08-01-2007, 12:27 PM | #26 |
Re: Coys C5's
08-01-2007, 05:57 PM | #27 |
chevy truck fan
Re: Coys C5's
2500hd,
thanks! i will go with that info then... thanks again! rodstored-72 |
08-04-2007, 02:29 AM | #28 |
Re: Coys C5's
If I choose to go with these what specs would I need? I have a little bit more narrow rear end though running a Ford 9" rear. I would want 20s in the rear and 18s in the front. I wish they made a 20 x 12 because I was gonna go with Weld Pro Stars in 15 x 12 with a 14.5" section width tire until I found out they don't make 5 x 5 bolt pattern anymore. So I'm wanting to fit the widest wheel and tire under there to fill out the wheel well. Would a 20 x 10 Coy C-5 with a certain offset and a wider tire fill the bigger gap or no? I have 16.5" of total width, 14.5" of useable space, I want more of the lip to be on the outside (so that's the least amount of backspacing right?) and I need at least a 30" tall tire. I'm running 4.11 gear so I need a tall tire. Here's a pic.
My 84 C10 build...
http://67-72chevytrucks.com/vboard/s...d.php?t=216158 |
08-04-2007, 09:17 AM | #29 |
Insert Title Here
Re: Coys C5's
Coys had a 20X12 at there display at a swap meet
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
08-04-2007, 11:26 AM | #30 |
Re: Coys C5's
According to their website they make a 20x14 in Chrome and Polished but not the grey center. They only list that size for 5x4.5 and 5x4.75 bolt patterns though. Your best bet would be to measure your set-up to find out the size and backspacing you want and then give Coy's a call and see if they can help you out.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 08-16-2007 at 06:44 PM. Reason: spelling |
08-04-2007, 05:06 PM | #31 |
Re: Coys C5's
The bolt pattern on the back is 5 x 4.5 (ford) the front is 5 x 5 (chevy). And the rear end is 3.5 inches more narrow on each side totaling 7" more narrow overall compared to the 10 bolt that was under there before.
My 84 C10 build...
08-04-2007, 06:07 PM | #32 | |
A guy with a truck
Re: Coys C5's
Here's my suggestion: Wheels Rear: 20x14 w/ 4" backspacing Front: 20x8.5 w/ 5.25 backspacing Tires Front: 255/45-20 Rear: MT Sportsman S/R , 31X16.00R20LT -This tire is made for a 14" wheel, has a section width of 15.7", a tread width of 13.5" , and is 31" tall. Using these specs will get you plenty of sidewall- it will be the same tire diameter as my Blazer pics above. Using max BS up front(5.25) will pull the wheel in, giving you a narrower track width, allowing you to lower it more up front for more rake and keeping the pro-street feel. Oh, and polished would look better than chrome in your case, since you are using so much billet. I don't want to tell you what to do, but YOU MUST DO THIS! Your truck would be unbelievable in this configuration. Please post pics when you get them mounted up. -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
08-04-2007, 07:41 PM | #33 | |
Re: Coys C5's
08-05-2007, 12:19 AM | #34 | |
Re: Coys C5's
I think I need more than 4" back spacing. I need more rim to go toward the back closer to the leaf springs.
My 84 C10 build...
08-05-2007, 12:43 AM | #35 |
Re: Coys C5's
With your current rear end measurements provided, you need 5.5"BS w/a 14" wide wheel. Of course this is only an estimate that would need to be verified.
08-05-2007, 04:52 AM | #36 |
A guy with a truck
Re: Coys C5's
Good call- I had 12" on the brain for some reason...
08-05-2007, 11:24 AM | #37 |
Re: Coys C5's
Lifts collar, put's on rhinestone shades & curls lip . . ...... Thank you..... thank you very much!
08-05-2007, 09:23 PM | #38 |
Re: Coys C5's
Where are these wheels made? Someone said they considered a set until the found out where they are made.
Regardless, how do they ride and balance out for those of you running them?
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
08-06-2007, 07:56 AM | #39 |
A guy with a truck
Re: Coys C5's
Made in China like a lot of things these days... Mine balanced out fine and are surprisingly light weight.
08-06-2007, 08:31 AM | #40 |
Re: Coys C5's
Im the one who mentioned where there made. For me it wasnt an issue of quality, there is some good stuff that comes out of china, & some really crappy stuff to, just like anywhere. Its more a political issue for me, I just have a problem giving my money to a govt. who wants to do us harm. They could make them in many other countrys & it wouldnt be an issue. John
75 GMC C-15 short/step factory 454, lowered |
08-06-2007, 01:57 PM | #41 |
Re: Coys C5's
China doesn't want to do us harm ... they just want our money.
08-06-2007, 09:14 PM | #42 |
Re: Coys C5's
Centerline Voltage made in California by ??????? But still made in the States. 18X8" and 20X9" I like Coy wheels and almost bought some but decided to go with these wheels instead. I just wanted something different
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S Last edited by 72 Cheyenne402; 08-06-2007 at 09:16 PM. |
08-16-2007, 01:54 PM | #43 |
Re: Coys C5's
rodstored-72 -- have you gotten your wheels yet?
1970 Custom Original 400/400 Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi PS PB and cold factory air Early Classic 4.5/6 Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20 Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40 Rear end is original wide 6 lug converted to 5 lug |
08-16-2007, 05:58 PM | #44 |
Re: Coys C5's
very nice 72Cheyenne.
BTW...yes they do like our money... take a look what its being spent on.
08-19-2007, 12:40 PM | #45 |
Re: Coys C5's
So would it be safe to assume if I was going to order 18's and 20's,the 18's would be 4 1/2" backspacing and the 20's would be 5"???
The truck is a 67 but has been converted to 5 lug on the front with 73+ suspension and the rear has a 72 diff.
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
08-19-2007, 02:54 PM | #46 |
A guy with a truck
Re: Coys C5's
Yep. Check your PMs...
08-19-2007, 04:20 PM | #47 |
Re: Coys C5's
08-19-2007, 10:39 PM | #48 |
GM ONLY BABY!!!
Re: Coys C5's
I like the C55's the best.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
08-20-2007, 03:43 AM | #49 |
A guy with a truck
Re: Coys C5's
They are cool looking. Kinda remind me of the Junk Yard Dogs, short on size options though...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 08-20-2007 at 03:46 AM. |
08-20-2007, 11:39 AM | #50 |
Re: Coys C5's
man those COY rims are awesome looking, where did you guys buy your tires from? i think i found my 22's for my truck.
1985 GMC ( future plan pro tour build for the wife ) Black 2013 GMC single cab 4/7 drop on 24'' Torque Thrust ST rules |
