, the catches, and both trunions. how much for all of that?
Blue_71 is offline   Reply With Quote
Old 10-08-2004, 09:19 PM   #50
1972C10
1972C10's Avatar
I saved the tailgate for my new truck .. It wasnt much count anyhow the tailgate surround was missing and everything else is smooth worn out . I will however keep my eyes peeled .. Not too long ago i threw away a tailgate that was caked with bondo but was a low use tailgate and had all that stuff
