Old 01-03-2007, 10:28 PM   #26
bagged74
its just $$$$$
bagged74's Avatar
Re: progress pics
thats going to be a pretty low ride height.
bagged74 is offline   Reply With Quote
Old 01-03-2007, 10:42 PM   #27
jlaird
jlaird's Avatar
Re: progress pics
I called slam specialties and asked them what the ride height of the bag I have is. The told me between 5.5 and 7". So I set the ride height up for the bag to be inflated to 6.25" high. Did I do something wrong?
jlaird is offline   Reply With Quote
Old 01-03-2007, 10:51 PM   #28
jimmydean
jimmydean's Avatar
Re: progress pics
That's freakin' low! Guess that's why I'll never run a step notch
Looks good though. Get that bad boy rolling.
jimmydean is offline   Reply With Quote
Old 01-03-2007, 11:58 PM   #29
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Re: progress pics
Your problem is that your doing bag over axle which gets 1:1 lift which sucks ass if you want it to ride good because as you can see its pretty low. Id say your doing it right, its just the nature of the stuff. I guess.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 01-04-2007, 12:38 AM   #30
jlaird
jlaird's Avatar
Re: progress pics
Should I set it up for 7" bag ride height? That would help out a little in getting the 4 link more parallel with the ground...
Old 01-04-2007, 01:07 AM   #31
gringoloco
A guy with a truck
gringoloco's Avatar
Re: progress pics
I agree with everyone else on the VERY low ride height. You will only be a few inches off the ground with the axle that deep in the notch. It will definitely look cool though...
Maybe build a taller mount on the axle to take up some of the 'slack'. My understanding is that you want a tapered style bag on over-the-axle setups. The Slams are better suited to a lever setup. Have you considered mounting the bags on the upper link and to the outside of the frame?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-04-2007, 01:24 AM   #32
jlaird
jlaird's Avatar
Re: progress pics
yea, I too have heard that the sleeve bag is better suited for over the axle. My plan is to use what I have, and if it is not to my liking, I'm going to switch out the slams for a sleeve type bag.
I just went out and did some measuring. If I go with a ride height of 7" with the slam bags and use a 30" tall tire, my frame under the cab will be 6.25" off the ground. This sounds reasonable, doesn't it?
Thanks for all the help fellas!
Old 01-04-2007, 10:14 AM   #33
XXL
Señor Member
XXL's Avatar
Re: progress pics
Originally Posted by AesC10s View Post
Check this one out guys, Its from speedway motors http://www.speedwaymotors.com/xq/asp...qx/Product.htm
I have one of these units that I played around with, never actually installed on anything, that could use a good home.
XXL is offline   Reply With Quote
Old 01-05-2007, 01:43 PM   #34
1lowdiesel
1lowdiesel's Avatar
Re: progress pics
looks a little low... but good.
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 01-05-2007, 05:06 PM   #35
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: progress pics
Originally Posted by jlaird View Post
guys, heres a pic of the 4 link mocked up. My axle is at ride height which was derived from the slam bag being a little over 6" inflated at ride height. My issue is the angle of the 4-link. I thought it is supposed to be parallel at ride height. Is it ok the way it looks? I can't move the front mount any further up.
I agree with the other's, it's gonna ride real low. I can only imagine what you'll have to do to the front.
To get the four bars closer to level, maybe you can swap the front mounts of each side with each other. This would put the front mount tabs angling downward, allowing you to raise the front mounts a couple of inches higher on the frame rail. Instead of airing up the bags to 7" which may increase the firmness of the ride, maybe you can install spacers between the bags and the brackets to get the bars level at ride height.
BTW, looking good...
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 01-05-2007, 06:05 PM   #36
jlaird
jlaird's Avatar
Re: progress pics
I will try flipping the front mounts, but I don't think it is going to make a difference. I'll have to go look.
The only thing that I am concerned about with the spacers is that the spacer is going raise the rear at full dump, correct?
Old 01-06-2007, 01:44 AM   #37
gringoloco
A guy with a truck
gringoloco's Avatar
Re: progress pics
Yep. This is why I suggested upper link mounting. At say, a 1.5:1 ratio you would get 10.5" of lift out of that same 7" of bag. -Chris
-Chris
Old 01-11-2007, 03:33 PM   #38
jlaird
jlaird's Avatar
Re: progress pics
Does anybody have any creative ideas of how to take up the space between the 4link mount and the frame? I basically have to do exactly what is in this pic, but I was trying to think of a more "visually pleasing" way to do it.
Old 01-11-2007, 04:54 PM   #39
PBFAB.COM
PBFAB.COM's Avatar
Re: progress pics
I think a 6.25" ride height (bottom of frame rail to the ground) is plenty of room. I set-up all our stuff to run a 5" ride height. I know you have been discussing the height the bag is designed to ride at, and this is critical to have it function properly. Set the bottom of the frame rail to your desired ride height off the ground and then figure your bag mounts out. I would recommend a tapered sleeve on an over the axle set-up... the ride quality will be much better than a convoluted bag. If you are planning on 'possibly changing over' to the tapered sleeve later and run the convoluted now, keep that in mind when building your mounts.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-11-2007, 05:24 PM   #40
XXL
Señor Member
XXL's Avatar
Re: progress pics
Can I get a side shot of this? I've got an idea to make it more visually appealing, but need to draw it on a side view.
Old 01-11-2007, 05:57 PM   #41
pharcyde05
pharcyde05's Avatar
Re: progress pics
I have done a few trucks and and we always start from the bottom and go up you alredy know that the bag will lift over 7 in so you want to get the truck at the layed out level mount bottom of bag compress bag and then mount top bracket so that bag is compressed when layed out
pharcyde05 is offline   Reply With Quote
Old 01-11-2007, 06:02 PM   #42
jlaird
jlaird's Avatar
Re: progress pics
XXL, heres a bunch of pics. Didnt know which would work the best for ya:
http://67-72chevytrucks.com/vboard/s...ghlight=4-link
Old 01-11-2007, 06:12 PM   #43
jlaird
jlaird's Avatar
Re: progress pics
Nathan, do you know the ride height of a typical sleeve bag? Is Firestone the sleeve bag of choice? Never seen any others.
Old 01-11-2007, 06:16 PM   #44
pharcyde05
pharcyde05's Avatar
Re: progress pics
the diffrance on that is that vally customs bracket on axel mounts bolth bars lower
Old 01-11-2007, 06:30 PM   #45
jlaird
jlaird's Avatar
Re: progress pics
OHHH!!!, thats exactly what I need!
Old 01-13-2007, 08:35 PM   #46
jlaird
jlaird's Avatar
Re: progress pics
XXL, would love to see what you had in mind for that front mount.
Old 01-16-2007, 12:54 AM   #47
Kenneth_CS87
Re: progress pics
what 4 link are u running?
Kenneth_CS87 is offline   Reply With Quote
Old 01-16-2007, 01:13 AM   #48
jlaird
jlaird's Avatar
Re: progress pics
Suicide Doors
Old 01-30-2007, 09:00 PM   #49
jlaird
jlaird's Avatar
Re: progress pics
Got the 4-link mounted and rear bags on. I changed from going over the axle to in front. Next is the panhard bar. Just ordered it today.
Old 02-01-2007, 04:33 PM   #50
[ol'Blue]
[ol'Blue]'s Avatar
Re: progress pics
thats f-ing sweet.
[ol'Blue] is offline   Reply With Quote
