Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 07-01-2009, 11:46 PM   #26
Captainfab
60-66 Nut
Re: Impala SS Rear Disc Brake Brackets
OK that's good. It looks like Outlaw72 will be taking the set I currently have, so I'll need to get some more laser cut. I'll get those ordered tomorrow and let you know a time frame.
Old 07-02-2009, 09:03 PM   #27
Outlaw72
Hay Team!!
Outlaw72's Avatar
paypal sent for the brackets and line adapters...
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
Old 07-02-2009, 09:24 PM   #28
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Nice job on these! I haven't made Impala brackets for a couple years now, so I'm glad someone else is. I still get PM's asking when I will make another batch, so I will steer them your way from now on!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-02-2009, 10:17 PM   #29
Captainfab
60-66 Nut
Originally Posted by 61superman View Post
hey captinfab
just so you know i would like to buy two sets thats not a problem. let me know either way
I got some more on order and I should have them by the middle of next week. I'll let you know when they're ready to ship. Thanks
Old 07-02-2009, 10:23 PM   #30
Captainfab
60-66 Nut
Thanks for the compliment
You did an excellent job on the Camaro caliper brackets. While you were gone and so many were wanting them, I considered making some but I didn't want to do that until I heard back from you. I looked at your design and tried to figure out a different way to make them, but your design is the simplest and just how I would make them. Do you plan to make any more of the Camaro caliper brackets?
Old 07-02-2009, 11:40 PM   #31
glock35ipsc
Thanks Captn! I do plan on making some more Camaro brackets in the near future.
Bob
Old 07-09-2009, 12:48 PM   #32
Captainfab
60-66 Nut
I have another run of these disc brake brackets available.
61superman I sent you an invoice as requested. Thanks
Old 07-10-2009, 05:53 PM   #33
61superman
61superman's Avatar
paypal sent thanks again
61superman is offline   Reply With Quote
Old 07-10-2009, 11:02 PM   #34
Captainfab
60-66 Nut
Thanks for the purchase .....they will ship out tomorrow.
Old 07-14-2009, 09:22 AM   #35
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Great guy to deal with people. And a very nicely made piece to boot.
--Josh
Old 07-14-2009, 02:40 PM   #36
GR82BME
GR82BME's Avatar
Excuse my ignorance, but do you need the impala caliper and disc and they just bolt up? Are the discs 5X5 bolt pattern? Sounds like a pretty sweet setup, I might have to do this to my truck if that is all that is involved.
GR82BME is offline   Reply With Quote
Old 07-14-2009, 10:47 PM   #37
Captainfab
60-66 Nut
To do this conversion you basically need the calipers and the factory caliper brackets (or cage as some call them), the brake pads, hoses, and the rotors (yes they are 5x5 bolt pattern) and the adapter brackets from me. There are a few other small items you will need, but these are covered in the list of parts I provide with the adapter brackets. Of course you will need the appropriate master cylinder and proportioning valve (adjustable or fixed) to operate the 4 wheel disc brake system.
Old 07-14-2009, 10:49 PM   #38
Captainfab
60-66 Nut
Thanks for the kind words Josh
Old 09-07-2009, 09:43 AM   #39
68 TT
Still plays with trucks
68 TT's Avatar
[quote=Captainfab;3299120]
Originally Posted by Dahawk View Post
The Camaro or Impala's front calipers would match, but I don't know how you would mount them to the spindles on your truck. The biggest issue would be the thicker rotor on the trucks. The aftermarket might be the option for that. I'll have to do some looking and see if there is an OEM caliper that would work.
The 98 to 2002 Camaro front caliper is on a 1.25" thick 12" diameter rotor so it would work on the same thickness truck rotor.
The guys on thirdgen.org have worked out ways of putting these PBR calipers onto their spindles that have cast in caliper mount bosses which could be adapted for use on our trucks too.
This caliper could be used on the 14-bolt rear disc conversion that uses the Dana-44 front rotors if you didn't need an e-brake.
68 TT is offline   Reply With Quote
Old 09-07-2009, 02:59 PM   #40
KcLevi
KcLevi's Avatar
Just a FYI GM used same prop valve for the Disc/Drum B-body they used it on the Disc/Disc B-body. Only 9c1 and SS had rear disc not Roadmasters.
KcLevi is offline   Reply With Quote
Old 09-09-2009, 12:02 AM   #41
Captainfab
60-66 Nut
[quote=68 TT;3505863]
Thanks for the info on that. I'll check into that when i get a chance. My son has a 2000 Z28 so that will make it easy.
Thanks for the info on that also
Old 12-20-2009, 12:28 AM   #42
Captainfab
60-66 Nut
Another bump.....
Old 12-26-2009, 08:48 PM   #43
Iron-Butt
454 club
Iron-Butt's Avatar
Do you still have a set left. will these fit the 1972 5 lug 10 bolt rear end.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 12-27-2009, 05:06 PM   #44
Captainfab
60-66 Nut
Yes I do still have these. They will fit all '63-'82 5 lug 12 bolts as well as the '83 and up 5 lug 10 bolts. Your '72 rear end should be a 12 bolt. Let me know.
Old 01-25-2010, 11:58 PM   #45
crob35
I would like a set of these brackets. I need your paypal address. Thanks
crob35 is offline   Reply With Quote
Old 01-26-2010, 12:18 AM   #46
Captainfab
60-66 Nut
My PayPal is captainfab454@hotmail.com
It will be a couple of days before I can ship these out......extremely busy right now. I'll try and get them out so you can have them for the weekend. Thanks.
Old 01-26-2010, 07:18 PM   #47
crob35
Paypal sent thanks again
Old 01-27-2010, 12:13 AM   #48
Captainfab
60-66 Nut
Your PayPal payment has been received. The plan is to send your brackets out tomorrow. Thanks
Old 03-29-2010, 09:17 PM   #49
bigarmzz
bigarmzz's Avatar
do you by some chance have any of these left? these should work just fine on my truck, 10 bolt 87 model, right?
thanks
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 03-30-2010, 12:33 AM   #50
Captainfab
60-66 Nut
Yes they will work, and yes I do have these in stock. I did slightly redesign them though.....just mainly gave them a little more shape instead of just a rectangle. I've just been busy and haven't posted new pics yet. Let me know how you would like to make the payment. I acept PayPal and money orders. You should be able to use a credit card thru PayPal as well.
thanks
