03-19-2008, 06:37 AM | #26 |
Re: bedsleds rebirth
today my package from ***************** came. got my bag brackets, link ends and link mounts. started the right side, got alittle bit done then got sidetracked with a headache. here are some pics
03-23-2008, 06:54 AM | #27 |
alittle more progress today. i have an all new respect for guys who build rollcages and round tube. sure is a pain in the ass. hopefully i get the left side done faster then the right
03-23-2008, 08:25 AM | #28 |
WOW dude thats a sweet idea for bag mount gussets, i like it a lot
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
03-23-2008, 08:32 AM | #29 |
2 links work nice a lot of guys dog em. I have one and ive never had one issue with it, other that everyone telling me how bad it is.But like bedsled I like the fact it works like a sway bar.they ride killer when set up right.
03-23-2008, 08:34 AM | #30 |
Nice work...Lookin badass so far. Are you going to box the old frame to the new one.
03-23-2008, 07:04 PM | #31 | |
Did you ever measure one of your set-ups?
03-23-2008, 07:28 PM | #32 |
my old bars were 24 inches long with a two link, didnt measure the pinion angle diference all the way down and all the way up but i set mine for ride height, and drive it at that height . ive never had any driveline vibration or worn ujoints.. its only an issue if done wrong.. not much dfferent then the 2 link on the stock 60-72 trucks except for the side to side articulation..
03-23-2008, 07:30 PM | #33 |
REDSLED04... the right side is already boxed where the new and old frame meet.. ill finish the driver side this weekend
03-23-2008, 10:06 PM | #34 | |
Also, aftermarket 2-links are about half the length of the truck trailing-arm style 2-link. That's a big difference when comparing pinion angle change (I know because I did tha same testing using a 48" long level). I'm not trying to claim one is better than another. I was just relating tests I had done while exploring possiblities. If it works for you, that's great.
03-24-2008, 04:26 AM | #35 |
my new bars are 40 in. long maybe it will be alittle better but either way i havent had any issue with them
03-24-2008, 06:22 AM | #36 |
Coming along quite nicely! Dfinitely diggin' the round tube touch on the upper bag mounts!
Are you planning on running a gusset on the links under the bag... or let it ride?
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
03-24-2008, 07:28 AM | #37 |
the links are 1/4 inch. SHOULDNT have any problems. havent in the past so im hoping none this time around
03-24-2008, 07:35 AM | #38 |
some more progress pictures..
03-24-2008, 07:53 AM | #39 |
Better fix the pinion angle. It looks a little drastic in that last pic....
03-24-2008, 07:58 AM | #40 |
there will be another tank on the other side.. its buggin me looking at it with only one tank on... still waiting on the other
03-25-2008, 05:09 AM | #41 |
alittle bit of color on the frame, setting up the track bar and a whole lot more of nothing. motivation isnt with me today.. after trying to clean the axle tubes and not really getting anywhere, wore me out
03-25-2008, 08:08 PM | #42 |
86 C10
Its looking good nice work you doing.
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold |
03-27-2008, 07:31 PM | #44 |
got the fuel cell ordered from jegs, 20 gal. aluminum.. should be here friday so i should beable to get that in this weekend.. trying to get it to roll around this weekend
03-27-2008, 10:50 PM | #45 |
Nice build.I want to do one this same way,, just because it looks good for me. I also wanted to ask you, what dimension metal you're using and what thickness? Finally, how did you make and afix the bushing ends that mount to the frame and where can I get those items? Once successfull then I'll tackle a 4 link. Again great build and Thanks.
Current ridesne owner GMC 1974 swb, 1986 Chevy lwb,chopped top '85 S-10,1948 Stylemaster rat rod,'2008 Honda Civ.Chopped top '46 dodge. Last edited by danielwetpaint; 03-27-2008 at 10:53 PM. Reason: caint feel my legs. |
03-28-2008, 05:10 AM | #46 |
danielwetpaint- 2x4 rectangle tube is .120 wall thickness. some people use 3/16... the link ends and brackets are from *****************
04-01-2008, 11:03 PM | #47 |
got the fuel cell
04-02-2008, 01:58 AM | #48 |
Man, You work fast!! Your work looks really nice. When do you think you will be done? Looks pretty close! Keep the pictures coming!
04-02-2008, 02:10 AM | #49 |
Another update:
finally got the other tank. made the brackets for the compressors too! now everything is starting to look symmetrical |
04-02-2008, 02:29 AM | #50 |
I noticed you put installed a track bar. Is this in place of a panhard or watts linkage? What is the benefit of a track bar over the others?
