#26 | |
Re: Blazer Update Pics
#27 |
A guy with a truck
Go with what you've got. The stock arms will get you pretty low once you get all the body out of the way. If you move the frontcrossmember forward, you're gonna have to figure out something for steering, as the stock stuff won't work. Were you planning on running the Bill Turner piece you have?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#28 | |
#29 |
I would like to get mine as low as this one, I love that blazer
#30 |
A guy with a truck
That one is just aired out on 20s/18s w/ a c-notch out back. Shouldn't be too hard to duplicate. You could ride that low with a small step notch and a sectioned crossmember.
The reason I mentioned the Bill Turner stuff is that it is already sectioned and set-up for the R&P. Would make life a lot easier.
#31 |
looks like a sweet project. I would go with that plan the vet stuf is cool but for the $$$$ I dont think the ride would be that much better.
Earl 68 2500 4x4 GMC Burb Last edited by earl87gta; 10-09-2007 at 04:55 PM. |
#32 | |
#33 |
How are you bolting up the 400 to the 6.0? It would be cheaper to get a 4L80E than to add a gearvendor unit.
Mike Redpath |
#34 | |
![]() Join Date: Apr 2004
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#35 |
You can get a flywheel of a 98 ls1 and a spacer and it is supposed to bolt up with little fab. I already have a good th400 and may not even get a gear vendor since this aint no daily driver but you can find them cheap if you look hard.
#36 |
#37 |
I did get all the 67 suspension back under it this afternoon ( it has 4 tires under it again) so the next step is to figure out how far I want to move the front suspension foward and how much I want to move the rear suspension back. I will then pull the tub and move the suspension and take the frame and parts and have them blasted and power coated.
#38 |
Where should I start looking? I haven't seen any real deals.
#39 |
#40 |
over/ under drive for a TH400.
#41 |
#42 |
What is the easiest way to put the tub on a rotisserie? Anyone have pics?
#43 |
A guy with a truck
Check bagged74's build thread. That's the only pics I've seen on here.
#44 |
#45 |
Got the tub on the rotisserie, it was pretty simple.
#46 |
computer illiterate
pics?
72 2wd blazer 72 swb 4x4 |
#47 |
jkade i loved your blazer b4, so i can only imagine what its gonna look like once your finished up,
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 |
#48 |
chevy_632
here's a pic of mine with 20x10 3" backspacing kinda what u said u were interested in doing thaught i would show a pic if it helps.also got a complete C4 front clip thats mint im not using PM me if ur still thinkin of going that route.rob
#49 |
Green club
Damn, that's nice
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
