Old 12-06-2008, 04:36 AM   #26
dazza
dazza's Avatar
Re: Header Solution
Plans on making something for manual transmission? or do you know of a solution for the linkage issue?
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 12-06-2008, 05:26 PM   #27
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
Nothing for BB yet and the only way we found to deal with the manual linkage issue was to convert it to hydraulic system.
Jokers69 is offline   Reply With Quote
Old 12-10-2008, 08:10 PM   #28
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
larry may your headers are on the way.
Old 12-10-2008, 08:29 PM   #29
larry may
Smile Re: Header Solution
Steve : I recieved the tracking number. My thanks and appreciation goes out to you and your shop(s) for the quick and punctuial expediancy. I appreciate the communication and progress reports as these were being fabricated.
Thank You
Larry
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 12-10-2008, 10:02 PM   #30
LuckyHenriksen
LuckyHenriksen's Avatar
Re: Header Solution
Any luck with the LS flanges?
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-10-2008, 10:50 PM   #31
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
There is no way it can be done with the template we built. We would have to have a truck with that motor setup in it.
Old 12-10-2008, 11:14 PM   #32
LuckyHenriksen
Re: Header Solution
Ok cool just checkin
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-14-2008, 02:45 PM   #33
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
They do fit 4X4 automatic thanks 67ZL1 for test fitting them for us.
Old 12-15-2008, 12:56 AM   #34
2wd73blazer
Re: Header Solution
Look like nice headers. I could use a set for BB if you decide to make some.
2wd73blazer is offline   Reply With Quote
Old 12-15-2008, 11:30 AM   #35
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: Header Solution
Would there be any problem with vintage air A/C?
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 12-15-2008, 10:54 PM   #36
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
I'm not sure. I'll look in to it. Does Vintage Air use a bracket off the exhaust bolts to hold the compressor?
Old 12-16-2008, 11:17 AM   #37
local13hutch
MEMBER
local13hutch's Avatar
Re: Header Solution
I was wondering if these will work with angled plug heads.
86 sub 4wd, 1 ton, duallie, big block th475
72 c10 short fleet, pro street
72 K/5 blazer,2x4 almost stock
72 3/4 ton sub 4x4
61 morris minor pickup, chevy 4.3 v6
03 escalade, 24" momo's wifes
96 2wd 2door tahoe
67 2wd suburban
72 4wd k5 99 vortec 14bolt/d60 205/th400- 72 4wd crewcab 1 ton sb cummins allison -2012 2ss camaro black hard top- 8 yamaha quads- 05 4wd one ton duramax dually, family limo.
local13hutch is offline   Reply With Quote
Old 12-17-2008, 12:32 PM   #38
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
I'm pretty sure they will with 90 degree boot, short header plugs and running the wires in the factory location. I will look in to this and let you know.
Old 12-19-2008, 01:27 PM   #39
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
These Headers are now avalible in stainless 304
Includes:
100% 304 stainless 16 gage tubing (.065) for primaries.
100% 304 stainless 14 gage collectors (.083).
100% 304 stainless header flanges (3/8")
CHROMEX ceramic coated ball flange collars
100% 304 stainless 16 gage tubing (.065) for female adapters with ball/socket and CHROMEX coated flanges.
Coated header bolts.
Coated collector nuts & bolts.
The price on these are 975.00 plus Shipping Thanks
Old 12-20-2008, 11:22 PM   #40
larry may
Re: Header Solution
I recieved the headers in a very timely manner and they look great . Much better than others I have purchased in tpast years.
TTT for you Steve
Old 12-21-2008, 12:15 AM   #41
bdydrp97s10
bdydrp97s10's Avatar
Re: Header Solution
it depends on which brackets you getr from Vintage Air..
the Steel-Eez brackets mount off the exhaust manifold
but if you opt for the alan grove brackets they dont come off the manifold.
but every kit ove seen on our teucks mounts off the manifold, haent seen one with the alan grove brackets yet
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333
bdydrp97s10 is offline   Reply With Quote
Old 12-22-2008, 07:44 PM   #42
Wootdog
Wootdog's Avatar
Re: Header Solution
How about for a LT1 in a 67 C10 with a 4L60E automatic transmission? No matter what I do, I can't get the headers to not leak I have installed. They leak on both sides out of the flanges that bolt to the aluminum heads.
Kerry
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 12-22-2008, 11:17 PM   #43
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
They should fit your truck with no problems. Just have to use lokar transmission linkage.
Old 12-28-2008, 10:28 PM   #44
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
The shop that makes them has said $75.00 off for a limited time.
Old 12-31-2008, 11:58 AM   #45
71cadc10
71cadc10's Avatar
Re: Header Solution
Man, I second on the gen III flange. Wish I lived closer you could use mine for template.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 01-06-2009, 01:11 PM   #46
kcjones
I wish I was a cowboy
kcjones's Avatar
Re: Header Solution
I will get some as soon as finances allow. I would want either the 1 3/4 primary uncoated or 1 3/4 coated, can't afford the expense of the stainless. Non-stainless still available, right? 3.0 inch collector?
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 01-06-2009, 01:55 PM   #47
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
Yes non-stainless are still available and they have 3 inch collectors.
Old 01-10-2009, 10:09 PM   #48
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
Still on sale any takers?
Old 01-10-2009, 10:17 PM   #49
Re: Header Solution
These look like they`ll work with manual trans.Did you figure for that?(I hope)
Old 01-11-2009, 04:10 PM   #50
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
They will not work on manual transmisson with factory clutch linkage
