#26 | |
Re: So, that's why it was leaking so much today!
Here's a thread I started in a diesel forum. All about what you guys have. http://www.4btswaps.com/forum/showth...?t=3189&page=2
1970 k20 350 4speed hd44 14b Circumventing the language filter is against site rules |
#27 |
I shortened the rear 1 piece shaft from a square body truck at home for free.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() |
#28 |
Post Whore
![]() Join Date: Feb 2000
Got some free time last night so I went out and popped the broke cover.
Looks like my truck has some missing balls ![]() ![]() Here's what was floating around visible through the crack in the cover ![]() So, what did happen to the missing ball bearings? Kind of looks like they are pretty captive in there - would they have slipped out and into the transfer case or broken up? Was some obvious metal grit in there. Spent a bit of time doing some more eyeballing and it looks like moving everything forward and dropping 2" of the body lift will require me to rework the low tranny hump I added or go back to the high tranny hump. I'm on a very tight budget as this was not a planned project to happen right now so I will probably see if modifying the low hump tranny will allow me to still use my rather new carpet. I'm thinking I can just move my exhaust hangers forward and avoid having to do anything to the exhaust - not sure on that. Guess I will start ripping the transfer case out soon, yank the headers, pull the engine crossmember to modify it a bit, then move the engine forward, i.e. open a can of worms! ![]()
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 08-22-2009 at 04:09 PM. |
#29 |
For what it's worth, I think my NP205 hits the bottom of my cab since I swapped it for the old T-221 & reused the X-member. Point being, I don't think i'd remove too much of your body lift.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
#30 |
Post Whore
From a few posts I have viewed it looks like the NP205 crossmember lets the transfer case sit 1" lower than the Rockwell's crossmember. If so, a 2" body lift ought to clear. If not, I guess I'll use spacers to lower the crossmember down a bit. Hopefully won't have to go to that trouble.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#31 |
wouldn't it also depend on the condition of a guys normal body mounts? Old ones will let the cab sit lower...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#32 |
Post Whore
I put in poly when I tore the truck apart so I know I don't have any sag presently. I do know the Dana 20's crossmember is 1" different than a NP205's crossmember. Pretty sure the same difference applies between the Rockwell and NP205's.
#33 |
Yeah, my cab mounts are about 2 yrs old, but the more I look at your truck, I think you got plenty of body lift, you could spare a couple inches and not have to worry...
#34 |
FYI, my stock rockwell crossmember had 1/4" spacers dropping it down....
#35 |
Some great info here for my 68 burb build.
When putting the NP205 in did have to drop the X member 1" for body clearance for the top of the NP205. Then completely remove the rear drive shaft carrier bearing support since it was in the way of the drive shaft and shorten the rear drive shaft 5 1/2". From what I've been reading here I'm sure I'll be glad I put a 205 in for parts and less noise. Thanks!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 11-16-2011 at 06:19 PM. |
