Closed Thread
Old 04-17-2008, 12:08 AM   #26
Jamie @ Doug Thorley
Re: The LS1 swap headers are done!!!!
Originally Posted by Yukon Jack View Post
I think the word "impressive" sums up your headers quite well!
Thank you sir.
Jamie @ Doug Thorley is offline
Old 04-17-2008, 01:35 AM   #27
atp
Ordered mine today!!
atp is offline
Old 04-27-2008, 05:45 PM   #28
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Jamie, check your PM's. I have some feedback on these for the 73-87's. I will be sending you the pics in an email.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Captkaos is offline
Old 04-27-2008, 06:08 PM   #29
Hart_Rod
Hart_Rod's Avatar
Here's a part number for the plug wires:
MSD
Connector wires 8.5mm
32819
$67
Hart_Rod is offline
Old 04-29-2008, 10:38 PM   #30
Codys87
Codys87's Avatar
Do you think you could send me some info on these headers for the 73-87's too? I'm doing a 6.0l swap on my truck and trying to find some good headers.
Codys87 is offline
Old 04-29-2008, 10:43 PM   #31
OrangeCrush1970
OrangeCrush1970's Avatar
Holy Horepower Batman!!!
That thing is awesome!
Rottenwood Garage
1970...71...72 C1500 aka Orange aka Sideshow Bob
540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600
2 Tons of Fun
OrangeCrush1970 is offline
Old 04-29-2008, 10:56 PM   #32
Captkaos
Captkaos's Avatar
There is issues with the drivers side header, it won't fit our bodystyle.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Captkaos is offline
Old 04-29-2008, 11:05 PM   #33
Hart_Rod
Hart_Rod's Avatar
Where's the problem and what style of motor mounts are you using?
R/
Hart_Rod is offline
Old 04-29-2008, 11:05 PM   #34
Codys87
Codys87's Avatar
DANG!!! Thanks though. Any good ideas on which ones to use?
Codys87 is offline
Old 04-29-2008, 11:29 PM   #35
Captkaos
Captkaos's Avatar
I am still going to use Thorleys, just going to wait until the get them modified for 73-87's. There is just a clearance issue with the tube going over the top.
I am using standard S&P plates.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Captkaos is offline
Old 04-30-2008, 12:03 AM   #36
Codys87
Codys87's Avatar
Yeah the Thorleys look great and Tri-y will deliver perfectly at the power band I've got, so I think I'll wait too.
Codys87 is offline
Old 04-30-2008, 04:28 AM   #37
Hart_Rod
Hart_Rod's Avatar
Do you think the same problem would exist if using the ECE motor mounts?
Hart_Rod is offline
Old 04-30-2008, 05:22 AM   #38
Captkaos
Captkaos's Avatar
No, they wouldn't, but then the motor would be to far forward compared to a stock SBC. I actually want to move it back some
This is with ECE plates (almost 3" forward from normal)
This is with S&P plates (where it is supposed to be)
I am really wanting to move the engine back another 1" if I can, but I would settle with what I have.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Captkaos is offline
Old 04-30-2008, 08:52 PM   #39
I'm currently working with another member to see if the headers work with the later body style with different mounts. I will keep you guys posted.
Jamie
Old 04-30-2008, 09:18 PM   #40
Captkaos
Captkaos's Avatar
What mounts are they Jamie? I have had 3 different motor plates from 3 different sources, they are all the same as far as location goes. The only different one would be ECE motor mounts which move the engine WAY to far forward for a 73-87 bodystyle (see above pic)
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Captkaos is offline
Old 05-01-2008, 12:59 AM   #41
It pcmcobra and he is using the carshop plates. He is anticipating the same issues. We will know more early next week when he gets to try the headers on. Looks like its only one pipe on the d/s that is hitting the power brake booster.
I know that the engine in the 67 I did seemed to be way foward as well.
Anybody have a 73-87 with the ece or cpp mounts?
Old 05-01-2008, 01:24 AM   #42
Captkaos
Captkaos's Avatar
If they are these plates, they are the same as everyone elses stuff.. Common 4 hole SBC mount with a LS 3 hole mount and common lower hole, spacing won't be any different.
http://carshop.carshopinc.com/produc.../86959/C/S2349
here is the comparison:
Carshop:
S&P:
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Last edited by Captkaos; 05-01-2008 at 01:32 AM. Reason: apparently I was dislexic
Captkaos is offline
Old 05-20-2008, 04:01 AM   #43
pcmcobra
pcmcobra's Avatar
Ok,
I got the headers today, and I can verify I am having the same issue as capt, kaos.
I am using the carshop plates, pretty much the same "standard" design as posted above.
Drivers side is hitting firewall "protrusion, same exact as posted above.
Passenger side seems fine:
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline
Old 05-20-2008, 04:04 AM   #44
Hart_Rod
Hart_Rod's Avatar
[quote=pcmcobra;2729329]Ok,
I wonder if the ECE mounts will give you more room? I know they will move the engine forward a couple of inches. Do yoyu have the room?
Hart_Rod is offline
Old 05-20-2008, 04:10 AM   #45
pcmcobra
pcmcobra's Avatar
Rob,
I am not sure. I could look it over and see, who's got some ece mounts for me to try?
pcmcobra is offline
Old 05-20-2008, 04:23 AM   #46
Hart_Rod
Hart_Rod's Avatar
Originally Posted by pcmcobra View Post
Rob,
Just measure 2" forward all the way around and see if anything hits, .
Hart_Rod is offline
Old 05-20-2008, 04:52 AM   #47
pcmcobra
pcmcobra's Avatar
ouch, those ece mounts are $219...
I'd rather use the mounts I have. Even sent the tranny xmember off to get a little "work" done to it so the 80 will bolt up.
Hopefully we can get this figured out.
pcmcobra is offline
Old 05-20-2008, 05:05 AM   #48
GKsport67
GKsport67's Avatar
Nice,i plan to upgrade to a LS1 later!!
I need some headers for my 283 v8
Can u(beat) give me a better price than $275?
GKsport67 is offline
Old 05-20-2008, 05:09 AM   #49
Hart_Rod
Hart_Rod's Avatar
You could always try this........................
Hart_Rod is offline
Old 05-20-2008, 05:17 AM   #50
pcmcobra
pcmcobra's Avatar
lol@rob...
I have not gotten to that point yet...but I do have a bucket full of BFH's for stress relief, or persuasion...
pcmcobra is offline
Closed Thread
