Old 01-12-2009, 11:14 AM   #26
joe231
joe231's Avatar
Re: Here's those pics of the under dash pedal assembly
I have a question....
in the first picture, I noticed the 2 assemblies on the right seem to have an extra little bend....what gives?
CHEVY ONLY
Old 01-12-2009, 12:41 PM   #27
jephs422
Not sure, I'll have to ask Justin that one. I know there were a few for a couple different applications being built, and I just snapped a few photos of the ones on the table, but I can't be sure.
Justin, let me know if you want me to start a group buy thread.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
jephs422 is offline   Reply With Quote
Old 01-12-2009, 05:23 PM   #28
tonythezeek
tonythezeek's Avatar
OOOO! i'm down. where do i sign up for the group buy?
tonythezeek is offline   Reply With Quote
Old 01-12-2009, 07:00 PM   #29
yfz450_0569
Is this assembly also available with an 11" booster? and if so how much for the whole kit with master cylinder, 11" booster, and pedal?
yfz450_0569 is offline   Reply With Quote
Old 01-12-2009, 08:08 PM   #30
jephs422
What you are seeing is not an extra bend, it is the angle you are looking at it. What appears to be an extra bend is the way the pedal arm comes back. It's not bent there at all.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 01-12-2009, 08:12 PM   #31
joe231
joe231's Avatar
weird.....camera trick
CHEVY ONLY
Old 01-12-2009, 08:16 PM   #32
scotts62
One day...
scotts62's Avatar
Scott
93 crew cab build
Project 62
Old 01-12-2009, 11:35 PM   #33
71blaze
I just installed a similar system and there is no way that an 11" would fit behind the dash that i was using.
71blaze is offline   Reply With Quote
Old 01-12-2009, 11:54 PM   #34
XXL
Seņor Member
XXL's Avatar
Ain't happ'nin... there is simply not enough room for an 11" booster back there.
edit: Whoops... what 71blaze said.
XXL is offline   Reply With Quote
Old 01-13-2009, 01:46 AM   #35
Scottshotrods
[QUOTE=yfz450_0569;3082453]Is this assembly also available with an 11" booster? and if so how much for the whole kit with master cylinder, 11" booster, and pedal?[/Q
there is no room for a 11 inch booster at all it will hit
the back side of the dash.
Unless you want to remove your dash all together
then it will fit.Just joking there.
The 7 inch booster will stop your truck with no problem
at all.
Thankyou,
Justin
Scottshotrods is offline   Reply With Quote
Old 01-13-2009, 08:38 AM   #36
N2TRUX
Happy to be here
N2TRUX's Avatar
To participate in the group purchase go here> LINK
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-13-2009, 09:45 AM   #37
yfz450_0569
[quote=Scottshotrods;3083343]
at all.
Thankyou,
Justin
The thing is I have 14" 6 Piston Baers up front and 12" 2 Pistons Baers in the rear and I want a booster large enough to handle them pretty well...
Old 01-13-2009, 11:49 AM   #38
XXL
Seņor Member
XXL's Avatar
[quote=yfz450_0569;3083622]
That fact won't make the 11" booster fit under the dash.
Old 01-13-2009, 11:57 AM   #39
joe231
joe231's Avatar
sounds like a custom dash is in your future.......
my thought is the big brakes would require less force on the WHOA pedal than a stock brake set-up to stop the same mass.....so the smaller booster should do just fine.....
may be off on this, but that is how it would seem to me
CHEVY ONLY
Old 01-13-2009, 11:59 AM   #40
yfz450_0569
[quote=XXL;3083782]
That wasn't my point, my point there was that I didn't only want a 7" cuz I have these brakes...
Old 01-13-2009, 12:03 PM   #41
yfz450_0569
Ok then... maybe this is where I ask some more questions, I'm almost to the point where I'll be getting this stuff. Would this 7" really do? I don't mind trying new things to make the 11" work if it is possible...
Old 01-13-2009, 12:10 PM   #42
Scottshotrods
In our shop we have several builds going on now.Every car or truck in our
shop have 13 and 14 inch rotors and wilwood 6 piston calipers on the front.
On the rear we have 4 piston calipers.We have been running the 7 inch
booster on our builds for over 10 years.We have never had a problem
with the brakes not working good.Hopefully this helps you out.
Justin
Old 01-14-2009, 09:15 PM   #43
71blaze
You would have to cut into the firewall and the dash.
It would be possible but by doing all of this you would be defeating the purpose of hiding it and it isn't nessasary.
Old 01-14-2009, 09:43 PM   #44
scotts62
One day...
scotts62's Avatar
Im sure the 7" would be fine but you could mount the peddle and try and put the 11" it its works then cool if not then put the 7" in it and run with it.
Scott
93 crew cab build
Project 62
Old 01-15-2009, 12:35 AM   #45
N2TRUX
Happy to be here
N2TRUX's Avatar
Guys, read Justin post. He tells you that the 7" is all that's needed.
Articles-
"Refining Sierra"
Old 01-15-2009, 03:37 PM   #46
jephs422
Both my Comanche, and Willy's wagon on 37's have a 7" booster with Wilwood 6 piston 13" fronts and 11" 4 Piston rears. I have absolutely ZERO issues stopping with either one of the them.
If you do want an 11" booster though, this pedal assembly would probably require too much work.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 01-17-2009, 09:16 AM   #47
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
sorry for the delay on pricing.Here is
the price on the pedal assy
1.Scotts under the dash pedal assy$249.95 each.
2.7 inch master booster $179.00
3.dual remote resv $80.00
4.remote cover for master $55.00
we do have them in stock and ready to ship.We can do a group buy on
them if we get 10 people who would
want one.
Thankyou,
Justin
www.scottshotrods.com
Count me in on this.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 01-17-2009, 08:53 PM   #48
blazntn
What are yall going to do about the windshield wiper motor? I am pretty sure it is going to be in the way!
blazntn is offline   Reply With Quote
Old 01-17-2009, 09:01 PM   #49
XXL
Seņor Member
XXL's Avatar
Yup, it's got to go. I've been using the original Kugel unit for several years, and there is no spare room under this part of the dash. I originally did a bunch of work fabbing linkage to let me swap the motor to the right side and let the left side be the idler side, but that was a mess. I am currently using a pair of small, independent "hot rod" style motors to run each wiper. They're wired in parallel so they flip-flop together, but because it's 2 motors, there's enough variance that they get slightly out of sync. It doesn't affect their functionality, though I've probably only used them twice, and I Rain-X my windshield. At some point, I'll probably just shave them altogether as several others on the board have done.
Old 01-21-2009, 01:00 PM   #50
Rokcrln
Rokcrln's Avatar
XXL I was planning on using this kit so I could shave the cowl and still have wipers. A few friends have used this kit in their rods and really like how well they work and the motor can be mounted any were you want it. This pic does not show it but the cable you see runs through a brake line type tube so their are no moving parts for you wiring or anything to rub on. http://store.summitracing.com/partde...part=HFM-WIPER
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
