#26 |
Re: Clean firewall
Big block 73 that is soooooooo clean tops to you my friend.
#27 |
Re: Clean firewall
I really like that battery box. Where'd you get it if u dont mind me asking?
Its Kool to be a square ![]() 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers ![]() ![]() --- ![]() ![]() ![]() |
#28 |
yeller
Re: Clean firewall
CCP or CPP...I forget their name...but is is one of those two.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#29 |
Location: Where I come from, it's cornbread and chicken...
Re: Clean firewall
for the master cylinder, there are some kits that put the master cylinder up under the cab floor...then you won't see the master at all, just the steering shaft...
Chuck. |
#30 | |
Re: Clean firewall
#31 |
6.0 powered square
Re: Clean firewall
redrat has one
http://67-72chevytrucks.com/vboard/s...d.php?t=308535
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#32 |
It'd be alot cooler if you did
Re: Clean firewall
I made my own- it mounts it under the dash.
#33 |
Re: Clean firewall
hey flamingbig on picture 2 , you didnt put the sheet of metal all the way accross. How did that turn out? Did you fade it into the original sheet metal with bondo? Im thinking of just putn a sheet over the exsisting firewall. I got some 16 gauge today would that be to thick? If so what did u use? Did u just rivet it in or weld it in also? thanks
Its Kool to be a square ![]() 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers ![]() ![]() --- ![]() ![]() ![]() Last edited by Rollinsqrbdy; 07-16-2009 at 10:10 PM. |
#34 |
6.0 powered square
Re: Clean firewall
the sheet metal firewall cover turned out ok but its just temporary until I decide what I really want its stop at the ridges under the wiper motor because I didn't want modify the wiper motor rod, or cut into factory sheet metal and make patch since I had just rewired the truck and added sound detonator so I didn't want to cause a fire, and sheet metal 20 gauge I think and I used black sheet metal screws to hold it on
#35 |
Re: Clean firewall
Thanks for the info. That was a quick response bud
#36 |
6.0 powered square
Re: Clean firewall
no problem
#37 |
Re: Clean firewall
That was going to be my next question. Does re-locating the master cylinder/booster affect brake performance in anyway?
#38 |
Re: Clean firewall
Well I got alot of the panel cover done i just got to get it welded in but, that can be a problem as I dont got a meg or even know anyone that has one. Other than the welding shop but, i'd like to do it myself.
#39 |
Re: Clean firewall
Not to be a pest, but could we discuss the kits that relocate the master cylinder and brake booster to somewhere else(presumably underneath the floor)?
Will this affect brake performance in anyway? |
#40 |
Re: Clean firewall
#41 | |
Re: Clean firewall
#42 |
yeller
Re: Clean firewall
I made it, actually made a few and sold them...but the market wasn't there so I quit.
#43 |
#44 |
yeller
Re: Clean firewall
Flat 16 ga steel, bent and welded.
#45 |
Re: Clean firewall
here's mine....shaved heater, wiper motor, that ugly bracket behind the booster, and pretty soon the booster as well. switching to a wildwood manual...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
