Old 08-11-2008, 04:56 PM   #26
umwtnt
umwtnt's Avatar
Re: Remote master cylinder mounted under dash
Hey, The progress is slow. I have managed to exopy my cab and am working on raising the bed floor so I can exopy prime it and the front end. As you can see I like it. I have also completed my rear disc brake set up and got the front brakes on. I also painted my engine body color and this past weekend painted my transmission, no pictures yet. My wife came down ill again a couple of weeks ago and my time with the truck therefore has slowed down. She's beginning to feel better so hopefully I can get back to the shop. Thanks for asking.
Name:  Truck build july 2008 009.jpg
Name:  Truck build july 2008 016.jpg
Name:  Truck build july 2008 017.jpg
Name:  Truck build july 2008 019.jpg
umwtnt is offline   Reply With Quote
Old 08-11-2008, 06:48 PM   #27
BigShoe24
True Addiction
BigShoe24's Avatar
The Cab Looks great! nice work on the brake set-up. Keep us updated.
BigShoe24 is offline   Reply With Quote
Old 08-11-2008, 08:09 PM   #28
jlaird
jlaird's Avatar
What did you do for a rear brake setup? Looks good!
jlaird is offline   Reply With Quote
Old 08-11-2008, 09:08 PM   #29
scotts62
One day...
scotts62's Avatar
Well hope she gets to feeling better.
Looks good! i like the way the frame turned out
Scott
93 crew cab build
Project 62
Old 08-11-2008, 10:28 PM   #30
Riveted1
Tasty Cakes!
Riveted1's Avatar
I like that a lot! That's going on the list of future mods for one of my rides... Now if I can just do remote control steering, the firewall will be CLEAN Oh ya, rest of it looks great too!!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 08-14-2008, 04:36 AM   #31
umwtnt
umwtnt's Avatar
Jlaird, I use a hodge-podge system. I purchased a set of plans for $20 off of E-bay. The plans were set up for camaro calipers, if you wanted an E-brake or Chevy front calipers otherwise. The plans came with full size prints for the caliper brackets. I used Cadillac calipers so I had to drill out the brackets different from the plans. Everything has fit well. I used the brake hoses and the short e-brake cables from the cadillac. If you don't have to wide a wheel the 15 inch wheels will fit over everything with plenty of clearance.
Old 08-14-2008, 07:15 AM   #32
jlaird
jlaird's Avatar
Nice. Do you have a link to the auction?
Old 08-14-2008, 12:06 PM   #33
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I hope you have better luck with the ABS master cylinder then my buddy had. After problems with it, having ABS replace the pump and M/C twice, we ripped all of it out and went with a Hydraboost system. Works awesome now.
Truck looks great BTW!
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-16-2008, 01:34 PM   #34
umwtnt
umwtnt's Avatar
Jlaird, I've look for that brake listing and cannot locate it any more. I purchased the plans probably 3 years ago. Let me see if I can get full some copies some place and if I can I will PM you for your address. check out new thread I will be posting under regular forum. I will call it Previous owner.
Old 08-16-2008, 02:54 PM   #35
scotts62
One day...
scotts62's Avatar
Not too change subject..
Where did you get the fuel tank, and what kind is it?
Scott
93 crew cab build
Project 62
Old 08-16-2008, 05:30 PM   #36
umwtnt
umwtnt's Avatar
I purchased that up in Carlisle about 5 years ago from the Truck shop. It came with tank, straps and sending unit. If memory serves me correct it is a 21 gallon tank but, please don't quote me.
Old 08-17-2008, 12:31 AM   #37
scotts62
One day...
scotts62's Avatar
Thats cool i was just curious, thinking of getting one for the ol truck. Thanks
Scott
93 crew cab build
Project 62
Old 11-18-2013, 06:11 PM   #38
Drewski23
Bumping this so hopefully the OP gets a notification...hoping to see how this all ended up because im re doing the brakes and wanting to shave my firewall
Drewski23 is offline   Reply With Quote
Old 11-18-2013, 09:42 PM   #39
dv8customs
dv8customs's Avatar
OP was last on this site 7/30/2012 so I would say you are out of luck.
dv8customs is offline   Reply With Quote
Old 11-24-2013, 04:58 PM   #40
jmedero
jmedero's Avatar
I have te Scott's hot rods u it in my 68 Burb. Also mike Losh 67cheby did it on square peg this year. It's an awesome set up. You can email justin who owns Scott's hot rods on the forum (scottshotrods) or call te shop at 1 (805) 485-0382 he will take great care of you.
Juan
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 11-25-2013, 01:08 AM   #41
Drewski23
do you have pictures of the installed setup? on page 19 of your build you have a few pictures but i dont see how a booster is going to fit without removing the wiper motor..unless you just took yours out? i was assuming you didnt because you left cogs
Old 11-25-2013, 01:17 AM   #42
jmedero
jmedero's Avatar
I'm going to use the street rod wiper set up. I have not installed it yet. I got the kit from justin. I had planed to install one of these kits anyways since the factory option of not fast enough and wide open on the wipers doesn't work for me.
If you run a manual brake set up you can actually use the factory wipers. I've seen several guys do it that way.
Old 11-25-2013, 01:36 AM   #43
Drewski23
so if i have a 3 speed column id just have to go to a floor shifter to use under dash kit? I was going to go frame mount but im doing l/ts and cutouts on the exhaust so that doesn't leave a ton of room.
also do you have any information/pics on the wiper set up? i didnt see anything on their site about it thanks again
ill give scotts a call tomorrow
Old 11-25-2013, 12:15 PM   #44
Scottshotrods
On the wiper kit we offer it is a specialty wiper motor kit.This kit has a 2sp and intermediate speed as well.This will give you plenty of room with our under the dash pedal assy we manufacture.We have both in stock and ready to ship out.
(805)485-0382
Justin
Scottshotrods is offline   Reply With Quote
