08-19-2015, 04:41 PM | #26 |
Re: FOUND!!! Power steering O-ring to Flare ADAPTERS
I've seen the adapters before, but never seen the inserts. Brilliant idea. Thanks for sharing.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
08-19-2015, 05:09 PM | #27 |
You can also search ebay for "MALE O RING TO MALE FLARE A/C ADAPTER FITTING KIT #6" and you can adapt the power steering pump from O-ring to flare.
08-19-2015, 05:13 PM | #28 |
Nice. thanks for sharing.
"Life is too short to drive a boring vehicle". Later, Wayne |
08-19-2015, 10:52 PM | #29 |
Enjoying left field
I thought I heard that you can swap the whole valve assembly in the pump from one to the other.
08-20-2015, 11:38 AM | #30 |
What I did was cut the oring/flare off and installed inverted flare nuts and re-flared the ends. I looked at the amount of work to change out the steering gearbox compared to the re-flare. If I need to replace the hoses in the future I would have to go through this again, so I may change the steering gearbox out to the 1986 version later on so I can just purchase the '86 hoses if they need replacement.For now this works. Thanks for the links to the flare adapters.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
08-20-2015, 11:44 AM | #31 |
Woodwright is correct about the pump. I remove the fitting in the pump and installed the flare fitting !
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
08-20-2015, 01:55 PM | #32 |
My pump was not the issue, I did the same thing. The issue was both of the fittings going to the steering box.
08-20-2015, 02:34 PM | #33 |
Yes the later steering boxes are different. I bought a Red Head quick steering box with the correct flare fittings when I did mine.
06-27-2016, 12:15 AM | #34 |
I need this.
06-27-2016, 11:39 PM | #35 |
Hellasick
Wow, this blew up and never saw it. Speedway still sells the one insert in a previous link. I'm guessing it fits the high pressure inlet but don't know. It would long appear that Lee mfg is no longer in business, too bad. The original flair fittings in the steering boxes may be larger than what is needed in the o-ring boxes and may be able to be turned down to fit. Wish I had some better info for you. It was a pain in the arse to find this the first time.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
07-28-2016, 06:14 PM | #36 |
Chevy Enthusiast
Do you know what size the inserts are for sure? I can get A/C inserts like meantioned above but I think there are two different sizes. Like #6 and #8? I'm trying to do this on a hydroboost unit and I know that the wrench sizes are 5/8" and 11/16" but I'm not sure how that translates to the actual line. http://www.ebay.com/itm/311464113724
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
09-24-2016, 10:21 AM | #37 |
i have an oem new box from napa and it came with 2 o-rings. it looks like the box accepts the flared lines. so i dont need them?
09-30-2016, 11:27 AM | #38 |
Chevy Enthusiast
If it has the cone shape brass pieces pressed into it it's flare, if it just has holes with a step down it's o-ring. Plus the box will have a part number on the top saying something like *******44 or *******44L, the L is the late model that uses o-rings.
Ps. Just to follow up on the adapters I meantioned above. I ended up using 2 #6 adapters. I had to remove the oring on one to get the line to thread in the hydroboost because the adapter was a little too thick but it still sealed fine.
09-30-2016, 12:09 PM | #39 |
thanx!
11-10-2019, 11:19 AM | #40 |
good info. thank you
