Old 10-15-2007, 01:59 PM   #26
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: 72 2wd Blazer: Project "Break Me"
Originally Posted by SactoJim View Post
Keep us posted on this one.....gonna be nice given what it looked like before!
that thing will look sweet in the end. Definitely signing up for the show.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-15-2007, 06:15 PM   #27
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Very nice work so far! Can't wait to see more progress. Best of luck and sorry to hear about your new carpet being used as a nest. That sucks.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 10-15-2007, 08:17 PM   #28
jkade
jkade's Avatar
Progress slow, I got the doors off and the tailgate and braces installed to keep everything straight. Going to try and get the body off sometime this week so I can work on the frame and suspension.
jkade is offline   Reply With Quote
Old 10-15-2007, 09:34 PM   #29
jkade
jkade's Avatar
Here is a chop Carter did for me a while ago and it is the look I want. I am going to put the 67-68 trim on it like in the last pic. I think I am going to run the front and rear pans instead of bumpers. I think the black may look best on the bottom, grille and do the winshield frame and top black also.
Old 10-17-2007, 08:35 AM   #30
jkade
jkade's Avatar
Got the frame out from under it in about 45 mins by myself yesterday. Looks like the stock gas tank will not work back
Old 10-21-2007, 06:49 PM   #31
jkade
jkade's Avatar
Started doing a little sanding and the passenger rear bottom quarter had a crap load of bondo hiding a couple of dents so I am going to take it and have it blasted. From what I could tell it had been painted about 3 times and it was originaly hugger orange. Maybe off to the blaster next week.
Old 10-31-2007, 08:59 PM   #32
jkade
jkade's Avatar
Update. Got the frame striped down and the c notch cut out. I ordered a kp weld in step notch for the rear along with the under bed bag mounts. I started the 1.5" crossmember notch today, got the section cut out and it will be grinding and cutting filler pieces tomorrow. If I can remember to get the camera out of my other truck I will take some new pics. I also located me a free 9" ford rearend.
Old 11-01-2007, 08:00 AM   #33
gringoloco
A guy with a truck
gringoloco's Avatar
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-02-2007, 08:27 AM   #34
jkade
jkade's Avatar
I have most of the grinding done on the crossmember, maybe I can get it welded up this afternoon.
Here is the stripped down frame, waiting on my rear notch.
Here where I am setting my ride height, that is 5" off the ground.
Old 11-02-2007, 09:04 AM   #35
gringoloco
A guy with a truck
gringoloco's Avatar
Sweet. How much crossmember notch? Did you ever figure out the steering?
-Chris
Old 11-02-2007, 11:14 AM   #36
jkade
jkade's Avatar
1.5" on the crossmember. I am going to install a R&P of some sort, I guess I will burn that bridge when I get there
Old 11-02-2007, 11:56 AM   #37
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
The before shots were great from my perspective, looking forward to seeing the after shots fer sure!!
Almost Perfect Before, Can't wait to See it Redone................
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 11-03-2007, 09:23 PM   #38
jkade
jkade's Avatar
Rick
Thanks, it is going to be a while before it is done Maybe 2009 or 2020
Old 11-03-2007, 09:36 PM   #39
jkade
jkade's Avatar
I am ditching the crossmember for the blazer, I don't like how much it sticks up above the frame now. I guess I will put it in my 67 when I do it. I am thinking about getting my old man and my buddy to help me build a crossmember and run c4 suspension. I am wanting to do this thing rite and not halfass anything. It will be more money but it will be worth it in the end. I wish I could afford the c4 dropmember but I can't justify spending that when I have the resources to make something work that is in my price range. I know I can get a complete c4 front suspension for $450 and that is brakes which I wont use and make my own brackets and run c5, spindles, rack, and control arms. I have a freind that can design the crossmember and my old man can fab it up for me. Suicide doors sells air springs for $540 so I can save money there over the air ride tech shockwaves. The kicker is I will have to buy some front wheels but I can use the current ones on the 67. I am going to concentrate on getting the rear fabbed up and then worry about the front.
Old 11-04-2007, 05:05 PM   #40
ColoradoK5
ColoradoK5's Avatar
Sounds like it may be awhile but as long as you get what you want on your project it will be worth the money and time spent.
ColoradoK5 is offline   Reply With Quote
Old 11-09-2007, 07:02 PM   #41
jkade
jkade's Avatar
What yall think about one of these for a dash? I want to do something different with mine. Name:  fa6e_12.jpg
Old 11-09-2007, 07:11 PM   #42
jkade
jkade's Avatar
I know this one has been done but it is my favorite.
Old 11-09-2007, 07:24 PM   #43
shifty
Questionable
shifty's Avatar
I like the red one better - seriously. Hell, if you don't do it, I would if I was talented enough
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 11-09-2007, 07:39 PM   #44
jkade
jkade's Avatar
I can't say that I have seen one of them done before, I could mount the rest of my guages in a console. You can do it if you take your time, or that is what people tell me
Old 11-09-2007, 07:41 PM   #45
Jtrux
I'm a poor spectator
Jtrux's Avatar
That's crazy, it looked good before, I can't imagine what it will look like when you're done. Keep it up.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 11-09-2007, 07:44 PM   #46
jkade
jkade's Avatar
It is going to be a while before I get done but I will one day and I am sure somewhere along the line I am going to wonder why the hell did I tare this thing apart
Old 11-14-2007, 02:12 PM   #47
jkade
jkade's Avatar
Got my step notch installed.
Old 11-14-2007, 03:28 PM   #48
gringoloco
A guy with a truck
gringoloco's Avatar
Nice progress. Man, that's a lot more notch than me- you will be loooooww... Are you keeping the back seat?
-Chris
Old 11-14-2007, 03:29 PM   #49
shifty
Questionable
shifty's Avatar
what is that dash up there out of, anyway?
Old 11-14-2007, 03:58 PM   #50
jkade
jkade's Avatar
I hope to be low I am thinking about running a back seat like below and having a trunk behind to to put luggage, battery, tank, amps, etc. The seat back will set up against the notch cover and the bottoms will be out in front like the blazer from the sema thread.
