03-30-2008, 07:51 AM | #26 |
Re: LFD's Shop Toys
We got a few hrs in today but not much do to dropping off customer projects and picking up new ones.
I decided to make a mock up door jamb to see if the hinge placment was going to work. I used my shrinker and streacher to make the jamb piece then Jim took over and made the mount and spot welded it all together while I went for coffee. When I got back (short walk) I found it all worked great. This is good because I have all the templete's made for how this one is set up and I will be using them again for anoter build comming up. While Jim was working on some 3/16 plates for the door it self for the hinges to mount thru I worked on the caps to cover the old strike area. They turned out real nice for a hammer job. Kevin LFD Inc. Last edited by Rokcrln; 03-30-2008 at 07:54 AM. |
03-30-2008, 08:03 AM | #27 |
Re: LFD's Shop Toys
That last one is an extremely cool pic!
03-30-2008, 08:16 AM | #28 |
Re: LFD's Shop Toys
I thought the same thing. This truck is so low we had to jack up the trailer and block the ramps just to get it loaded. To unload it I just backed the trailer tires to the curb and rolled it off and this is were it stopped. Figure the truck is 67 years old and the house is still another 45yrs older then that This should be a sweet truck when done. The owner did all the curent work about 15yrs ago and it was done well but now it is time to complete it so he can drive the cr@p out of it.
Kevin LFD Inc. |
03-30-2008, 08:22 AM | #29 |
Re: LFD's Shop Toys
mock-up jam is brillant. i wished i would have used hinges like that vs the after market set-up.
03-30-2008, 08:24 AM | #30 | |
Re: LFD's Shop Toys
03-30-2008, 08:32 AM | #31 | |
Re: LFD's Shop Toys
Kevin LFD Inc. |
03-30-2008, 08:34 AM | #32 | |
Re: LFD's Shop Toys
Kevin LFD inc. Last edited by Rokcrln; 03-30-2008 at 08:35 AM. |
03-30-2008, 08:40 AM | #33 | |
Re: LFD's Shop Toys
03-30-2008, 05:16 PM | #34 |
Re: LFD's Shop Toys
That jamb piece is nice. That looks like alot of shrinking and stretching for a mock up piece. Man you do good work. I have a difficult enough time just adjusting the doors on these trucks! Also, my trailer has no dove tail and 5 ft ramps. I installed a 7k drop leg jack on it. I have had the rear tires of my truck almost off the ground loading low vehicles, but it works.
03-30-2008, 06:01 PM | #35 | |
Re: LFD's Shop Toys
I have plans to build another set of ramps for my trailer that will be 7' and slide under the front sides of the trailer for just this reason but untill now I did not need them. Kevin LFD Inc. |
04-01-2008, 05:57 AM | #36 |
Re: LFD's Shop Toys
Well The rear jambs are done and we should have some doors swinging by end of Monday. I will also be working on the Burb 4th door jamb most of Monday while Jim works on the crew cab doors so I hope to get alot of progress because Tuesday I have to go back to my 9-5 day job so things will slow a bit here.
Kevin LFD Inc. |
04-01-2008, 06:06 AM | #37 |
Out of the carpool lane.
Re: LFD's Shop Toys
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
04-01-2008, 06:14 AM | #38 |
Re: LFD's Shop Toys
Would this not be the ultimate chassie for the crew cab build! Can you say 1971 chevy TopKick
Kevin LFD Inc. |
04-01-2008, 06:22 AM | #39 |
Re: LFD's Shop Toys
That reminds me of this. That's a full size H2 and Avalanche in the background:
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 04-01-2008 at 06:24 AM. |
04-01-2008, 07:29 AM | #40 |
Re: LFD's Shop Toys
Except the one I posted is usable as a tow vehical and much safer to drive in the street. I was up in santa rosa last week and saw a new burb that made that truck lok small
Kevin LFD Inc. |
04-01-2008, 08:11 AM | #41 |
Re: LFD's Shop Toys
Kevin, I have been trying to talk the family into a trip to California to tour LFD. And all they want to see in California is Disneyland and the Governator. I told them of the work you did on project penecilan. And the work on LFD Project. I even told them of the one man cab lift, And still nothing. Keep up the good work. even if the family doesn't think so I think you would be a better vacation destination than Disneyland.
04-01-2008, 08:18 AM | #42 | |
Re: LFD's Shop Toys
Trust me you will see more of LFD here on the site. Take the family to Disney and enjoy the time with them. Kevin LFD Inc. |
04-02-2008, 06:30 AM | #43 |
Re: LFD's Shop Toys
Swing! I had Jim and Jugernot over today giving my a hand with the crew cab as I was trying to get some work done on the burb. Here are some shots of Jug and Jim making good progress. I still have some welding to finish up then once the frame table is done I can strech it out a bit. Jugernot is the one in grey and Jim is in red.
Kevin LFD Inc. Last edited by Rokcrln; 04-02-2008 at 06:34 AM. |
04-02-2008, 06:45 AM | #44 |
Luv the Crewcabs
Re: LFD's Shop Toys
Door's came out Nice, Really making some Good Progress on the Crew cab. Can't wait to see you mating the 2 Cab's together...........
Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
04-02-2008, 06:49 AM | #45 |
Re: LFD's Shop Toys
Then here is a bit of work on the burb. I did not get as much done as I wanted but we made good progress on the crew cab today. I got the upper door opening metal all formed and tacked in place. I also got both upper sides all trimmed and tacked and ready to be finished and smoothed out.
Kevin LFD Inc. Last edited by Rokcrln; 04-02-2008 at 06:51 AM. |
04-02-2008, 06:53 AM | #46 |
Re: LFD's Shop Toys
04-02-2008, 09:48 AM | #47 |
Re: LFD's Shop Toys
04-02-2008, 04:25 PM | #48 |
Re: LFD's Shop Toys
No I am going with the same size as a burb rear door so it will be 33 1/8"+- acording to the one sitting next to it. I like how the last 4dr I built looked so I figured I will just go that way but the doors will not be cut untill I stretch the cab and have a good look.
Kevin LFD Inc. |
04-03-2008, 07:31 AM | #49 |
Re: LFD's Shop Toys
Made some progress today on the burb. Made a few more templetes as well. One for the drivers side of the B-post and one for the inside of the B-post for the hinge bolt access covers. I am spending alot of time making these templetes for furture builds and customers. This way they will be exact and quicker then doing them from scratch each time. I also spent a few hours cleaning up the top and sides of the 4th door opening.
How often do you see a 4dr burb or a 4dr 68 PU let alone both together! Kevin LFD Inc. |
04-03-2008, 07:33 AM | #50 |
Re: LFD's Shop Toys
And
Kevin LFD Inc. |
