Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-07-2009, 12:49 PM   #26
worley91
Big Boys With Big Toys
Re: Mini Spool?
Isn't a mini spool a circle track set-up?
worley91 is offline   Reply With Quote
Old 02-07-2009, 12:57 PM   #27
djracer
djracer's Avatar
Re: Mini Spool?
they use them too but they work pretty good and are cheap.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-18-2009, 05:02 PM   #28
VOLZ1207
Re: Mini Spool?
Originally Posted by straitnate14 View Post
you could put a carrier locker in it thats more work and might require a gear change I'm probly going to build the 12 at first with a c-clip kit and a detroit locker in it the spool is cheap but I can see either a broken axle or a destroyed carrier, and ring and pinion set I think that you should just send the spool back and get a good locker and gear set but whatever you do dont put a powertraxx in it, I have gone through 2 of them
straitnate14 i put a powertrax in mine and im running the heavier springs. it pops occasionaly as you're probably familiar with. what happened to yours when they failed? thanks, take care
VOLZ1207 is offline   Reply With Quote
Old 04-18-2009, 10:41 PM   #29
72 SUPER10
Re: Mini Spool?
no company makes a good mini spool that will take the punishment of traction and some fair horse power IMO.
72 SUPER10 is offline   Reply With Quote
Old 04-19-2009, 12:26 AM   #30
worley91
Re: Mini Spool?
I watch them be abused weekly by 500+ horses at the dirt tracks
Old 04-19-2009, 03:55 AM   #31
mongoose
mongoose's Avatar
Re: Mini Spool?
totally different...
traction on dirt is no where near what you get on pavement....
you can put 1000hp through a 7.5"... as long as it never hooks up.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 04-19-2009, 08:53 AM   #32
djracer
djracer's Avatar
Re: Mini Spool?
In my old 67 camaro with a 9 inch I made about 1000 low 7 second 1/8 mile passes on a stock 9 inch with 28 spline axles and a mini spool. When I stepped up the combo to run high 6's I broke 1 stock axle and 1 crosspin in the mini spool before going to 35 spline stuff with a spool.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-19-2009, 02:14 PM   #33
jgreene0717
Jason
jgreene0717's Avatar
Re: Mini Spool?
I have the auburn mini spool in my 71-c-10. If you do not mind dragging your tires around corners get it. If not just buy the powertrax unit.
jgreene0717 is offline   Reply With Quote
Old 04-19-2009, 04:18 PM   #34
worley91
Re: Mini Spool?
ha. I can tell how much time you spend around a dirt track. Cars that are set up right hook up just as hard on dirt as they do on asphalt
Old 04-19-2009, 05:27 PM   #35
mongoose
mongoose's Avatar
Re: Mini Spool?
so... you're saying.. if you punch it from a craw it wont spin....
every car i've seen on a dirt track has, even just a tiny tiny bit.. but it's enough to unload the rear.... from crappy hornets.. o 410s...
theres alot more load in the rear when starting from a stop than going from a roll as well
Old 04-19-2009, 07:59 PM   #36
shortbed70
shortbed70's Avatar
Re: Mini Spool?
Piece of cake to put in I've run one in my 12 bolt for two years and no problems but now I have a factory lsd again. They are very hard to push around a corner.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 04-21-2009, 03:27 PM   #37
Chlsnk
Chlsnk's Avatar
Re: Mini Spool?
I am also planning to put one on. I figure I will go with the summit brand mini spool .
Chlsnk is offline   Reply With Quote
Old 04-24-2009, 09:16 PM   #38
72 SUPER10
Re: Mini Spool?
dont say i didnt warn you , a mini will do ok in a (car) making ok power and fair traction , but i broke 4 mini spools of all brands and cross pins,never broke a axle in my 72 chevy (truck) . it was a factory 31 spline and it was a 9 inch out of a 71 ford truck, imo the 12 bolt is a much better rearend anyway and its chevy. and my truck ran 7s on motor.your trucks will break a mini spool, i promise, vince.
Old 04-25-2009, 02:30 PM   #39
LuckyHenriksen
LuckyHenriksen's Avatar
Re: Mini Spool?
groovy thanks for sharing
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 04-26-2009, 10:10 AM   #40
shortbed70
shortbed70's Avatar
Re: Mini Spool?
New update on my mini, I just sold it yesterday to a friend and looked at the axles. Theres about 7000 miles on them stock 30 spline and there is wear evidence on them but no twisting but you can see where the splines are worn on both sides. Went back to open to sell truck.
Troy
Big Red Dog build
Old 04-26-2009, 10:06 PM   #41
scatesracing
Machinist
scatesracing's Avatar
Re: Mini Spool?
I had a n axle break and a bearing cap break but the mini was fine in both cases?????????? It was a cheep cheep one too
scatesracing is offline   Reply With Quote
