08-21-2007, 01:59 PM | #26 |
Re: porterbuilt dropmember questions
any updates??
more questions: what happens to the sway bar with the dropmember??? do you re-use the stock one?? |
08-22-2007, 05:27 PM | #27 |
WOW ME LIKEY
nickle and dime |
08-23-2007, 03:01 PM | #28 |
I'll make a package deal happen !!!!! Call me when you're ready and if you want to get the complete system from me, then I guarentee it'll be a killer package deal for sure.
- Clint - |
08-23-2007, 03:54 PM | #29 |
A guy with a truck
Me too. Curious...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
08-23-2007, 09:28 PM | #30 |
We'll see this bad boy laying frame TOMORROW!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
08-23-2007, 09:40 PM | #31 |
nice truck man. keep the pic comen.
08-24-2007, 01:47 AM | #32 |
PorterBuilt Man Crush
With the Dropmember you need to bend the sway bar end in 1" on each side since the the track width is narrowed by 1".
This is the from the Man him self.
The 72 will live again |
08-24-2007, 02:13 AM | #33 |
That's correct on the sway bar. The trac width is narrowed up one inch per side on the Dropmember, so the sway bar will need to do the same. The sway bar needs to be the end-link style as well. The last one I had done, I called Addsco and had them bend me the bar one inch extra per side. I am assuming most other manufacturers will do the same? It shouldn't be an issue having one bent if you already have purchased it... just don't heat it up to bend it!
08-24-2007, 03:08 AM | #34 |
A guy with a truck
How 'bout with stock control arms?
08-24-2007, 10:09 AM | #35 |
I do know the factory bar will not work. It may be necessary to fabricate some tabs, or order some pre-made generic tabs to attach to the factory arms. I know Adsco's (sp?) kit comes with brackets that bolt/weld to the factory lower arm to allow the mounting point for the end-link. Another thing on my "to do" list is check into a camaro sway-bar for the 70's era and see if it's compatible. I have one on the shelf... now if I could only find two more days in the week...
08-24-2007, 11:57 AM | #36 |
I thought the dropmember narrowed the track width almost 4". What is it?
08-24-2007, 02:33 PM | #37 |
67-72 parts collector,…
What's the best backspacing to run on the front with the dropmember.? Looking at a 20x8 wheel.
08-24-2007, 02:52 PM | #38 |
It narrows it just over an inch on each side, that makes it a little over 2" overall. I know I posted 4" a long time ago... it was an error on my part.
08-24-2007, 05:49 PM | #39 |
- Clint - |
08-30-2007, 01:23 PM | #40 | |
*i always think of more questions. heres some more: *does anyone have the big block dropmember in a 73-87? *if i bought one set up for the big block, could i run my small block on it until i could afford to build my big block? *is there any more clearance issues with a bbc? *can i run shorty c10 headers?? or even the chevelle shorty's? sorry for not just calling and asking all these questions but i do believe others want to know so im putting it all in a public forum. also, im always thinking of more and more questions and i probably won't have enough money for at least another month. thanks. |
08-30-2007, 03:39 PM | #41 |
Hay can you run stock wheels on the lowered crossmember or do you have to have 20s or bigger the tires i have now are 26in tall
nickle and dime |
08-30-2007, 05:34 PM | #42 |
What arms and spindle will you be running?
08-30-2007, 07:59 PM | #43 |
IT will have the art stuff it also has a ece 2.5 drop spindall on it right now but i kept the stock ones also
nickle and dime |
08-31-2007, 12:28 AM | #44 | |
Or A Dropmember, a 73-87 lower arm (with PB lower bag mount), and a 2.5" spindle, with a 26" tall tire will bury your rails in a 63-72 C-10.
09-01-2007, 01:52 AM | #45 | |
-As for backspacing, we have been running 20x8.5" wheels with 5.25 to 5.5 backspacing with good results. -Nobody has ordered a BBC Dropmember for the 73-87... yet. There will be clearance issues at the trans tunnel/floor. Not much cutting required... but it will need to be cut. -You can run the small block in the Dropmember with the BBC mounting tabs. (the difference in SBC,BBC, and GenIII mounts on the Dropmember are the tabs on the crossmember. The BBC tabs are just over 1/2" taller than the SBC tabs. So, you can run a SBC with the tabs for a BBC, but not the other way around. The GenIII tabs are completely different). -The shorty chevelle/camaro headers will work best.
09-01-2007, 01:59 AM | #46 | |
Would there be any diffence in backspacing options since I am going with 18x8 or 18x9. I need to get my front's ordered, and did not know if there was any difference since I am not doing a 20+
09-01-2007, 04:18 PM | #47 |
What tire size are you planning on running Jason? If it's in the 27" tall ballpark, the backspacing will need to be the same.
09-01-2007, 06:35 PM | #48 |
It is a 27" thanks
09-05-2007, 04:04 AM | #49 |
With this dropmember installed, will it be possible to bolt in an aftermarket sway bar?
There is no replacement for displacement! |
09-05-2007, 04:29 AM | #50 | |
Yes, but requires modification. You need to bend the bars in 1" per side due to the narrowing of the track width. You also need to use end link syle sway bar.
