10-11-2005, 11:04 PM | #26 |
You may be on to something. Or doing that to a small window cab.......just thinking.......
10-12-2005, 01:11 AM | #27 |
no, I haven't met any of the local guys here.
10-12-2005, 02:05 AM | #28 |
Thanks, ebfabman (and others). Now I have another mod I must do. It will have to wait until I figure out how to flush mount the front window though. I didn't realize you could gain that much room.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
10-12-2005, 08:22 AM | #29 |
efabman-
Could you get a couple closer shoots of the corner areas and of the area below the window. Thanks
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block |
10-12-2005, 08:36 AM | #30 |
blood type; Retumbo
I have a plan. I will go & buy a winning lotto ticket & thern after I win I will send a cab to ebfabman.
Longhornman, I have thought & contemplated the same thing for the last 4 years. the problem I see is the inner fender wells would have to be removed & replaced with a hand-made one. then the frame would also be in the way (especially after I do my 3" "Z". right now I am fearing the thought of stretching the cab. maybe I will have to try the rear wall thing like shown here. Thanks Earl.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
10-12-2005, 09:50 AM | #31 | ||
More Cowbell....
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
10-12-2005, 10:25 AM | #32 | |
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
10-12-2005, 05:40 PM | #33 |
Yeah baby!
Hey, if I did that I could beat the dents in the back of the cab out from the inside!
11.37 @116 |
10-12-2005, 06:00 PM | #34 |
i want to mount my front and rear windows flush and have been trying to find out what it takes. i wonder if newer style windshields will work...time for measurements
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
10-12-2005, 08:19 PM | #35 |
Putter, I see no reason why that couldn't be done. Another thought is to use part of the piece that was removed to connect the inner and outer panels to add some support to the back panel.
Bowtie, give me a day or so and I'll take some close up shots...thanks |
07-11-2006, 02:17 AM | #36 |
Re: *pic* of trimmed cab int. for additional seat/leg room
That is definetly a neat idea, I need to get some more experience under by belt so I can tackle some projects like that.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
07-11-2006, 08:24 AM | #37 |
Next project: 1970 K10
Wow, thanks for digging this one up! I think I have another mod to add to my list!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
07-11-2006, 11:27 PM | #38 |
I found this pic of a piece of the lower section welded back on. It gives the rear cab panel some support. Since I did this I've had the stock bench seat back in the cab and as SCOTI said, it gives about 3 inches of additional clearance
07-11-2006, 11:31 PM | #39 |
I know this might be a dumb question but how would you cut a perfectly straight line across that section.
07-11-2006, 11:50 PM | #40 |
Not a dumb question at all. I use 1/2 inch or smaller masking tape laid out where I want my cut to be then draw a line with a sharpie right along the tape edge. Then I remove the tape and use a cut off wheel to cut the line. Another way I like is to use a piece of aluminum angle as a guide and use the plasma cutter against it.
07-12-2006, 08:17 AM | #41 |
Where that lower piece would normally set against the cab, is it spot welded on, or was there some sort of adhesive to keep it from vibrating? Or does it come right off when the cut is made?
Thanks! I like this mod!
07-12-2006, 09:23 AM | #42 |
any pics of it with the stock bench mounted?
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
07-12-2006, 09:38 AM | #43 |
Yes its spot welded along the bottom edge. This cab is a '72 cab and the spot welds were not quite random but they were not all lined up. I wanted to save that piece but the spot welds didn't allow a nice straight cut along the bottom. Maybe this cab was made on friday about quitting time.
I don't think I took any pics when the seat was in it. Its back out now. If I can find some help, I'll put it back in and take a pic. |
12-21-2022, 01:30 PM | #44 |
Interesting idea, but what does this do to the structural integrity of the back of the cab?
12-21-2022, 02:04 PM | #45 |
It most likely won't be as strong but to what degree would require some testing. I could see the back wall buckling easier in a major crash but if the hit is that hard you're likely to be hurt from other impact points first.
