Old 01-09-2007, 04:16 PM   #26
see ten
WTB this ad
see ten's Avatar
Re: Tail light fuel filler
That looks like it's going to be real clean when finished up. How do you make it open? Are you able to pull down from the top or do you push it in at the bottom? Any particular reason that exhaust tubing was used instead of fuel line (aside from that size of rubber tubing not being easily available everywhere)?
see ten is offline   Reply With Quote
Old 01-09-2007, 04:53 PM   #27
HuggerCST
HuggerCST's Avatar
Rubber filler hose would have been better than steel, it was just easier to get the bend that I wanted using steel verses seaching the wrecking yards for the right size/bend. As far as I know, no aftermarket company makes it pre bent, but I haven't researched it. If I find some, I may change it, but would still have to piece it together to get it to the tank. The easiest way to open it is to push on the bottom. At first I was planning to use a magnetic cabinet door latch to hold it closed, but I liked the spring better. Right now I don't think it has enough tension holding it closed, and I'm thinking about raising the point where the spring attaches to the light housing to give it more leverage.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 01-09-2007, 06:00 PM   #28
[ol'Blue]
[ol'Blue]'s Avatar
the hose IS available, i went to a local hose and fitting shop, it says on my hose fuel hose, and is the correct diameter. i believe it was for an aircraft,
he also deals with Hydrylics.
maby i just got lucky, but hose is available.
[ol'Blue] is offline   Reply With Quote
Old 01-09-2007, 07:39 PM   #29
JCA1972
JCA1972's Avatar
That looks great, very clean work, I might just copy your idea when I do mine, it would be really cool if you could rig up a remote control to open the light, that's what I'm planning for mine.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
http://67-72chevytrucks.com/vboard/s...d.php?t=226458
JCA1972 is offline   Reply With Quote
Old 01-09-2007, 07:53 PM   #30
jbon64
jbon64's Avatar
excellent work
hey.....smell my finger
64 nova wagon , 63 nova convertible
jbon64 is offline   Reply With Quote
Old 01-09-2007, 08:00 PM   #31
piecesparts
Parts and more parts
piecesparts's Avatar
With some application of thought, one could add a linear actuator and open it electrically. They come in all sizes and lengths.
piecesparts is offline   Reply With Quote
Old 01-09-2007, 08:12 PM   #32
69 air cab
that's cool Hugger..........so is the bed on the truck now?
69 air cab is offline   Reply With Quote
Old 01-09-2007, 08:20 PM   #33
HuggerCST
HuggerCST's Avatar
Hey Bill! No, I just took these pics last night. I plan to put it on to test fit a few things this weekend though. I'm just happy to get some time to work on it.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 01-09-2007, 08:21 PM   #34
HuggerCST
HuggerCST's Avatar
That would be cool.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 01-09-2007, 08:28 PM   #35
69 air cab
PROGRESS..........nothing like it...........good to see it's moving along
Old 01-09-2007, 09:04 PM   #36
see ten
WTB this ad
see ten's Avatar
Yep, you are correct, it's not just something you can run in to your local Napa or Auto Zone and pick up. I was able to source some here locally when I put a tank under the bed of a 66 I used to have.
Old 01-09-2007, 09:32 PM   #37
HuggerCST
HuggerCST's Avatar
Pre-bent fuel hose is available?
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 01-09-2007, 11:05 PM   #38
gringoloco
A guy with a truck
gringoloco's Avatar
So... When you gonna come do both my trucks?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-10-2007, 12:38 AM   #39
HuggerCST
HuggerCST's Avatar
Bring 'em on over, it's always easier the second time around! The blazer may take a few days, and umm, I'll need the keys to make sure that it "works right".
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 02-24-2007, 10:42 AM   #40
meaniam
what a *****en mod gob wee done. will the tanks be on the outside of the frame rails or in the middle. what size tank are you gonna use? and where did the tank come from?
do you have a parts list?
thanks
i hate my inside cab tank
meaniam is offline   Reply With Quote
Old 02-24-2007, 11:31 AM   #41
HuggerCST
HuggerCST's Avatar
thanks
Thanks! The tank will be inside the frame rails, behind the rearend. I have a blazer tank from American classic truck parts that I was planning to use, but because it hangs so low, and the filler neck is not in the best location, I am thinking about getting one of Fuelcellguy's custom tanks. I listed the parts in a previous post, on page one.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 12-18-2008, 03:23 PM   #42
lghtng2
Don't forget to close the gas cap you'll be pulled over for having your tail-light out lol hahaha...nah its a nice mod i like the way your thinking probably confuse alot of people at the pump like to see some reactions of people on the street good work!
lghtng2 is offline   Reply With Quote
Old 02-19-2009, 04:50 PM   #43
kevncar
Active Member
kevncar's Avatar
subscribed...don't wanna lose this one!
Kevin
72 Chevelle
67 C10...454/TH400
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961
kevncar is offline   Reply With Quote
Old 10-29-2009, 08:17 AM   #44
HuggerCST
HuggerCST's Avatar
Just thought I'd post pics of it finished. It works great, but does burp some out when it gets full.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 10-29-2009, 10:20 AM   #45
matthufham
looks good! glad its lasted you awhile without too much trouble
matthufham is offline   Reply With Quote
Old 12-13-2009, 09:36 AM   #46
srea76
srea76's Avatar
From the pic it is hard for me to tell. Did you have to actually widen the stake pocket to get the hose in there?
srea76 is offline   Reply With Quote
Old 12-13-2009, 12:44 PM   #47
Mayo
Cool Truck
Mayo's Avatar
pretty cool
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 12-13-2009, 01:03 PM   #48
HuggerCST
HuggerCST's Avatar
No I didn't have to widen anything, just remove the two lips from the bedside, on each side of the tail light opening, behind the bulb housing, and also had to cut a opening behind the tail light to make room for the filler and hose.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 01-04-2010, 07:58 PM   #49
72 Long
72 Long's Avatar
Nice work - very clean! At the moment, I'm contemplating the same type of filler mod. Torn between bed and taillight fill. I noticed what I thought was a tank vent hose in one of your pics under the bed. Where did you vent it? I looked at the marine filler and didn't see a vent. Also, did you run into any problems with the mechanical fuel pump after relocating the tank?
72 Long is offline   Reply With Quote
Old 01-04-2010, 08:47 PM   #50
weircc
weircc's Avatar
wish i woulda done this instead of stake pocket. and for those of you wanting leds go to f/s section led man will make you a set really reasonable for the price too not 600.00
weircc is offline   Reply With Quote
