04-23-2009, 05:33 PM | #26 | |
Re: Need help with Z-ing!
It's laying, and I did research. I don't care about the money. I'm trying to learn new things a little at a time. I don't have time to keep my face in the computer screen all day searching for bag things. I have way to much to do throughout the day to search this type thing. I'll pay and me him work his magic lol. Look at a previous tread of his work on back and you'll see why I'm not worried. At this point he's getting a little extra cash. Maybe he should have done a 3in Z, but what's done is done. Always ways to get an 1in or 2 |
04-23-2009, 05:38 PM | #27 |
What should the Z be? Why have I searched and seen 2.5, and why the hell would you do 6in Z's???
04-23-2009, 06:14 PM | #28 |
Keepin it old school
Most people do a 3" - 4" Z..
You could always run 3" drop spindles. Summit has a good deal on DJM 3" spindles. |
04-23-2009, 06:21 PM | #29 | |
Well, we finished a 2.5 but did a lower arm step, 1.5. I'll just do a 3in spindle now. This route keeps my tranny tunnel lower, engine lower, and the 3in spindle and 1.5 arm step keeps my camber at a minimum |
04-23-2009, 06:23 PM | #30 | ||
So to help others that are considering mods like this in the future . . .... Establish the goal for the vehicle & design/build w/that goal in mind. In other words, don't build it to almost lay-out on 27" tall tires when your goal is to have it lay-out flat on 31" tires (it takes more work). I can't speak for others, but there's no raggin' on you from my camp. As always, post the pics of the truck once you have it back in your posession
04-23-2009, 06:27 PM | #31 |
truck is is being setup for a certain tire. I was on 15's so I found a steal on some 20's, $400, 2 were brand new tires, 1 was runflat, and 1 had a knot.
04-23-2009, 08:19 PM | #32 | |
If you know the height your trying to lay out with, the rest is just math calculations. If the tires are inconsistent, you set them up so they reflect the height your trying to achieve. All you technically need is one tire that's the correct dimension & work from there.
04-23-2009, 08:26 PM | #33 |
You also don't want to put those 3" spindles on top of those 1.5" stepped A-arms.
04-23-2009, 09:22 PM | #34 | |
I'll probably get new arms later on. I'm leaning towards a 20/22, always liked the smaller on front. 22's and you have to move the hinges, and I think 20's u don't. I've searched and seen pics and I saw a truck with a 20 on front and barely tucking tire and it looked great! Black truck, 20/22 Intro Vistas, set about a inch off ground, framewise. |
04-24-2009, 01:08 AM | #35 | |
Where's all the pics?!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
04-24-2009, 01:24 AM | #36 | |
Yea, and now my hood and fenders just came down another 2.5in lol. Where's everyone getting hood hinges at? I set this up for a 285/35/22. I ordered a Slam bag but after giving FBI like 2mths, I gave up and had the Doms drop shipped from Airlift. They compress a extra .3inches but they are a big bag. They are 2.7inches compressed, what are Firestones? I want new arms and spindles pretty soon. If I install my 454 and blower on a bigger Z than 2.5 then my scoop will be over the roof LOL. How can I lay a tire like I want on a Z my size? That's really all I need to do. He's stepping my arms 1.5 on a 2in spindle down the road when I get 22's. If I get arms then where do I stand? |
04-24-2009, 03:22 AM | #37 |
My suburban is laid out on a 28" tire in the front with no Z, 2.5" drop spindles, and no stepped arms.
My front will lay out on a 29" tire too.... Big Green, I'm not knocking you but you should have done some more measuring when you started. Have you figured out what ride height will be? When you step the lower control arms they will tend to hang to low. Like porterbuilt said you will need to get new hood hinges. They won't work, and your fenders will need to be cut to lay out. Alot of guys are getting the hinges from http://www.sachserodshop.com/pdf/212.pdf |
05-22-2009, 11:44 PM | #38 |
05-23-2009, 01:45 AM | #39 |
Tucn1ton, pic didn't show up but from the looks of that Burb, it's JJ's old Burban. He's from barling.
05-23-2009, 02:05 AM | #40 |
Just saw the pic in your profile. Your the guy who bought it, that's cool. One sweet ride! Some of these guys on here dont seem to like, or agree with my truck build, or my trucks plans. It's finished now, but if you don't mind, please tell these guys how chopped up and how crappy your trucks bagged job is on those 22in Budniks and that Z. You see, that job on your truck is pretty killer, well, mine is bagged and Z'ed by the same guy. Where were you from in Arkansas, I forget?
05-24-2009, 12:09 AM | #41 |
Theres no need for bigger than 2" of z. period. after 2 the engine gets raised to high.
if you already z'd it 2.5 then section the crossmember 1.25", raise the steering .5" to clear, cut the hell out the upper spring pocket and plate the inside, throw your stepped arms away and get ART arms or new stockers and reangle the upper bj. That setup will lay 22's with a 2" spindle or 24's with a 3" and with a slam bag get around 14" of lift. pics of 1.75 z, 1.25 c-member raise, cut upper pocket, 2" spindles and ART arms. setup is on 245/40/20's but still lays on top of 2x4's laid flat with -5 degrees of camber glad to see everyone else up to their usual mindset of bash the thread starter and provide no information. |
05-24-2009, 12:22 AM | #42 |
Where did you see this?
05-24-2009, 12:30 AM | #43 |
just the bs of he should have z'd more and measured twice...etc.
the guy asked what else can he do and that he's not z'ing anymore, and Im not sure, but out of two pages he may have gotton 2 or 3 answers? |
05-24-2009, 12:36 AM | #44 | |||
wrong
Im just saying, the guy asked a simple question, and got bashed for some irrelevant (for only z'ing 2.5). This is just tradition here though. and now I've been suckered into posting meanless bs as well. |
05-24-2009, 01:33 AM | #45 |
Cajundragger,
That's good info. I got my truck done. We did the 2.5In Z, dropped the Dom bags in the lower arm, cut and straigtened the upper arm to align the balljoint so it's not in a bind, and and it lays on my 20 with a 27in tire. I did do a 3in spindle to lay on a 22 in a few months. Plans are a 22/24. Trucks lays flat on pinch weld on that work, strange don't you think? LOL. Atleast you know that a 2in is fine. I have a electronic dist. with a Accel supercoil cap and even with the cap of the base where the cap sits hits the firewall. I'd hate to have a even bigger Z. I'll know more with my carb and breather on but it may be close to the hood then. I don't like the valve covers thru the hood look lol. |
05-24-2009, 01:55 AM | #46 | |
For the record, I didn't bash. What i read was he didn't want to spend over X amount of dollars & didn't want to do a bunch of extra work but then didn't end up w/what he wanted hence my suggestion of measuring twice, cutting once. I can only speak accurately for myself, but we (other members & myself) suggested drop spindles & that wasn't enough so I suggested more of a Z. If the guy can do a 2.5" 'Z', he surely can do a 3.5" Why would increasing the amount of 'Z' or adding 3" spindles cost more than removing the c.member, sectioning it, re-installing it, raise the steering, & then modifying the a-arms? Although we try to help, our answers aren't always what is wanted. That being said, they shouldn't be considered useless information. Just because one chooses a different option, it does not render all other choices worthless.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-24-2009 at 01:57 AM. |
05-24-2009, 05:33 PM | #47 |
know-it-alls are always good for a laugh ...
05-24-2009, 11:46 PM | #48 |
05-24-2009, 11:47 PM | #49 | |
05-25-2009, 12:01 AM | #50 | |
Happy to be here
Your insight and advice is appreciated, but your suggestion that bashing is the norm on this forum is not.
