View Poll Results: louvered hood poll | |||
keep the hood | 52 | 37.96% | |
ditch the hood for cowl induction | 85 | 62.04% | |
Voters: 137. You may not vote on this poll |
01-01-2009, 03:18 AM | #26 |
THE DAMN YANKEE
Re: Building the damn yankee
removing the bed the easy way
My 20 yr ols son sand blasting the frame rear ready for fabrication/ modification this is the military metal ID tag that was riveted to the glove box door. check out that fine looking olive drab interior paint scheme the rockers were installed with screws i can't wait to look under these patches and what kind of surprise the PO left me |
01-01-2009, 10:04 AM | #27 |
Interesting build so far.
01-01-2009, 01:06 PM | #28 |
VA72C10
Nice fabricated parts...will be following the build.
Looking for a 67-72 swb or blazer project in or around VA. |
01-03-2009, 11:25 AM | #29 |
Tot Roddin'
phipp... this is turning out to be quite the build. Keep up the great work and keep us posted on your progress.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-03-2009, 11:41 PM | #30 |
The Early Chevy Van Man
sweet burnout pics!!! love it. I also love the louvers. Cowl induction doesn't look right on these trucks... looks goofy and out of place. The louvers are cool and ol skool and different. I day keep the louvered hood.
64 Chevy Van 65 GMC Handi-Van 99 2500 silverado 4x4 ext cab |
01-05-2009, 01:48 AM | #31 |
THE DAMN YANKEE
gettin down to serious bizzness. the more i opened it up the more rust i saw.i neglected to buy the front&rear doorjamb extensions but they're on their way as well as new cab mounts. thank god for my grinders and air chisel!!
this is the rough cut out still a little up the toeboard has to go to remove all the rust skin was removed with an air chisel applying upward force as not to distort the doubler prior to removal the cab north/south support was welded to bushing perch so the cab wouldnt shift when the floor was removed this bar was welded in to keep the door post from moving while removing the entire bottom of the pillar imho if you don't do this you're screwed when it comes to getting it to all line up again more photos to come as i'm doing the floor/ lower cab in quadrants to prevent any movement while cut out and to ensure it will line up with the new replacement panels. most people would look for a new cab before doing all this work. in the mid atlantic region the rust free cabs are 1 on totaly restored trucks or rare as hens teeth and cost a bundle. i should have all 4 quadrants done in about 4-6weeks and aprox 300.00 in new sheetmetal repair panels. Last edited by phipp13; 01-05-2009 at 02:08 AM. Reason: comments |
01-06-2009, 10:18 PM | #32 |
THE DAMN YANKEE
while waiting for my pillar extensions to arrive, i worked on my vent boxes, here are a few pics of the repairs i have made. i have more detailed pictures if anyone needs them pm me. v/r phipp13
might as well go all the way cut all the rust out. pic of the flush repair i used a pneumatic step flange/hole punch tool . All the holes will be plug welded hey look twins! except this ones worse the bottom is rotted out too. after i blast the cab i will POR15 these areas and paint them before welding them shut. Last edited by phipp13; 01-06-2009 at 10:27 PM. |
01-07-2009, 10:20 PM | #33 |
Restoring a 68 SWB
Just finished up this vent box on mine. I had to cutout the bottom of mine too. I don't think I'll have to cutout the bottom on the drivers side.
Very detailed build. Keep it up. I am doing some similar stuff and need all the help I can get .
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
01-07-2009, 11:14 PM | #34 |
Under Construction
looking good bro.... keep at it!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
01-08-2009, 04:09 AM | #35 |
Looks great man! What are these gas delete things I'm hearing about?
01-11-2009, 01:11 AM | #36 |
THE DAMN YANKEE
Today was a good day! the Damn Yankee took a whoppin from me YA! Some days everthing you touch turns to crap. well today was just the opposite. i got the whole left front fitted, clamped drilled, clecoed, and the floorpan partially spotwelded in. thats a monumental task considering how anal i am when it comes to metalwork. It's learned behavior being that i'm an aircraft sheetmetal mechanic/ aircraft welder. the Dates are wrong on my camera
pic of my cutoff grinder with .032 cutting wheel. final trimming of floorpan pic showing the .032 gap created by cutoff grinder.i butt my pans and spot mig them in. the .032 gap is perfect to weld shut. there is room for shrinkage therefore it wont buckle when it's welded. patience is the key for doing a decent job. Last edited by phipp13; 01-14-2009 at 12:46 AM. Reason: commentary |
01-11-2009, 01:54 AM | #37 |
VA72C10
nice work....care to come a little south to patch up my rockers
01-11-2009, 02:04 AM | #38 |
Looks real good, I do it the same-1/32 gap to but weld. I wish I had that grinder instead of a pistol grip and/or die grinder with 3" wheel.
01-11-2009, 05:45 AM | #39 |
Restoring a 68 SWB
Looks good. Keep the pictures coming. I started pulling off my rockers tonight, so I need as much info/pictures as possible .
01-11-2009, 06:42 AM | #40 |
THE DAMN YANKEE
Trai, you got my # call me if you have any questions any time. i'd be more than happy to help. V\R phipp13
01-14-2009, 12:44 AM | #41 |
THE DAMN YANKEE
Floor Pan is in 90%, i'm looking forward to this weekend. Monday is a holidayday off for me. Hopefully i'll have pics of the entire leftside completed. If you look closely you can see how i plug welded the floorpan in. I've had great success doing my floorpans this way. if anyone has any questions feel free to P.M. me and i'll try my best to answer them, V/R Phipp13
01-14-2009, 05:39 AM | #42 |
Restoring a 68 SWB
Looks really good from here. We need to have some stuff ready for you on Project Underhaulin .
01-14-2009, 08:16 PM | #43 |
THE DAMN YANKEE
BRING IT!!! let me know the plan and i"ll bring my tools. V/R phipp
01-14-2009, 11:09 PM | #44 |
looks great man! you are doing some great work
01-15-2009, 02:53 PM | #45 |
looking good man
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 http://i195.photobucket.com/albums/z...en58/001-2.jpg |
01-16-2009, 10:48 PM | #46 |
THE DAMN YANKEE
I got my engine combo dynoed by shaun/ Super73 ran my truck on the dyno and gave me charts and graphs. what a nice guy too. that takes time and he did it for nothing in return! #s to be posted in 30 mins
01-16-2009, 11:56 PM | #47 |
Under Construction
Waiting....
01-17-2009, 02:50 AM | #48 |
Looks like you use a spot weld cutter to make plug weld holes with the panel in place-never thought of that!
01-17-2009, 04:11 PM | #49 |
looking very good, you have done a nice job on the fabbed parts and sheetmetal work!
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 |
01-17-2009, 10:14 PM | #50 |
THE DAMN YANKEE
got my Dyno number on my 383 not too shabby. they're rwhp and drag co-effiency is factored in. i'll run what i got for now. most importantly is gettin this back together and down the road!!
