Old 05-04-2005, 11:44 AM   #26
bagged81
Signals in the bumper.
bagged81's Avatar
Originally Posted by grnddwn
Do both!
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 05-04-2005, 11:44 AM   #27
fastbagged68
fastbagged68's Avatar
If you ditch the top plate you will have to get a cup for the upper mount and cut it to lay out your crossmember. Other option is to get a smaller 20" tire. If your tire is about the same size as whats on a dodge ram 20 it is a 275-55-20 = 31.9 " Drop your tire size to 28" and I guarantee it will lay the crossmember.
fastbagged68 is offline   Reply With Quote
Old 05-04-2005, 01:26 PM   #28
loweredd
www.loweredd.com
loweredd's Avatar
Dont worry about the crossmember, Z the frame, and be done with it. Mine layed out with a 32" tall tire.
loweredd is offline   Reply With Quote
Old 05-04-2005, 05:36 PM   #29
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
How much did you Z yours?
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 05-04-2005, 05:45 PM   #30
loweredd
www.loweredd.com
loweredd's Avatar
Measure, Measure, Measure, Measure, Measure, Cut, Weld.
www.loweredd.com
Go to Frame Z
Old 05-05-2005, 09:28 AM   #31
bagged69c10
I think my tires are 275/45/20 or 275/40/20.
1965 c-10 long bed
1993 Sierra x-cab
Old 05-05-2005, 09:43 AM   #32
loweredd
www.loweredd.com
loweredd's Avatar
275/45/20 is what is on mine. They will lay NO PROBLEM. Just get to the shop and start cutting already man!!!
Old 05-05-2005, 01:04 PM   #33
bagged69c10
My shop also happens to be my driveway so I really need to make sure I know what Im doing before I tear into it.
1965 c-10 long bed
1993 Sierra x-cab
Old 05-05-2005, 07:54 PM   #34
DM310
then do this. buy a extra crossmember and chop it. when you are done you can take a day to swap it out then you can see if its good enough. if not then z the frame.
66 C10 (under construction)
1.5" crossmember drop
2" Z'ed frame
8" rear notch
Watts-link
Bagged
DJM 3" spindles
DM310 is offline   Reply With Quote
Old 05-08-2005, 04:27 AM   #35
BK
BK Built
BK's Avatar
mines z-ed 4", got the idea from loweredd, just buck up and do it, its easy, and you can be way low on big rims, mine should lay on 22's with small tires until i decide to biuld a full frame.
BK is offline   Reply With Quote
Old 05-08-2005, 12:50 PM   #36
SCOTI
SCOTI's Avatar
Loweredd & DroppedChoppedPanel . . .....
How many miles have you each put on your vehicle since you did this "piece of cake" modification?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-08-2005, 03:16 PM   #37
SkyBlue72'
YES, I also want to know how many miles have you all put on your vehicles with either a z'ed frame or a chopped crossmember or both?
SkyBlue72' is offline   Reply With Quote
Old 05-09-2005, 01:16 PM   #38
bagged69c10
I talked to a local shop over the weekend and they said that Zing the frame is easier. They have done the crossmember in the past but now they just Z it. Oh yea Im also on a tight budget.
1965 c-10 long bed
1993 Sierra x-cab
Old 05-09-2005, 01:58 PM   #39
loweredd
www.loweredd.com
loweredd's Avatar
Are you implying I cant weld?
Before I had the 20's on there during the winter, I probably put 5000 miles on it.
Why do you ask?
Old 05-09-2005, 01:59 PM   #40
loweredd
www.loweredd.com
loweredd's Avatar
How is this NOT a piece of cake modification? It's just about the same thing as putting in a rear notch!
Old 05-09-2005, 07:11 PM   #41
SCOTI
SCOTI's Avatar
Before I had the 20's on there during the winter, I probably put 5000 miles on it. Why do you ask?
No. I'm not implying anything. I asked simply for verification of actual road testing after completion of this mod.
I was mainly curious of any pitfalls that might have been discovered.
I wouldn't say it's just about the same. Thats oversimplifying the amount of work involved.
A 'c-notch' doesn't mandate:
  • complete disection of the frame rails
  • removal of suspension pieces
  • removal of sheetmetal (depending on the year of the vehicle)
  • additional fabrication because of the notch
'Z-ing' the frame:
  • requires complete disection of the frame rails
  • requires removal of @ least some suspension pieces
  • requires the removal of the front sheetmetal (or if creative, you must @ least unbolt some of it)
  • requires further modifications to other affected areas (steering linkage, radiator connections/shroud, trans tunnel)
All that plus you don't have to triangulate for a c-notch (unless installing a step-notch) but it's pretty important for 'z-ing' the front suspension.
This isn't a slam on you personally. I just don't want someone w/limited skills to cut up their truck thinking this is a "piece of cake" mod. It requires some amount of skill to pull off. 'C-notches' can be installed by those w/limited skill (some don't even require welding & will bolt in place).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-09-2005, 07:51 PM   #42
KdawgS10
keller
KdawgS10's Avatar
I belive he was tlaking about a 8 peice step notch.
and yahoo can put in a 2" C
"complete disection of the frame rails"
yes you do. if thier is any other way of doing let me know.cuz evry time I go to put in a 8" notch on a 4" frame it ends up cut in half
"removal of suspension pieces"
hmm..... unless your just doing bag over leaf you usally take ot the alxe and leafs. and if you ARE installing a rear notch your usually changeing somthing.
blocks/4link/taking out leafs.
"removal of sheetmetal (depending on the year of the vehicle)"
I dont know what your working on but on EVRY truck its 100% easyer to work ont he rear with out the bed on. and its usually harder to get the bed off then it is the front clip.
andf what about the gas tank in the rear? I allwaysd take out the gas tank. I have never liked the idea of welding around a tank.
"additional fabrication because of the notch"
evry time I have ever done a notch. I have allways boxed the frame/bag brackets/ shock relocating. or some other fabricating of that efect.
cutting hole int he bed floor/brake line rerouting/wire rerout/exast
83 1ton 4door dually, 350/700r4
99 S10 2.2/5speed bagged. traded for the dually
91 S10, 2.5/5speed juiced
87 3/4 4x4, 350/4speed
89 S10 long bed , 2.8/5speed
65 chevy short bed stepside, 327/3speed
97 neon acr, 2.0 dohc 5speed DD
KdawgS10 is offline   Reply With Quote
Old 05-10-2005, 12:19 AM   #43
SCOTI
SCOTI's Avatar
Originally Posted by KdawgS10
...I belive he was tlaking about a 8 peice step notch.
You believe he was? Thanks for clearing that up for me since he didn't type step notch.
Perhaps you should re-read my post. I clearly & concisely stated 'c-notch'. No mention of an 8" notch.
What if it's just a coil spring truck? Does the rear axle need to be pulled? No, it doesn't. Air over leaf doesn't require disconnecting the rear axle or brake lines either.
I dont know what your working on but on EVRY truck its 100% easyer to work ont he rear with out the bed on. and its usually harder to get the bed off then it is the front clip. ...... andf what about the gas tank in the rear? I allwaysd take out the gas tank. I have never liked the idea of welding around a tank.
On some trucks, a 'notch' (c-notch), can be installed w/o removing the bed. It might be easier w/the bed off, but it can be done w/o removing sheetmetal. Not all trucks have the gas tank near where a 'notch' is installed. But, even if you have to remove the bed & gas tank, it's less work than pulling a front clip, suspension, & drivetrain. All that work is part of what makes 'Z-ing' harder to do.
evry time I have ever done a notch. I have allways boxed the frame/bag brackets/ shock relocating. or some other fabricating of that efect.... cutting hole int he bed floor/brake line rerouting/wire rerout/exast
There are several 'notch' kits available through the aftermarket that don't require boxing the frame & can be bolted on (or welded if that's preferred).
I wanted to be sure my post wasn't taken as a slam, hence the first sentence in the quote above. I suppose my mistake was instead of pointing out the obvious, I should have asked Loweredd to be more specific about his statement.
Maybe the statement should read "it's no harder than fabricating & welding in a rear step notch".
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-10-2005, 12:55 AM   #44
KdawgS10
keller
KdawgS10's Avatar
he ment step notch. even you know that. your just trying to make a stink out of a word he missed.
and I ment
anyone with a sawsall can put in a 2" C notch.
Old 05-10-2005, 07:29 AM   #45
SCOTI
SCOTI's Avatar
No, your assuming again. He said 'notch', I thought notch. If he would have said "step notch', that would have 'upped' the degree of difficulty.
and I ment anyone with a sawsall can put in a 2" C notch.
Yes, a c-notch is easier to install than a step notch. We both agree on this one. Can we move on now? How about contributing instead of criticizing?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-10-2005, 07:54 AM   #46
1low1967
1low1967's Avatar
heres some of my handy work
1low1967 is offline   Reply With Quote
Old 05-10-2005, 08:44 AM   #47
loweredd
www.loweredd.com
loweredd's Avatar
OK Guys, let's not bite each other's heads off. I DID mean step notch, not c notch. Sorry for not clarifying that.
That frame looks good 1low1967!!
I understand SCOTI not wanting someone to go and hack up thier truck and not be able to get it back together, but this IS just as easy as putting in a rear STEP NOTCH. At least it was for me. I put in a 10" notch, and that was almost more work than Z'ing the front.
Old 05-10-2005, 10:30 AM   #48
SCOTI
SCOTI's Avatar
Ok, that makes sense.
I agree 100%. Nice looking job.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-10-2005, 12:57 PM   #49
DM310
all this talk about Z'ing the frame makes me want to do it now. So now I decided to Z the frame 2", so along w/ my 1.5" crossmember drop that will be 3.5". I will do it this weekend and take pics
2" Z'ed frame
8" rear notch
Watts-link
Bagged
DJM 3" spindles
Old 05-10-2005, 01:05 PM   #50
1low1967
1low1967's Avatar
Good to hear. I did 3 1/4 on mine... Remember measure 100 times cut once...Good luck and can't wait to see the pics
