Old 06-05-2009, 08:45 AM   #26
jmuck
jmuck's Avatar
Re: My '87 SWB Project w/pics!!
Hey man have you already had the bed on the truck with the drop shackles? I have done a few of these trucks with shackles and had to cut the bed brace to get them to fit.
Your truck is looking bada$$
When your in Nac. look me up!
jmuck is offline   Reply With Quote
Old 06-05-2009, 06:37 PM   #27
3r!c84
Badass
3r!c84's Avatar
yea i was going to get the 3/4 drop from beltech.its like the same set up idk if im going to cut some off the front spring..how can you go lower in the back?in the pics it looks at the highest point on the shakels ?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 06-05-2009, 06:44 PM   #28
flamingbig10
6.0 powered square
flamingbig10's Avatar
you could remove a few leafs or get lowering leafs springs
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 06-05-2009, 06:58 PM   #29
3r!c84
Badass
3r!c84's Avatar
yea but wouldnt that sagg down tomuch with some wight in the bed or pulling a trailer?
-00 Saturn 5spd
1/4:13:90
Old 06-05-2009, 07:57 PM   #30
flamingbig10
6.0 powered square
yes it would but you could add helper bags and if would give you little more towing capacity and also you'll have adjustable rear ride height
Aaron
Old 06-05-2009, 08:21 PM   #31
3r!c84
Badass
3r!c84's Avatar
yea i could take out one from each side..would lower it much but it will help out.
witch one would u take out?
-00 Saturn 5spd
1/4:13:90
Old 06-05-2009, 11:09 PM   #32
twoodson
johnc, thanks for the compliments, I'm hoping it look as slick I as I expected, I don't won't nothing flashy just simple and clean as hell.
Jmuck, yepper the bed brace had to be cut, I'm gonna cut me some sheet metal and weld it there to clean it up. I should be down Father's Day weekend and you know I will be looking you up bro.
3r!c84 If I am not mistaken I believe if I drop it down to the next hole it will lower it a little more in the rear, I think that's correct.
twoodson is offline   Reply With Quote
Old 06-05-2009, 11:14 PM   #33
flamingbig10
6.0 powered square
how mant leafs does your truck have and nice truck twoodson
Aaron
Old 06-06-2009, 12:59 AM   #34
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
i cannot wait till u get that tank done...im so gunna do this lol
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 06-06-2009, 11:31 AM   #35
3r!c84
Badass
3r!c84's Avatar
it only has 4 on each side
and on the shakel its allready on the top hole you cant lower it any more u can more it down to the lower hole but thats is going to lift it in the back
-00 Saturn 5spd
1/4:13:90
Old 06-06-2009, 01:23 PM   #36
twoodson
3r!c84; oh okay, I couldn't remember, I'm gonna leave it like that. I full tank of gas in the rear might lower it a little and flush mount bed cover. I will also be a trailer with my '70 VW on the back occasionally. Thanks for that info
Old 06-06-2009, 02:32 PM   #37
3r!c84
Badass
3r!c84's Avatar
and did u have to cut into the bed support?? for that kit?
-00 Saturn 5spd
1/4:13:90
Old 06-06-2009, 02:50 PM   #38
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Nice Project!!
I like it.
Kenny
87Lowrider is offline   Reply With Quote
Old 06-06-2009, 06:10 PM   #39
twoodson
3r!c84, yeah I had to cut into the bed support for the shackles to clear. I will post a pic either later tonight or tomorrow, I am about sit the bed back on for a few minuts so I can mock up were to cut the filler hole in the bed floor.
Old 06-06-2009, 08:00 PM   #40
3r!c84
Badass
3r!c84's Avatar
thanks i wanna see how much u cut outa the bed supports
Eric
-00 Saturn 5spd
1/4:13:90
Old 06-07-2009, 10:13 AM   #41
babyJay
Arrived on a Pale Horse
babyJay's Avatar
I've got one of those skid plates on the shelf upstairs in the garage, and could not for the life of me remember what the heck it came off of. Thanks. Nice progress, your truck will be awesome when it's done.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 06-07-2009, 11:33 PM   #42
twoodson
Well I got a little further this weekend. I spent Saturday pulling weeds and trimming hedges (did not plan on doing that); took my son to play a basketball game, put the bed on the truck to measure were I needed to cut the filler door in the bed floor, which i did not get it cut yet , but it will the next couple of days. Today I drilled the holes in the front and rear braces, that holds the fuel tank, to bolt up the skid plate. What a PITA, but I guess when your tooling with these ole trucks it's to be expected. Wasn't too bad I don't guess. The reason there is not bolt in the right side of the rear brace for the skid plate is that I forgot to re-tap it. I had to re-tap all the nut-holes in the skid plate due to the rust. There is always 1 you either forget or one that gives you hell.
3r!c84, I forgot to take a pick of underneath the bed, I should be able to get it done tomorrow evening after work.
Old 06-07-2009, 11:41 PM   #43
twoodson
Forgot to add pics; I am now trying to figure out what to do about the fuel lines from the sending unit of the tank. The motor is TBI so I am not for as to what I need to do, Take measurements and call inline tube, get some, russell, aeromotive, etc and plumb. I sent a message to SCOTTROD because I rad in Truckin' were Hill's Hot Rods put an '87 Blazer Tank in his truck, hopefully he will respond or I may try and call Hill's tomorrow to see what they say. If anyone has any suggestions, feel free to let me know. After I get that out the way I will make sure that everything is were it needs to be and I will start unbolting braces and the start the 3-stage por-15 process to the rear. Oops I still have to remove the hangers, shackles and leaf springs, which I can do while waiting to see what route to take on the fuel lines. The hanger and shackle will be coated in the polished ceramic and the leaf springs in Satin Black. Thanks everyone and PLEASE give me some ideas or contacts for the fuel lines issue.
Old 06-08-2009, 10:50 AM   #44
jmuck
jmuck's Avatar
fuel lines are gonna be the easiest thing to do just buy regular steel or aluminum lines b/c stainless lines are so hard to bend and harder to flare.
I would suggest 3/8" aluminum lines and just bend it where you need it to go along the frame. You can actully do alot of your bends by hand with the soft aluminum lines. Use small pieces of rubber to make them connect or flare them and bolt them together. Rubber is easier with just a regular hose clamp. Does the tank have the fuel pump inside or are you running an external one? Let me know and I will help any way I can.
Old 06-08-2009, 11:24 AM   #45
twoodson
JMUCK, it will be an in-tank pump, sounds pretty simple and cost saving$$$ which is right up my alley, I believe summit sales a roll of tubing, I need to order me a roll. I believe my sending unit has 3 different sizes, 3/8, 1/4 (vacuum) and I believe 5/16 I will have to double check. U R Da Man
Old 06-08-2009, 10:26 PM   #46
twoodson
Bingo, went to Oreilly's to see if they had any steel lines that I could use for fuel and they had various lengths of steel brake lines with fittings. So I will be using those for the main fuel line, return line and vacuum line. I just need to get the correct measurements and a tube bending tool. They were around $11.00 for a 5ft length. One more step out the way.
Old 06-09-2009, 09:42 AM   #47
JohnC
JohnC's Avatar
Nice find. We carry those lines at our hardware store too. They are a real life saver for a town with not automotive store yet.
JohnC is offline   Reply With Quote
Old 06-09-2009, 10:25 AM   #48
jmuck
jmuck's Avatar
Get the lines as long as you can b/c the less fittings the less problems with leaks. That is the good thing about buying a roll of line you will have no fittings in the middle of the frame. You can get a tubing bender from Jegs or Summit for less than $10.00 but if your local auto parts has one for a little bit more it would be worth getting it from there b/c you have no wait time and no shipping cost.
Old 06-09-2009, 10:41 AM   #49
boatpuller
boatpuller's Avatar
good work.......i like the truck.it will be bad as$ when you git r done.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 06-11-2009, 05:04 PM   #50
jmuck
jmuck's Avatar
Here is one of my buddies trucks we did. It has an LS1 and air ride. He is about to have me redo the air ride so it will lay the body on the ground.
Do you recognize the old 55 in the background?
